Volks AutosSky Insurance
    Defratos's Avatar
    You’re Dethpicable!!
    May 2004
    London....Relocated to the Mid East
    2,230
    Weird noise when starting engine???
    Hey guys, some of you might already know that I've just recently got an S3 and so I'm not sure how it's engine is supposed to sound. I've only got two question and would appreciate any replies.
    1) When I start the engine it takes like 1.5 secs to actually ignite and has a sort of rumbling noise. I'm not talking about the exhaust I'm talking more in the region of the Cam belts.
    2) When accelerating there is a slight whistly noise from the engine, is there a factory fitted dump valve?
    P.S. Anyone know of any good spark plugs for the S3?? anyone fitted any?
    djjnrj
    Re: Weird noise when starting engine???
    small engine noise is normal for first start of the day. as for the whistle. that would be the turbo spinning up, sounds real good don't ya think? lol
    and yes, the S3 has a dump valve (BOV) as standard, but is kind of hard to hear unless you really listen cause it is a re-circulating one. hope this helps.
    Aug 2003
    Surrey
    469
    Yes, it's a diverter-valve, not really a dump valve.
    If you hear it release air between gear changes then it may need replacing - it should retain turbo pressure, not release it to atmosphere. They're about 20 quid for a standard one.
    Defratos's Avatar
    May 2004
    2,230
    yeah I sometimes hear it while changing gears. where exactly is this diverter-valve located? and how easy is it to change?
    Aug 2003
    Surrey
    469
    When mine was going, I could hear a "chakka-chak" kind of noise between changes (only with window open).
    You can see it on top of engine - do a search on "diverter" on this site and you should easily find images and more details, etc.
