Chris NottMonster Motorsport
Page 1 of 2 12 LastLast
Results 1 to 40 of 67
    Aug 2010
    bradford
    1,239
    can I run a hybrid without ?
    Hi iv just gone hybrid and getting it end of this week I got some mods for it but not the main ones.
    Im Running a cheap map at 20psi prob what's just fooooked my other turbo.
    I'm on a budget of 200 after iv bought the turbo from cr turbos.
    I no I need rods,3" downpipe, injectors and more but no got the money and need my car so instead of getting standered ko4 I went hybrid.
    Can I run my car with this without putting the foot down ,running high boost or takeing the map off so its standered again or am I just going to blow the engine up.
    If I can run one of these ways what will be the down sides.
    Thanks for any replys gaz
    350bhp & 316ftlb BBT new k16 7+7 blade hybrid turbo, Welly cooler, jetex filter, relentless ported v3 manifold 3" downpipe & de-cat, liquid gauge, r32 rear arb, AGU ported and polished Head, 550cc injectors, kw v2 Coilovers, s3dave tie bars & heat sheild, milltek cat back, I.E forged rods, brembos, inline fuel pump, v3 badger 5 tip, devils own WMI kit, AGU pistons, rear grooved discs & brembo pads, ds2500 pads & EBC ultimax disc, stack boost gauge
    Jul 2010
    bristol
    647
    so you want to run it with a hybrid turbo on either the standard or cheap map? why go hybrid if you havent got the money to do it properly?
    99' a3 quattro - k03s, carbonio cai, simota cone filter, FMIC, raceland coilovers, fully polybushed, forge TIP, forge 007p, forge coolant hose kit, forge throttle body pipe, stainless catback, brembo pads, stage one map, black angel eyes, 17" radius r3's gt28rs coming very very soon
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,079
    Depending on what the actuator is set at, if it's low enough, I think you'd be safe to run with the n75 unplugged, giving actuator pressure only
    Aug 2010
    bradford
    1,239
    I don't want to be swoping turbos paying someone to do that twice two I was going hybrid anyway three no point paying lots on same tubo iv had for 7 month four because I want to.
    If I cannot run the car like that it just means ill take it off road for few months till I have the money and plus side can play about with her a lot getting everything ryt
    Aug 2010
    bradford
    1,239
    Cheers prawn its set as standered mate iv been tolded that just wanted your thoughts mate no they would be a fault but would it still run ok and not nak the engine don't mind having it off the roadif that's better.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,041
    IIRC, Bill unplugged the N75 on Speedy Steves until he saved up for the map and injectors... running actuator pressure on std injectors should be fine and being a wideband ECU the fuelling will adjust ok so little chance of going lean... but! the N75 must remain off and don't fit the injectors before mapping as the map will not know they are larger... injectors and map should be done together and as you don't have rods I wouldn't suggest running much boost when it is done..
    <tuffty/>
    Welly's Avatar
    Testing dodgy Chinese gear...
    Aug 2009
    Gloucestershire
    10,680
    What Tuffty said - that's it in a nutshell.
    DON'T be tempted....
    Homer Simpson
    Wellyboots, you are quite literally my most favourite pikey in the entire world
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,173
    I think maybe you should have asked these questions before ordering the turbo
    I have just asked very similar questions to yourself but I have the money to spend but dont want to for the type of driving I do.
    I was running a cheap map and I bought a Revo map at Bills last weekend, this has sorted out a few of my running problems but has highlighted my weak turbo. The turbo will be coming off soon for a refurb.
    I asked the questions you have asked above and decided against a hybrid and instead will be just going for a standard K04 refurb and then maybe a stage 2 map when it's done.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    Aug 2010
    bradford
    1,239
    Great tufty what I wanted to here I won't be putting the injectors on till the map going 550cc geniusis and if I do get it mapped first be getting a boost controller so I can lower it to about 8psi if that's ok.
    Will it be running slower than what it was 202 g/s I'm not bothered just so I no its safe till sorted pal.
    Welly's Avatar
    Aug 2009
    Gloucestershire
    10,680
    Quote Originally Posted by s3gazz View Post
    Ummmm, yes. And don't take it anywhere near the redline to try and find out would be my advice.
    Homer Simpson
    Aug 2010
    bradford
    1,239
    Lol or I won't welly had too much bad look with her ha not going through no more
    Will be tempting like but least I no iv got it under the hood till sorted e cheers yours ok now.
    Welly's Avatar
    Aug 2009
    Gloucestershire
    10,680
    Quote Originally Posted by Westle View Post
    Thats because experience has taught you well mate.
    Homer Simpson
    Aug 2010
    bradford
    1,239
    Good look pal Iv always wanted more so that's why I went hybrid I no I should of asked first but ye no power power power came to mind plus been told I can run with n75 off just make shore ha
    Westy's Avatar
    Dec 2008
    17,173
    Old and wise my friend
    S3 Build Thread
    Welly's Avatar
    Aug 2009
    Gloucestershire
    10,680
    Just take it steady Gaz and things should be OK.
    Might be worth taking a look at this:
    http://www.thewellings.co.uk/audi-sp...Conversion.pdf
    Thats with VAT @ 17.5%, not the 20% it is currently. And there are no labour charges there.
    Homer Simpson
    Westy's Avatar
    Dec 2008
    17,173
    lol that's what put me off
    S3 Build Thread
    Welly's Avatar
    Aug 2009
    Gloucestershire
    10,680
    LOL, I want to avoid people making the mistake I did thinking that a hybrid is quick, cheap and easy power.
    It isn't.
    Homer Simpson
    Westy's Avatar
    Dec 2008
    17,173
    It isn't.
    Yeah and you'll find that out when Dane's car wizzes past you on the air field
    S3 Build Thread
    Welly's Avatar
    Aug 2009
    Gloucestershire
    10,680
    Stop winding.... lol. :P
    Homer Simpson
    finesse's Avatar
    Aug 2006
    London / Anglia
    2,814
    19 posts & not a mention of RODS!! Its a record
    Westy's Avatar
    Dec 2008
    17,173
    Quote Originally Posted by finesse View Post
    Check out Wellys link above mate. Lovely little price list, including rods
    S3 Build Thread
    Welly's Avatar
    Aug 2009
    Gloucestershire
    10,680
    Except for the very first post....
    Homer Simpson
    Westy's Avatar
    Dec 2008
    17,173
    Finesse's skim reading skills are imense
    S3 Build Thread
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,041
    Ok... first... you won't be able to get it mapped before fitting the injectors... a) whats that actual point as it will need mapping again, z) no one in their right mind would actual map it without injectors!
    IF you need to run the car at all, pull the N75 off and drive carefully... its 'safer' with it disconnected however it doesn't mean you can drive like you stole it even on limited boost...
    Speedy Steve had alternative transport while waiting to get his mapped... IF you can get away with it then don't drive the car...
    The ECU will adjust to compensate for the increased air flow but it will still be advisable to not rev the car to the redline (as Welly has already said)
    Low revs and no hard acceleration and you should be fine... but you HAVE to be responsible...
    Personally if you haven't got to drive the car then don't.. and yes you will be pulling much less airflow and the car will feel powerless...
    <tuffty/>
    finesse's Avatar
    Aug 2006
    London / Anglia
    2,814
    Lolnot reading
    Aug 2010
    bradford
    1,239
    Thanks welly great help mate I'll take it steady till it's done
  28. #27
    Sep 2010
    London
    65
    Got a question for you while your on this subject, as I am in a similar situation. I sent my s3 off to have the the engine rebuilt as the head gasket went and I found a crack in the head and exhaust manifold. Got the turbo checked while it was there and that has also cracked. So I went hybrid aswell for the same reason, but had the con rods, pistons done with the build. Should I be running this set up with the standard intercoolers, injectors, etc
  29. #28
    Welly's Avatar
    Aug 2009
    Gloucestershire
    10,680
    Quote Originally Posted by Dan S3 View Post
    Not really, but depends on the mapping I guess...
    Homer Simpson
  30. #29
    Aug 2010
    bradford
    1,239
    Thanks I won't be mapping it anyway and wasting money was just thinking if it saves mi car then 400 is worth that.
    I would not drive like a tit if people tell me not to with how the car wil be running the n75 will be off all time.
    Am I ryt thinking I can get I mapped proply and put the foot down when iv done the following rods,injectors, 3"downpipe tar
    The less power can handle that just get me from a to b if I need to drive if I don't I won't what's the point.
  31. #30
    Aug 2010
    bradford
    1,239
    Just found out A guy fitting my turbo for 60 who has fit rods before as he's a machinic has just told me he will do them for 180 is that a bargin or not and is it realy a big hard job
  32. #31
    Sep 2010
    London
    65
    It's at amd essex, they fitted the engine and they are gonna do the mapping. Originally I was only gonna do the usual dv, induction kit and stage 1 map but it has all snow balled. How important are the injectors? I can understand the intercooler but im not looking to break the 300 mark just yet, and should I be looking at the down pipe to get the hot gasses out quicker?
  33. #32
    www.badger5.co.uk
    May 2004
    nr Glos
    6,951
    thats very cheap gaz....... almost too cheap
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
  34. #33
    Westy's Avatar
    Dec 2008
    17,173
    Don't forget that a decent set of rods will cost you around 300 too.
    S3 Build Thread
  35. #34
    Welly's Avatar
    Aug 2009
    Gloucestershire
    10,680
    almost too cheap
    You pay peanuts, you get monkeys...
    Fitting rods is a BIG job.
    Homer Simpson
  36. #35
    G60DAN's Avatar
    Cornwall
    318
    I've not long got rods they where 350
  37. #36
    Dane's Avatar
    Faster than a V12 Q7
    Cheltenham
    3,991
    Worth it though! It's nice not having to worry about that sort of thing.
  38. #37
    Westy's Avatar
    Dec 2008
    17,173
    Quote Originally Posted by Dane View Post
    Did you buy your car with the rods done Dane or did you get them done?
    S3 Build Thread
  39. #38
    Dane's Avatar
    Cheltenham
    3,991
    Bill did them for me after owning the car for 4 months or so.
    If I was staying at a stage 1 I probably wouldn't of had them done, but I have Welly-esque aspirations!
  40. #39
    Aug 2010
    bradford
    1,239
    it is cheap bill i no its a guy my girlfriends uncle nose has his own garage hes fitting my turbo on tuesday and then going to ask him to do rods i think been in the buisuness a few year and done some before
  41. #40
    Aug 2010
    bradford
    1,239
    do i need a manifold gasket if its coming off with turbo guys tar
