AH FabricationsEM Tuning
Results 1 to 11 of 11
    DaveA3's Avatar
    Audi A-Trizzle!
    Milton Keynes
    2,378
    Gap between Rear brake pad and disc
    Hi all,
    Had a look at the brakes last night as they feel crap. Dunno if they just need bleeding or something but they just feel **** like all the braking is at the front. Anyway i noticed at the back the rear pads are both like 2-3mm away from the disc (plenty of tread left)this cant be right surely? the front is almost touching which seems normal to me. Any ideas im thinking seized piston or something?
    Also side question does the handbrake do just the rear brakes or all 4?
    Audi A3 1.8T Sport (AGU) - 2000
    Engine: Carbonio CAI/Jetex JR Hybrid Induction, Forge 007p DV, Forge TIP, Longlife S/S Custom Exhaust system, R-Tech Stage 1 Remap, Creation Motorsport Boost Pipe Kit.
    Exterior and Chassis: 18" Cades Tyrus, Euro Wipers, low on JOM Coilovers, Eibach Front & Rear ARB's, Black Angel Eye Headlights, 6000K HID's, S3 Brakes.
    For Sale PM ME - £2500 Mods Inc
    mikeyg's Avatar
    Jan 2011
    Milton Keynes
    835
    Handbrake works just the rears.
    If there is an obvious gap between rear pads and discs, is it possible to get sdomeone to press the brake pedal for you, while you look at the pads to see if they move against the disc.
    Might help to know wether a caliper is seized. Or if you have a jack, jack the rear up and spin the wheel and get someone to hit the brake to see if the wheel stops dead.
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,840
    The pads on the rear should be touching the disks when you have the handbrake on! If they aren't, then something is up.
    You've got to have a laugh!
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,655
    Like above, something dont sound right with that.
    If you roll the car a little bit and put the handbrake on, what happens?
    It should stop the car and have even braking on both sides.
    A4 B5 Double Din, RNS-d, TMC, Full Sports Leather Heated with Leather Door Cards and Lower Door trims all for sale.
    Audrey's Build Thread
    RIP Audrey. She's being broken down.
    New Car, New Thread.
    Scott's Akoya Silver A8
    DaveA3's Avatar
    Audi A-Trizzle!
    Milton Keynes
    2,378
    Quote Originally Posted by Axios View Post
    ill try this on the way home.
    and the other stuff at the weekend. im just taking it easy now for obvious reasons.
    thanks all!
    SiGainey's Avatar
    Sep 2003
    North Wales
    475
    Sounds like a siezed caliper. Real common you can pop the piston out and re-grease but the only long term is to replace
    '01 AMK, completely standard except for the Ambient Lighting Pack.
    DaveA3's Avatar
    Audi A-Trizzle!
    Milton Keynes
    2,378
    if im gonna have to replace i may aswell upgrade
    i done the rolling test last night and it braked at the rear but hardly done anything at all. Like uber weak!
    when parked i put the handbrake on. the car didnt roll but if i got out and pushed it, it went forward no problem!
    its like when u just put the handbrake on 1 click but it was on like 5 clicks
    Just needs adjusting or still sounds like something has seized?
    cheers
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,059
    The pads could be seized on the callipers too common problem
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,655
    I'd side with it being seized but it might be worth taking the calipers off and give the pad runners a clean and check the caliper to make sure every thing appears ok.
    All else fails, upgrade time.
    DaveA3's Avatar
    Audi A-Trizzle!
    Milton Keynes
    2,378
    ok ill have a go at the weekend time permitting. i may just take it to my local indy and get them to sort it quick as the missus is buggin to go to lakeside shopping on saturday.
    thanks again lads
    oh anyone know some of the upgrade options? nothing too fancy as its just the rear but any suggestions welcome
    May 2010
    Bedford
    2,877
    TT rears which use the bigger vented discs. Chris on BucksVag has done it on his Fabia so you could always have a work or have a search around the net to see whats needed and so on. He reported a nice change from them with 312`s on the front.
    Cactus green 8L S3 - B5 TIP + Jetex, Revised 007p, R32 rear ARB, AP Coilovers, Compbrake rear arms, Full Powerflexed dogbone.
