Sky InsuranceVolks Autos
Results 1 to 7 of 7
Thread: S3 hub nut size
    Jul 2010
    111
    S3 hub nut size
    hey folks,
    wanting to do my drivers side fron wheel bearing, what size is the hub nut? big allen key nut by the looks of it
    cheers
    2001 S3 AMK. Viper Remap, Forge 007P, Carbon fibre engine cover, SFS TIP, Tints, Forge Breather Hoses, Auti R8 oil Cap, Leon CPR Top mounts, S3 car mats, German number plates. 249 By Pass mod
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,563
    17mm
    <tuffty/>
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,563
    ...and its a bolt... that needs replacing ideally...
    ...and you will need a press to press out the flange and bearing... (as well as press it back in of course)
    <tuffty/>
    Jul 2010
    111
    cheers buddy awesome.
    Jul 2010
    111
    will the knuckle have to coem off aswell bud or is the wheel bearing housing a seperate unit?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,563
    You will need to pull the suspension strut out the top, ball joint from the bottom, brake caliper and disc and track rod end to remove the hub carrier... then you need to press out the drive flange from the rear of the carrier first, undo the circlip then press out the bearing from the front... press the new bearing in from the rear and fit the new circlip, press the flange from the front supporting the inside part of the bearing else it will just push this out and destroy the bearing... refit the hub carrier and attach all the bits you removed... the hub bolt needs to be done to a procedure... further helpful info includiong doing up the hub bolt can be found here..
    Driveshaft gaiter replacement tutorial
    <tuffty/>
    Jul 2010
    111
    ace mate thanks for that, bit more clear in my head now, will let you know how i get on. thanks again
