Chris NottMonster Motorsport
Results 1 to 11 of 11
    Mar 2011
    S3 Swaybars install Picture
    Hi there,
    Does anybody have a picture of their rear and front sway bars installed on the S3 or A3 quattro ??
    thank you.
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,566
    Quote Originally Posted by bogdan_wrc View Post
    Hi there,
    thank you.
    By sway bars, I'm guessing you mean Anti Roll Bars(ARBs) right?
    What exactly are you looking for? If it's an after market set up you are looking at, it just looks the same as standard but different colour maybe?
    DaveA3's Avatar
    Audi A-Trizzle!
    Milton Keynes
    2,378
    they call em sway bars in USA etc dont they?
    yeh i didnt have one at the rear but front is the same just a lil wider and red. The rear one is just red also just straight across at the back.
    Audi A3 1.8T Sport (AGU) - 2000
    Engine: Carbonio CAI/Jetex JR Hybrid Induction, Forge 007p DV, Forge TIP, Longlife S/S Custom Exhaust system, R-Tech Stage 1 Remap, Creation Motorsport Boost Pipe Kit.
    Exterior and Chassis: 18" Cades Tyrus, Euro Wipers, low on JOM Coilovers, Eibach Front & Rear ARB's, Black Angel Eye Headlights, 6000K HID's, S3 Brakes.
    For Sale PM ME - £2500 Mods Inc
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    shouldn't they be anti sway bars...lol
    Mar 2011
    i am referring to these
    http://hemitruckclub.com/MrHemi%20In...ar/hellwig.jpg
    or
    http://www.rc-truckncar-tuning.com/i...way-bar-2a.jpg
    yes, also known as Anti Roll Bars.
    I am looking for the H&R ones, or any other ones which will be fitted after-market.
    I have a custom exhaust, with a very straight pipe, and I want to know if it interferes with the rear swaybar/ Anti Roll Bar.
    So, pretty much searching for a picture from underneath an S3 8L with aftermarket (H&R or any other type) swaybars/ Anti Roll Bars installed.
    thank you for your answers.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,583
    or
    Now if you had said that in the first place lol...
    the rear ARB is well up out the way above the heat shielding and you should have no probs... makes no odds if fitting after market ones either..
    std exhaust
    3" exhaust..
    <tuffty/>
    Mar 2011
    hello tuffy we meet again :P
    thank you if I have knew you had these..i would have asked for those pics on the other forum :P
    and how do they feel?
    any other pics?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,583
    any other pics?
    Thought I recognised the user name... I currently have std ARB's on mine but planning to use R32 ones when I get around to it... plenty of threads on here about R32 ARB's and there are some performance related threads in the FAQ sticky you should read..
    <tuffty/>
    Ginge's Avatar
    It's never fast enough !
    Jan 2011
    Hemel Hempstead (home) / Loughborough (UNI)
    192
    Just fitted the Neuspeed 19mm rear ARB massive difference major improvement
    Can't comment on a front one though sorry
    99' S3 APY currently just 007p, Badger 5 TIP, Customised Miltek non-res cat-back, Jetex cone, H&R Springs and Bilstein B8 Dampers ... 3" Downpipe, AH Fabrications FMIC and R-Tech Re-map on the way
    Mar 2011
    was it hard to fit them? seems very difficult..to take it out and to pass it through all those pipes and small spaces...
    the R32 ones are thicker or? what is the diff between H&R and R32 standard?
    do you have the codes for these? the H&R and around 500euros the set of two..
    thank you very much for the replies.
    mk1chopper's Avatar
    Missing the S3
    Oct 2006
    Bedford
    1,095
    Rear ARB isnt hard to do, just need to drop the exhaust down remove and refit, front requires a bit more work, i think it can be done without removing the subframe but easy to do with the sub frame dropped.
