JMB RetrofitsChris Nott
Results 1 to 8 of 8
Thread: Knock sensors
    AudiiduA's Avatar
    Midlands
    358
    Knock sensors
    Hi all, had my s3 on vagcom today, needed a new MAF and a knock sensor! how hard is the knock sensor to fit? pics would be good as cars gone into limp mode
    finesse's Avatar
    Aug 2006
    London / Anglia
    2,814
    can not find a pictures now but its around the inlet mani
    AudiiduA's Avatar
    Midlands
    358
    Quote Originally Posted by finesse View Post
    Mines AMK, i believe theres 2?? is this correct? i know where they are just looks a pain....
    Aug 2009
    Nuneaton
    34
    Pm'd ya matey
    Agric04's Avatar
    Feb 2011
    Grantham, Lincolnshire
    198
    This may or may not help you. I had a real issue with my knock sensors about 2 years ago. Vagcom kept identifying one of the knock sensors as faulty. Had the car at various garages trying to resolve issue and changed the faulty knock sensor twice before giving up and taking mine to the stealers. Turned out that the faulty knock sensor for me was the one that vagcom wasn't picking up as the good knock sensor was doing it's job and logging the fault. So if you change your knock sensor and still get faults try changing the other one too. Worked for me.
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Can also be wiring related, so check out the connections, and look for broken wires before parting with cash.
    Knock sensor is easy to change if you need to - they are both on the face of the block.
    Make sure you do them up to the correct torque - 20 nm rings a bell but don't quote me on that.
    Homer Simpson
    AudiiduA's Avatar
    Midlands
    358
    Its coming up with no 1 sensor! is that the left or right one??
    LD3
    Japanese Baseball Champion
    Oct 2007
    Bromley,Kent
    99
    Mine had a knock sensor fault-turned out to be some wriring and not the sensor itself.
