EM TuningChris Nott
Results 1 to 12 of 12
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,263
    Accessing the heater unit?
    How do I get at the heater unit? When I turn on/off the cliate control unit it sounds like something is sticking as I can hear it clearly from behind the glove box. I've also been experiencing a peppery smell when the heating is on and I can only imagine that my heater/air cn unit is at fault.
    Is there a guide that shows how to get at the unit?
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    SiGainey's Avatar
    Sep 2003
    North Wales
    475
    '01 AMK, completely standard except for the Ambient Lighting Pack.
    Westy's Avatar
    Dec 2008
    17,263
    Cheers Si, my searching skills aren't the best!
    S3 Build Thread
    Westy's Avatar
    Dec 2008
    17,263
    Well I took the fan off last night and checked the air passage to thepollen filter and there is nothing in there that looks to be causing the smell coming through it.
    The smell must be coming through from the engine bay!
    I have recently fitted new rocker cover gasket and cam adjuster gaskets so there is no oil leaking from there. I have also cleaned my engine bay with gunk after realising I was running the oil catch can open for 6 months and it was leaking oil in the bay.
    The only other place I can think that this smell might be coming from is all the grease that has splattered everywhere from a split CV boot.
    I'm going to get one of those Air con bomb flush cans to try and clear the smell but it's becoming annoying now.
    S3 Build Thread
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Bacteria on the evaporator usually causes smells but its more of a bad egg smell than what you are describing, is your pollen filter seated correctly? and is it clean
    Westy's Avatar
    Dec 2008
    17,263
    Yeah this is like a peppery spicy smell a little like celery! It appeared shortly after fitting the oil catch can last year so I thought it was that but the contents of the can never smell like that!
    The pollen filter is seated correctly and clipped down. It was changed last June as part of my service and is mint.
    S3 Build Thread
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    My dads B5 had that smell when his heater matrix started leaking.
    Clean the windscreen (inside) so it's super clean, then set your heater on windscreen mode, max heat and full fan speed, if small amounts of coolant are in the heater channels it'll show up as white mist on the windscreen, looks like steam but it'll be sticky
    It's very rare for heater matrixs to go but if it is the matrix it'll get gradually get worse
    Westy's Avatar
    Dec 2008
    17,263
    Cheers Sandip. Is there a more accurate test that can be done like checking the heater matrix
    Where abouts is the heater matrix located?
    S3 Build Thread
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    Quote Originally Posted by Westle View Post
    Not sure there is to be honest, usually leaking heater matrix's cause wet floors but becuase the venting is well sealed the coolant tends to stay in the venting and evapourate when you put the heater on. Trust me, if you matrix is leaking you see the white residue on the windscreen lol
    If it's a tiny leak, coolant level won't really go down, you may possibly notice some discolouration in the coolant though
    The matrix is located within the depths of the dashboard nightmare!
    Westy's Avatar
    Dec 2008
    17,263
    Well I hope its not that then! I'll try one of these flush bomb things to see if that clears it.
    S3 Build Thread
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    Wack your heater on windscreen mode, max heat and full speed for a few mins
    Westy's Avatar
    Dec 2008
    17,263
    Quote Originally Posted by sandip View Post
    Yes sir
    I'll give it a go later.
    S3 Build Thread
