So on Saturday the sun came out finally wooooo and I decided it would be nice to have the sunroof open! (for the first in a year probably - not ever had issues with it and I oiled the tracks last summer so it was nice and smooth)
Anyway fully made it slide open and no problem - it was glorious! Came to shut it again and it closed half way?! Random I thought So I turned the dial fully open and close and it still only closed half way - this carried on for a good 15mins! Interestingly it didn't register a 'click' (usually a click on the dial opens it a tiny amount) only as soon as u fully turned it on the dial would it start to open
The weird thing is when it tries to close and get half way the only other way I could get it to close further was when you pull pull the dial down (usually used to opening the sunroof vertically) and it will close another tiny bit to 2/3rds and that's it! Arggggggggghhhhh!
So I had to take the switch of in the end and overide it manually by closing it using the allen key on the motor. (obv tried dis and reconnecting it and the same thing happened) I checked all the tracks and there's nothing blocking them
I tried opening it again fully closed once id manually shut it with the allen key and it had no problems sliding open again BUT wouldn't close again!!!! Even if i only try to open it vertically by pulling the dial down it resorts to sliding it open?!?! V frustrating Mechanically it seems fine and the tracks are clear visually.
Anyone experienced anything like this before or can offer any suggestions? Greatly appreciated.
