Volks AutosEM Tuning
    Feb 2011
    Stoke on trent
    48
    And the saga continues
    After my post yesterday about the A3 not revving i rang psi and ordered a maf
    picked it up last night took the old one off (piece of cake) only to find the new one was bigger and would not fit air box fitted old back and a3 would not rev at all unplugged maf and it reved fine rang psi this morning gave them part numbers off olg maf they sourced one for 10.30 this morning went up fitted my self outside their reception took for a spin engine management light went off but was hunting on tickover anywhere between 250 to 900 revs.
    Psi reran diagnostic and cleared couple of faults the first fault of 2 weeks ago has now gone running rich possible coolant temp sensor or Maf sensor and they now reckon that there is air getting into the system as the turbo is making a slightly different noise they reccomend to remove all hoses to check for leaks and have quoted 2 hours labour and then any parts it could be either a cracked hose or a J valve not sure what this is but it now only hunts a bit and is stable around 900 revs with only slight fluctation.
    I did not get the error codes but was wondering what you guys think i should look at next
    regards
    Lee
    www.badger5.co.uk
    May 2004
    nr Glos
    6,944
    Is the maf the right one ??
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
    Feb 2011
    Stoke on trent
    48
    yes matches part numbers that i gave them after the first one was too big to fit my airbox
