Results 1 to 34 of 34
    MingeBlue's Avatar
    Feb 2008
    112
    Garage Prices reasonable ?
    Hi my A3 1.8t 2002 53k serviced today at an indie, jobs they recon needed doing totalled Ł1900 , two minds whether to keep it now.
    I was expecting it to need a fair amount of work new breaks discs and pads alround and new rear suspension springs as one had broke, but wasnt really prepared for the list they came back with. Some of the items after googling seem pretty common 1.8T issues engine wise but alot of the cost are bushes and roll bars and mounts bit. Considering I don't use the car much and funds are limited I'm trying to priotise what I get done, some of the prices quoted are below are they reasonable I'm based north London ?.
    Replace rocker cover and timing chain adjuster gaskets as leaking (though Ive not seen oil) Ł211, they mentioned this at another service before at a different garage but they sia just to keep eye n t and it seems fine
    Throttle value cleaned and reset Ł78
    Top breather hose leaking Ł78
    New rear springs Ł210
    disks and pads all round Ł420
    Front anti roll bar bushs Ł214
    ihsbone bushs warn Ł169
    REar axles bushes Ł210
    Front top suspnsion mounts Ł182
    2002 A3 1.8T
    beachbuggy's Avatar
    Surrey
    1,745
    Throttle value cleaned and reset Ł78 - 30 minutes work, no parts needed.
    Top breather hose leaking Ł78 15 mins labour. not sure on parts.
    New rear springs Ł210. 1 hour labour, and then cost of the springs.
    disks and pads all round Ł420. 1.5 hours labour. Depends on quality for cost of parts.
    Front anti roll bar bushs Ł214 - 1 hours work max and Ł13 in parts. ( That's a ridiculous price to replace. )
    ihsbone bushs warn Ł169 - Ł40 parts. 1hour per side.
    REar axles bushes Ł210 - Ł30 in parts, shouldn't be more than 2 hours work
    Front top suspnsion mounts Ł182 - Ł20 in parts and if they're changing the wishbone they can do it at the same time. On there own it would take no more than 1.5 hours for both sides. However with the wishbone already removed it's a 2 minute job literally!!!!
    I can only say, that some of the prices they've charged you are very very expensive. The only PITA is the rear bushes. Other than that it's all straight forward stuff. And bearing in mind changing say the front disks/pads, front bushes, front ARB and top mount can all be done at the same time, makes is all easy, as to change the top mount when the wishbone is out is a doddle. 1 Nut!
    Jacko4130's Avatar
    Goodie Gum Drops
    Dec 2007
    mansfield
    839
    Sounds like a rip off to me, if your no good with the spanners i'd get some more quotes...
    Black S3
    beachbuggy's Avatar
    Surrey
    1,745
    Just seen this as well
    Well the gaskets for this are less than Ł30. And would only take 1 hour max to fit...
    MingeBlue's Avatar
    Feb 2008
    112
    Thanks for the insite guys, I did think some of the job prices were a tad on the expensive. I can only really affOrd about Ł500 at the mo so will get rear springs done for Mot and sort the brakes, will also have to find a new garage who are more friendly on how they charge labour someone who charges on actual time taken
    2002 A3 1.8T
    jcs356's Avatar
    Brum brum
    Jun 2004
    Englandland
    2,681
    Whereabouts are you? I'm sure we could recommend some better places local to you.
    Jason
    2001 Nogaro S3 (daily driver)
    1958 replica Porsche 356 Speedster (summer posing)
    1997 Seat Cordoba SX 16v (track day toy) replacing (t)rusty 1994 Seat Ibiza GTi RIP
    May 2006
    Lancs
    211
    They all seem massively inflated to me. Ł211 for rocker cover gasket is madness, not to mention the rest. I know garages have overheads to cover and need to make a living but those seem more in line with main dealer pricing.
    Just as a guide a local garage replaced my rear springs, a wishbone bush, an inner cv boot(I supplied this) and put it through it's MOT for Ł235.
    MUSH's Avatar
    MUSH Developments Ltd.
    Jun 2010
    Newcastle
    712
    Why not price all the parts up and possibly buy them all yourself? Try tps/gsf/ecp?? Then its just a case of finding a good mechanic who wont rip you off. As mentioned above its all pretty standard stuff bar the rear beam bushes which can be awkward and if its all done together whilst in bits surely the labour wouldnt top a full day.
    Audi S3 1.9 GT30....
    ....that is all
    Agric04's Avatar
    Feb 2011
    Grantham, Lincolnshire
    198
    I had a rear spring replaced on my 1998 a3 1.8t for it's mot in Jan for under Ł100. On my S3 Jabbasport replaced all my front bushes with superpro bushes, a new front arb, top mount, breather pipe, new subframe for less than Ł1100 and the new subframe alone cost Ł450 from the stealer. You're definitely being ripped off, travel to somewhere like jabbasport or awesome gti and get the job done by a specialist who won't take this piss! I wouldn't get any work done at that garage.
    MingeBlue's Avatar
    Feb 2008
    112
    Thanks everyone for the replies and suggestions, I'm based in Harrow / pinner area if anyone can recommend a decent mechanic but I'm also willing to travel?
    Thought it seemed pricey and it seemed a shame to let the car go because of it.
    2002 A3 1.8T
    Agric04's Avatar
    Feb 2011
    198
    You could try VAGtech Limited - Independent Specialists for VW Audi Seat Skoda at Milton Keynes. Never used them but believe they have a good reputation and I think about an hour from you.
    MingeBlue's Avatar
    Feb 2008
    112
    I started ringing around a few other garages mechanics today for prices and most seem to be about 20% cheaper then I was orginally quoted which at least is something.
    I was looking through my haynes manual though last night and I was thinking that may be some of the work I could do myself, like replacing the top breather hose and cleaning / resetting the throttle value, do you think these are jobs someone with not to much hands-on car experience maintence could do ? If so got a few questions,
    1. The top breather hose is it that this pipe in the pic in this post ?
    help! broken hose and totaly clueless!
    2. Cleaning the throatle value and resetting, how easy is it to get this out, and what do they mean by resetting would that mean hooking it up to vagcom ?
    2002 A3 1.8T
    DaveA3's Avatar
    Audi A-Trizzle!
    Milton Keynes
    2,378
    the throttle is 4 screws. its at the front left of the engine mate with a big black pipe going into it.
    just get some carb cleaner and a cloth and wipe clean. mine reset itself on idle after a few mines. There is a lil procedure (key in and out kinda thing) u can do.
    my rear axle bushes were changed for Ł110 fitted.
    i had my front and rear anti roll bars fitted with bushes for Ł80 (labour i bought the bars myself).
    standard discs and pads should cost around Ł250 for parts all round. so probs around Ł340 all in.
    Audi A3 1.8T Sport (AGU) - 2000
    Engine: Carbonio CAI/Jetex JR Hybrid Induction, Forge 007p DV, Forge TIP, Longlife S/S Custom Exhaust system, R-Tech Stage 1 Remap, Creation Motorsport Boost Pipe Kit.
    Exterior and Chassis: 18" Cades Tyrus, Euro Wipers, low on JOM Coilovers, Eibach Front & Rear ARB's, Black Angel Eye Headlights, 6000K HID's, S3 Brakes.
    For Sale PM ME - ÂŁ2500 Mods Inc
    MingeBlue's Avatar
    Feb 2008
    112
    Cheers DavidA3 what garage / mechniac did you use ? Ringing round my area labour rates are between Ł55 - Ł65 an hour plus VAT thats just normal garage not speacilests.
    2002 A3 1.8T
    Aug 2010
    652
    how much for labour!! my garage charge Ł35 an hour for labour. I say a days work there, so Ł245 labour for the day. Ł300 inc tax. Then parts get yourself as you will get them cheaper.
    To give you an idea my local garage charged my mate Ł80 to fit all 4 coilovers...
    New wishbones are Ł40 a pair on ebay and took me an hour to fit on my drive....
    New garage time if i were you....
    Rob_B's Avatar
    Mar 2010
    Norwich
    194
    get yourself on eurocar parts and price the parts up mate...then at least you will have another figure to compare the parts to...that sounds awefully expensive to me
    i had my top mounts done last year...got genuine parts and mine cost me Ł120incl labour
    so thats Ł62 they are more already!!!
    in regards springs too...they arent cheap from audi, i broke a front one so took the opportunity to lower the car...this would be ideal for you too camskill do a set of apex spirngs for Ł78ish(from memory) as you will need to do the top mounts and one rear spring the labour would be nothing!
    i hope this helps?
    MingeBlue's Avatar
    Feb 2008
    112
    May be its just London garage rates that are high, I've called around and Ł55 plus VAT was lowest I could find. Also most of the garages seem to have quoted based as if each item at a time was being worked on seperately ignoring the fact they may already have bits off that save time. The actual Indie I went to orginally actually ended up charging me more for a oil service than Audi themselves do, I only went to them because I thought the other work I needed doing would be cheaper but seems not.
    I'm pretty hands on fixing stuff willing to have a go at the top breather and cleaning the throttle valve, the other stuff probably not safe for me to have go on my own.
    2002 A3 1.8T
    May 2006
    Lancs
    211
    Get the spanners out! The suspension stuff maybe not because I think you'll need spring compressors but certainly the breather pipe, ARB bushes, brakes, cam cover gaskets and throttle body aren't difficult at all and will only need basic tools.
    If you are stuck just grab a copy of Elsawin of Ebay for a fiver and you have step by step instructions.
    Agric04's Avatar
    Feb 2011
    198
    Are the eBay copies of Elsawin any good? Are they legal copies? Anyone tried them?
    May 2006
    Lancs
    211
    I have one and it works for me. Not sure on the legalities but I guess eBay would be getting involved if there was any copyright issues.
    Aug 2010
    652
    good old haynes! this is why people learn to work on cars...save a fortune!
    Sep 2010
    Telford/Shropshire
    366
    way over priced mate! just for an example:
    brakes (discs,pads all around Ł420 ???
    they gotta be kidding!
    for about Ł300 Ł320 ish u can get (not a standat relplacement) but an upgrade (ebc green stuff pads,and turbogrooved discs ) thats about 320 for an aftermarke upgrade setup of 4 discs,4 pads
    and these lads charge u 420 for oem replacemet?? even if that price is with the cost of fitting that way too overpriced! not to mention some other stuff from that list of yours.
    take your car to a another '' more reasonable'' garage
    DaveA3's Avatar
    Audi A-Trizzle!
    Milton Keynes
    2,378
    Quote Originally Posted by MingeBlue View Post
    i use ZM car repairs (vag specialist too) in milton keynes. They are Ł30 an hour labour
    MingeBlue's Avatar
    Feb 2008
    112
    Quote Originally Posted by DaveA3 View Post
    Thanks DaveA3 I will probably give them a try as it will be worth it as it will save me alot of ŁŁŁ.
    On a side note the garage also mentioned my clutch could be on its way out, was just happening to read Autocar last night and they were looking at second hand TT's and they stated to fit a new clutch to that was an engine out job Ł1200 , is that the same case with an A3 1.8T considering its the same engine ?
    2002 A3 1.8T
    Agric04's Avatar
    Feb 2011
    198
    Had new clutch on my old a3 and can 100% say it's not an engine out job.
    thegoal007's Avatar
    Another S3 owner....
    Apr 2008
    surrey
    729
    [QUOTE=MingeBlue;1207823]Thanks DaveA3 I will probably give them a try as it will be worth it as it will save me alot of ŁŁŁ.QUOTE]
    And some real dodgy garages charge half he labour rate and then double the amount of time required for the job :-)
    I think if your in London and want to get in repaired then you'll be paying the going rate. I do wish people would update their profiles so we know what part of the world they live.
    02 plate - 2002 - 225bhp - S3 - Ming Blue - completely standard - nuff said, OK there's a centre armrest, sunroof, BOSE speakers & black leather recaros, oh and the non OE chrome pack !
  28. #27
    DaveA3's Avatar
    Audi A-Trizzle!
    Milton Keynes
    2,378
    i've used them for the past 6 years definitely no issues with prices or extensive labour times. they work very efficiently.
    clutch isnt an engine out job on the a3. On the quattros and s3 etc its a bit more intensive due to all the haldex gear etc being in the way
  29. #28
    mk1chopper's Avatar
    Missing the S3
    Oct 2006
    Bedford
    1,095
    Id happily recommend TTS (www.ttshop.co.uk) in Kempston (J13 M1) Ł69 an hour but there a specialist, phone up for a quote on the work you want doing im sure they'd give you a decent quote, they stock OEM and uprated parts too so they could give you some alternatives (as others have said like lowering, uprated bushes)
  30. #29
    DaveA3's Avatar
    Audi A-Trizzle!
    Milton Keynes
    2,378
    them dudes are pricey but do know what they are doing aswell. tbh e gets better rates in london than the ttshop
  31. #30
    MingeBlue's Avatar
    Feb 2008
    112
    I've sent them an email DaveA3 thanks with a list of the jobs asking for a quote so fingers crossed. I'm happy to drive an hour and hang round Milton K for a day then drive back if it saves me Ł400+
    2002 A3 1.8T
  32. #31
    thegoal007's Avatar
    Apr 2008
    surrey
    729
    And don't forget then to add a fifth of the total on top........VAT !
  33. #32
    MingeBlue's Avatar
    Feb 2008
    112
    Big thanks to DaveA3 I owe you a couple of beers, zm repairs came through with a very good price well chuffed, looks like I will paying a visit to Milton K in the next few weeks
    2002 A3 1.8T
  34. #33
    DaveA3's Avatar
    Audi A-Trizzle!
    Milton Keynes
    2,378
    no probs mate Top blokes. Tell em i sent u. Just say David with the A3. Glad you got a good price in the end! Plenty to do in Milton Keynes for the day aswell.
  35. #34
    dany2k's Avatar
    Dec 2010
    Lancashire, England
    298
    Quote Originally Posted by thegoal007 View Post
    say... i was going to pay with my credit card, what can you do for me if i pay cash? always works for me!
    Audi A3 8L 1.8T Quattro 180 in black. Totally standard: for now...
