EM TuningSky Insurance
    Imteyaz's Avatar
    Oct 2008
    Warwickshire
    524
    How to - change the connector on your MAF plug wiring.
    Whilst having my clutch changed recently, the garage that carried out the work managed to break the little tab that you press to unclip the MAF plug from the sensor. Now, to most people this wouldn't be a big issue but my OCD kicked in and I wanted to replace it (I had doubts that the plug would fall out at some point from not being secured in place).
    Speaking to TPS, they informed me that the replacement plug costs less than 2 so I ordered one. Here's what you need to do to replace the connector:
    1 x new connector (1J0 973 999 A), 2 small flat screwdrivers and a little patience.
    The new connector is slightly different to the original one in that the 4 cables that push in to the connector are held in by a horse-show shaped clip instead of barbs used in the original unit. This horseshoe clip slides from side to side and is better than the original design that normally requires the correct pin extractor to remove the barbed connector / cable.
    To expose the original cabling, unclip the two tabs on the 90deg rigid trunking and this will expose the 4 cables with round dust seals. Make a note of which wires go in which position (there are 5 slots on mine yet only 4 are used, the 5th one is left empty).
    At the end of the plug where you can see the female cable connections, you will see a piece of red plastic surrounding the 4 female connectors - you may find like me that this has become brittle over time and bits have broken off - break it off completely - you won't be needing it in the new plug.
    Once this red piece of brittle plastic is removed, you will then notice that the individual connectors are surrounded by some black plastic strips on the top and bottom, use two small flat screwdrivers to prise them apart and gently pull the individual cables from the rear of the connector - they will slide out fairly easily.
    Refit the cables in the right position on the new plug and slide the horseshoe shaped clip to lock the cables in position - job done!
    I wish I had taken some photo's whilst doing this little job but in all fairness it is pretty straight forward to do with a little patience. Hope it helps anyone who like, me hates broken bits that you notice every time you lift the bonnet up.
    Imteyaz.
    dany2k's Avatar
    Dec 2010
    Lancashire, England
    292
    would never, ever bother doing this but thankyou for taking the time to write it up mate
    Audi A3 8L 1.8T Quattro 180 in black. Totally standard: for now...
    S3 Nattie's Avatar
    Quattro ist für sissies
    May 2009
    Cardiff
    1,600
    Thanks alot for the guide, was really useful. The red plastic thing was completely messed up on mine and the black prong things holding the female connectors in were messed also. Only took 5 min and I didnt have the revised connector, bought a new original one.
    cheers buddy
    For sale
    3" Downpipe and de cat (will be going on ebay soon)
    Autogauge boost gauge
    Chrome Audi Number plate surrounds
    PM for info.
