EM TuningMonster Motorsport
    Dec 2010
    Newcastle-upon-tyne
    93
    Help please - aux belt tensioner
    I need some help, trying to refit my alternator. I can't get the tensioner into place. Its just too strong to move by hand. Is it broken or some sort of technique too it? edit: 1.8t agu.
    Aug 2010
    652
    there is a square bit on top. 15mm spanner and lever! there is hole to push an allen key through to hold it in place too
    Dec 2010
    Newcastle-upon-tyne
    93
    Where is the hole? After I move it slightly? I levered it with some mole grips, and snapped them :|
    Aug 2010
    652
    VWVortex.com - Ultimate Timing Belt DIY!!
    1.8T CAMBELT & WATER PUMP CHANGE including pictures - uk-mkivs
    hole is in side of square bit. have to lever quite a way and pull quite hard!
    May 2006
    Lancs
    211
    There is a hole on the side which when pulled with a spanner towards the front of the car will line up with the hole on the bit that is fixed. As mentioned before it's a doddle to do, there is a square shaped lug that sticks up.
    Dec 2010
    Newcastle-upon-tyne
    93
    Cheers guys, when I looked at it, it was obvious! Done now, and she's working great again
