Monster MotorsportVolks Autos
Results 1 to 16 of 16
Thread: Oil issue!!!
    broken down
    Penguin Pass Champion
    Feb 2011
    Perth, Scotland
    39
    Exclamation Oil issue!!!
    Ive got a problem guys, the oil light comes on and flashes at me and beeps three times(sometimes doesn't beep) and then goes off straight away or after a few minutes. This only occurs when i first start the car never when i am driving.
    The oil filter and oil were changed just a month ago. There are a couple of things wrong that i know of such as the dipstick holder is broken(held together with tape) and there is some kind of temporary fuel cap instead of an oil cap.
    Any ideas as to what could be wrong are greatly appreciated.
    John
    Audi A3 1.6 Sport
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    If the oil level is ok and there is no excessive noise from the top of the engine then it could just be the sensor John
    broken down
    Feb 2011
    Perth, Scotland
    39
    okay....where is the sensor? is that the thing plugged into the sump?
    Audi A3 1.6 Sport
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    Quote Originally Posted by skol View Post
    Most probably, not sure what it's like on the 1.6, just check to see if the plug is secure first
    What oil has been used? From reading your post again it seems like it's taking your car a few mins to build oil pressure, is the oil level defo ok, measuring correctly because of the broken dipstick??
    broken down
    Feb 2011
    Perth, Scotland
    39
    Its just 10w30 oil i think, pretty confident that there is enough oil in there. il just have a look and see if the plug is loose.
    If there is an issue with the oil pressure, will i need to buy a new oil pump?
    Audi A3 1.6 Sport
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    10w40? Does your engine sound a little noisey? Not sure if it'll be the oil pump, could be the pick up what's blocked
    What's the mileage on it?
    broken down
    Feb 2011
    Perth, Scotland
    39
    yeah 10w40, engine makes abit of noise when idling but nothing that loud. the mileage is 117000
    Audi A3 1.6 Sport
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    Hmm....if it keeps happening then it could be either the pump or pick up pipe. The sump will be off regardless so might aswell get both done
    Unless it's the actual sensor what's faulty
    broken down
    Feb 2011
    Perth, Scotland
    39
    so i should take the sump off and clean it all, and go from there?
    Audi A3 1.6 Sport
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    I would try the pressure switch first, and i would not drive it until you get your conclusion..
    broken down
    Feb 2011
    Perth, Scotland
    39
    Okay sound mate will give it a try tomorrow, hopefully that will be it.
    cheers guys
    Audi A3 1.6 Sport
    broken down
    Feb 2011
    Perth, Scotland
    39
    checked the pressure switch seems sound, never took it right off just made sure the wiring and connectors looked alright. just annoying it only does it sometimes so dont know whether to take it to the garage or try and isolate the problem myself. Ohhh the dilema!!!
    Audi A3 1.6 Sport
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    That doesn't mean it's working...
    Homer Simpson
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,385
    Fit a pressure gauge.
    TD5 Land Rover Defender build
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    l
    broken down
    Feb 2011
    Perth, Scotland
    39
    noted welly, il replace the sensor dont think they are very expensive anyways
    Audi A3 1.6 Sport
