EM TuningSky Insurance
    Jan 2005
    Hampshire
    7
    S3 rear beam bushes?
    Hi, I was reading in another post that upgrading the rear beam bushes is a worthwhile mod? Does anyone know how much this costs (roughly) including fitting and where I can get them from? And is it worth doing this if you've still got standard suspension? I'm looking at upgrading to eibach springs and anti-roll-kit with koni dampers eventually but this costs a load of money. I was thinking of getting the rear beam bushes done with a low strut brace in the meantime. Cheers. [img]/ubbthreads/images/graemlins/beerchug.gif[/img]
    Oct 2003
    up north...
    767
    Re: S3 rear beam bushes?
    bushes available from a variety of places, including forge and awesome gti
    cost about 70 plus fitting for both upper and lower tie bars.
    not worth it unless you are modifying the rest of the suspension, in which case you get 1 set with rear adjustable tie bars which you might get as part of a proper suspension setup
    Oct 2003
    up north...
    767
    i presumed he was talking about the rear upper and lower tie bars... maybe not though?
