Badger5Sky Insurance
Results 1 to 16 of 16
    imported_gek
    Video of S3 6th Gear Acceleration
    Following on from a post the other day about flat acceleration in 6th and the general "getting used to the speed" syndrome, I've become all paranoid so thought I would take a phone vid of me accelerating from 3000rpm in 6th.
    Does it seem normal? Slower than others?
    I would like to point out that the phone was wedged in the steering wheel, I had both hands on the wheel, and I was absolutely not on the public highway [img]/ubbthreads/images/graemlins/wink.gif[/img]
    Vid
    The file can be viewed in quicktime or windows media player I think.
    RAPS3's Avatar
    Moo Moo Land
    1,068
    Re: Video of S3 6th Gear Acceleration
    Cant get it to play in Windows Media, quicktime, or real player
    imported_gek
    Try this link
    May 2004
    UK
    115
    seem'ed slow.. but if your doing that speed would be in between 3rd gear and then 4th and you'lll notice the difference
    imported_monkeytrousers
    Not sure what you're trying to prove. What was the previousl link you mention? Cheers.
    Grant's Avatar
    Dec 2003
    Aberdeen
    1,110
    "gek"
    Has you car been chipped?
    imported_gek
    [ QUOTE ]
    [/ QUOTE ]
    The original link was a .3gp file, which some people won't be able to view, so the follow up is exactly the same file but converted to .wmv
    The purpose of it is just to ask people's opinions as to whether the 6th gear acceleration seen in the clip is normal for an unchipped S3, or whether it seems a little slow, compared to others.
    [ QUOTE ]
    Imola S3 said:
    "gek"
    [/ QUOTE ]
    It's not chipped mate.
    Grant's Avatar
    Dec 2003
    Aberdeen
    1,110
    If it's just standard, then it would appear normal.
    A standard S3 will not have the torque to pull in 6th at 3000rpm very quickly.
    What you doing driving at 3000rpm anyway... 5000-5500rpm is where it's at!
    StephaneS's Avatar
    Apr 2004
    Herts
    379
    seems slow to me even for a standard S3
    Sep 2004
    Central Scotland (where it rains alot)
    144
    Yes mate,
    appears to be a touch on the slow side.
    I would suggest trying the little rubber U shaped hose on the left hand side of the throttle body. If its all oily around this area the little hose is probably bust giving you a boost leak.
    Order a Samco 130 Degree hose 13mm for around 15. cut it to size and fit it. Takes around 20minutes.
    This is what was wrong with mine. Car felt ok around town upto about 4Krpm but crap on the m/way. Sound the same??
    Cheers,
    Stevie
    The Slug's Avatar
    Nov 2004
    UK
    1,853
    Like the lighsaber young luke, lol.
    May the force induction be with you!!
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,532
    Looks fine to me, the cars geared for 150ish mph, what did you expect between 70-90?, drop it a gear I say. [img]/ubbthreads/images/graemlins/devil.gif[/img]
    Sep 2004
    Glasgow
    919
    seems slower than my standard s3.
    As for pulling in 6th, i think somebody posted torque curves recently for a Standard s3 versus big turbos and there is torque at 3k to pull the standard car faster than that.
    fix the prob and you can still drop a gear and be faster [img]/ubbthreads/images/graemlins/wink.gif[/img]
    imported_gek
    Thanks for all the replies. I'll have a check for boost leaks.
    I've also been rather surprised by the fact that I can't get the average mpg to drop below 30mpg, which is too high I feel for the way I drive - 40 miles A roads, 70 miles motorway a day.
    Sep 2004
    144
    [ QUOTE ]
    [/ QUOTE ]
    Its you MAF mate. I had this problem too. Drove 600 mile trip to England and back and got 34mpg! nonsense! New MAF and if dropped to 24mpg mosdt times but the performance fairly improved.
    Deffinately this mate, I'd bet a whole 5.00 !
    imported_gek
    [ QUOTE ]
    Definately this mate, I'd bet a whole 5.00 !
    [/ QUOTE ]
    If I explain the symptoms to the stealer will they know it's the maf, especially if I there are no fault codes? Should I unplug it to force the fault code?
