JMB RetrofitsBadger5
Results 1 to 27 of 27
Thread: ESP Problems.
    Jan 2011
    Glasgow
    233
    ESP Problems.
    I've only owned my S3 for a month now and i'm sure some of the lights on my dash dont work. Plus i recon my ESP is not turning off either. Its defo working when i turn the car on and drive.... but ive never been able to turn it off. Ive tried countless times to hold the button in the time ive had it while stopped and running nothing.
    I've attached a video below.
    YouTube - MOV00800.MP4
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,520
    So it defo works and the esp light flashes on the dash when it cuts in??
    If you get no light when its blatantly cutting in id say the led or bulb has blown behind the instruments.
    If it does flash at you when it kicks in maybe the switch itself is nakered and needs taking out.
    Jan 2011
    Glasgow
    233
    No ive never seen it flash. I can feel it cut power though when accelerating and its wet. As you said it must be the led on the dash.
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,520
    Must be the light then mate. But next time, start it and press it just the once and see if its off by givin it some. Just to check
    Jan 2011
    Glasgow
    233
    You telling me to do illegal activities? :P i like it lol... i will check on some grass somewherei recon when i got time
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    It 'could' be that the previous owner has removed the bulb because the car has a yaw rate sensor that is dead
    Get the car scanned for faults
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,520
    Good shout sandip. Lets hope not, because that is SNEAKY!
    From Show... to GO
    Nov 2010
    Stafford
    436
    Take the clocks out,
    Id say 90% that there will be some black tape covering the ESP light. As it is prob on all the time.
    Thats what happened on mine, took the black tape off and it was on all the time.
    Turned out my MAF was dodgy, replaced it n all was well
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,520
    Your maf had the esp light on?? Really? I'd never had put the two together.
    Jan 2011
    Glasgow
    233
    The Cluster is slightly marked... like kinda cracked at the top right corner..... got me worried a bit now. How do i take them out? Why would they do that is it expensive to replace? what would of been broke to do that?
    Jan 2011
    Glasgow
    233
    I recon your right the about the YAW sensor. I've been reading it up it says brakes can seem like they are grinding and thats exactly whats happening to my car recently. I thought it was just a binding brake. MAN! they expensive? what and where i replace here?
    S3 Johnny's Avatar
    The grass isn't always greener
    Sep 2009
    Somerset
    230
    The ESP light is an LED bulb so it will be a nightmare to change, good luck with it sorting it tho
    S3 03, Ming Blue, Genuine RSTT's, BOSE, Sunroof, Factory Lowered, Centre Armrest, Greencotton filter, REVO, Forge 007p (Yellow Spring), Black DiamondDrilled and Groved Front Disks and Pads, Custom FMIC withYellow pipes SOLD
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Yep, Maf can throw the light on
    Jan 2011
    Glasgow
    233
    Is it dangerous to drive with a faulty or broken YAW sensor?
    Dane's Avatar
    Faster than a V12 Q7
    Cheltenham
    4,003
    dude the esp light should come on and go off with the other lights as you turn the engine on, so my thoughts echo that of the others either the bulbs gone (in one way or another) or there will be a bit of tape on the clocks
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    Before you remove the cluster try and get the car scanned for faults. Disturbing the cluster can sometimes ruin the DIS (displaying centre on cluster).
    A faulty yaw rate sensor will turn the esp off, i do that in my car as soon as a get in
    If you do remove the cluster be gentle, a display without any broken lines in it is something to be proud of
    Jan 2011
    Glasgow
    233
    Sometimes at slow speeds when i turn the diff seems to clunk! and on IGNITION my car makes a weird sucking noise at the rear continuously. Now every time i drive it seems like there is a pad rubbing against a disk....
    Feb 2011
    southampton
    229
    just been reading this thread and where do you get the led bulbs from and how do you fit them ..
    audi s3 2001 amk 210bhp, forge 007p
    Jan 2011
    Glasgow
    233
    Cluster LED bulbs are hard to replace you can send them away to Cluster Repairs UK - Instrument cluster speedometer repair, correction, modification and spares. for repair
    gavin89's Avatar
    Wana go Low gotta go Slow
    Bournemouth/Manchester
    214
    Quote Originally Posted by karls s3 View Post
    IIRC theres two type of instrument cluster. One with 2 plugs at the back, and one with 3 plugs (S3/1.8T). With the cluster opened up, the earlier ones pre 2001 are easily serviceble as the needles pulls off, and the front plate can come off which gives you access to the PCB. The LED is a SMT type, but size and brightness needs to be checked when its desoldered from the board. Late 2001 has needles which you cannot pull off, it is attached into a dial tube which clamps both top and bottom together, I have not found a way to get access into the PCB as it is plastic moulded. Procedure will be the same if you can get access.
    Gavin
    Feb 2011
    southampton
    229
    ok mine is a 2001 y s3 its got the 3 plugs in back green pink and white..
    gavin89's Avatar
    214
    If its pre facelift then you have a good chance your needles will simply pull off allowing you access to the PCB.
    Feb 2011
    southampton
    229
    are the bulbs just pushed into the board or soldered ect.. also any idea where i can get these bulbs i only need them for the esp light on clocks
    Feb 2011
    southampton
    229
    any one had to replace the bulbs in there clocks.. that might know the answer
    gavin89's Avatar
    214
    If you read me post above, I've already told you what they are...
    SMT LEDs soldered on.
    Feb 2011
    southampton
    229
    Quote Originally Posted by gavin89 View Post
    sorry mate where will i get these bulbs from
  28. #27
    gavin89's Avatar
    214
    Depends on what type they are...Try rapid electronics or RS components
