Hi Guys
I had the EPL light come up on the dash in solid state. Initially I thought it would go away once I switch the car off and on again. I was wrong and it stays on.
Got a mate of mine to plug the good old vagcom in - Found two faults. 1. 16825 - Evap Emissions Control Sys: Incorrect Flow - Intermittent. 2. 17704 - Error in mapped cooling system (Check temp-sensor and thermostat).
Can a dodgy temp sensor and stat cause these faults? My mate was telling me that if the temp sensor is nakard, then it can have an affect on your exhaust emissions. I've also noticed that sometimes when I have the car running for about 10 min - say going to the peti station, it will start fine but when I switch it off and then on again, it will struggle to start ...
What do you think guys??
