Badger5EM Tuning
Page 2 of 2 FirstFirst 12
Results 41 to 56 of 56
  1. #41
    SiGainey's Avatar
    Sep 2003
    North Wales
    475
    The only issue I have with it is I want to fit cruise and there's a fault code
    '01 AMK, completely standard except for the Ambient Lighting Pack.
  3. #42
    Whoever does not try, does not learn.
    Feb 2004
    Surrey
    193
    I find it bizarre how everyone is suffering from over-revving, as the symptoms were totally different to mine. When changing gears in either 1st, 2nd or 3rd the car will jerk or dip, and the only way to resolve this was to apply slight throttle (quite a bit actually!), and cruise control wasnt working i.e. wasnt disengaging when clutch pedal is pressed.
    Now that I have installed the new clutch switch and is adjusted correctly, everything seem to be working fine now - gear changes are very smooth, cruise control working too.
    Audi S3 (52) 265bhp Revo Stage 1
  4. #43
    Mar 2011
    Exeter
    90
    ive got a clutch switch coming tomorrow, was only 12 quid odd from tps so thought id give it a go, will let you guys know if i get any improvement, i hope so, haha.
  5. #44
    Mar 2011
    Warwickshire.
    246
    Mine does this too and did it before I had it mapped so I don't think it has anything to do with the cars being mapped.
    I'll change mine and see what happens, I might be lucky and it works but from what I have read here seems like it is just something we will have to put up with
  6. #45
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    You can log measuring block 66 i think and you can see it switching,,,mines switching fine, and still over revs every now and again...
    Ive just learned to live with it now and put it down to a quirk of the car.....
  7. #46
    Mar 2011
    Warwickshire.
    246
    All that logging stuff goes over my head lol but is something I must learn when I get a vagcom that is.
    I just let of the revs a second or 2 before changing gear and it's ok then but when I want to rag it it does my nut in. Might aswell not bother letting off the revs while gear changing lol.
  8. #47
    Inertiauk's Avatar
    Mar 2011
    529
    I have the same problem in my 1999 S3, my clutch switch is black, the one I replaced with with is also black. replacign it did nothign I still get the 'clutch switch signal implausable' error in VAG COM
    __________________________________________________ __________________________________________________ _
    Driving a 2004 B6 Audi S4 - Stage 2
  9. #48
    Dane's Avatar
    Faster than a V12 Q7
    Cheltenham
    4,003
    I had no fault code. but I also had to take one of my switches apart and put everything back together properly before it would work.
  10. #49
    Mr.G's Avatar
    Nov 2008
    In a Tardis!!
    1,302
    Guys...
    Have read all the posts above, and while i too have suffered with this problem mine (clutch position sensor) once replaced fixed the problem. It is a well known fact that 1 in 3 new switches are faulty, this information was given to me by two places, one by Audi (stealers) and the other by a well known tuning garage. If it were me I'd purchase 3 fitting each one till the problem disappeared, there is no way I'd be putting up with the over revs, I couldn't handle it when mine was like it, so god damn annoying it's just not funny.
    I'm not sure how much the switches are as mine was replaced by said tuning garage when my car was remapped.
    Good luck with your cars...sincerely hope you all get a resolution to what is one of the most annoying things about S3 faults.
    G
  11. #50
    Ryan_W's Avatar
    Mar 2010
    Stamford
    332
    It is a pain in the arse!
    I changed mine for a brand new Audi OEM switch and it still does it ever so slightly, it is better than before though...
    May buy another switch and see if it improves.
    '02 Audi S3 - 270bhp / 283lb ft - SOLD
    '08 BMW 135i - 306bhp / 295lb ft
    '12 VW Golf GTD 170 - 168bhp / 258lb ft
  12. #51
    Imteyaz's Avatar
    Oct 2008
    Warwickshire
    526
    Have a look on R-Tech's website:
    R-Tech remap offers and news
    Some interesting reading re: surging and how they have managed to map it out on AUM/AUQ engine codes.
    Could the S3's have a similar OE map / remapping issue? I have an R-Tech map on my AUM 1.8T and I have also changed my clutch switch for a new one - as I stated before, I have NO surging issues.
    Imteyaz.
  13. #52
    dancarpy's Avatar
    S3 DCY
    Jul 2009
    Manchester
    236
    My clutch pedal snapped yesturday
    just got my car back today and now i have the over revving problem which i didnt have before !
    so its something to do the way the clutch pedal is or the clutch switch and how it sits.
    it sometimes irratically over revs but then other times its fine. only drove it for 30 min tonight so ill see how it is againt tomorrow. :S
    VW MK4 R32
    Stage 1 Revo / Cold Air Feed / Miltek / AP Coilovers
  14. #53
    Jul 2010
    derbyshire
    36
    Did anybody manage to sort this issue out? Ive noticed mine does this. Completely standard AGU.
  15. #54
    Mar 2011
    Warwickshire.
    246
    Mine still does it now ffs, just used to it now :/
    A3 quattro Sport
    Forge 007p Pipercross panel filter R-Tech stage one map (213BHP)
    Oil catch can mod, SIA delete, EGR valve delete. Forge EGR delete plate.
  16. #55
    Feb 2012
    135
    Glad im not the only 1 with this problem!! Changed my slave and master yesterday and mines started it!! Up to 1k between 1st and 2nd then drops off through the rest of the gears!! Its fkin annoying and i have only put up with it for 1 day, god knows how u lot have been living with it! Mines a 2002 bam with cruise and is unmapped so as stated above it may well be down to these faulty switches!! New switch 2mz so will post if it cures the problem.
  17. #56
    vfr800's Avatar
    Feb 2012
    Melting Beans
    740
    Have you made sure the plastic stopper is still attached to the clutch pedal?
    S3 AMK 2002. Only 203 BHP left in my poor little engine, currently searching for the 7 missing horses.
    Mods: Powerflex bushes at the front and rear, 710P DV, ambient light module, Badger5 V3 TIP, S2000 Filter.
