AH FabricationsVolks Autos
    S3 TAM's Avatar
    Pocket now empty
    Oct 2009
    London & Hertfordshire
    621
    Boost gauge wiring
    Morning All,
    Just a quicky, does anyone know what fuse to connect the boost gauge wires too?
    so it turns on & off when the car does.
    Revo Stage 2 with all the Gear
    BHP = 274 / Torque = 293
    Welly's Avatar
    Testing dodgy Chinese gear...
    Aug 2009
    Gloucestershire
    10,680
    I normally use the switched ignition live in the back of the head lights switch. Use a test light to pin point the wire you want, then use some strippers to clear a small amount of sheath. Wrap wire around, solder, done. You can also use the earth from the same loom if needs be.
    Homer Simpson
    Wellyboots, you are quite literally my most favourite pikey in the entire world
