Badger5Chris Nott
Results 1 to 18 of 18
    Jun 2010
    London
    17
    Fitting B5 TIP!! but.....possible oil leak found....thoughts please!
    Just a few pics of my new B5 TIP.
    BUT....can anyone shed any light on the oil which seems to be over the turbo housing? has it blown a seal or something?
    Only noticed properly once id put the pics on the computer!
    Thoughts please.
    With 3' adaptor...
    Old and new....
    Done.....
    Dane's Avatar
    Faster than a V12 Q7
    Cheltenham
    4,003
    not sure on the oil but, ooooooh shiney!
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    It looks like your old tip has been leaking to me.....or rocker cover leaking
    S3KO4's Avatar
    Aug 2009
    London
    850
    could come from the rocker cover or a split breather pipe, I would have used some carb cleaner and cotton ear-buds to clean the compressor wheel first.
    S3-8L REVO stage 2, Milltek, 3" DP & custom 3" decat, RS2 spark plugs, 4 bar FPR, Green-Cotton uprated upper/lower boost hose & TIP, Front Zimmerman & Ferrodo. LCR spliter. boost gauge, smoothed AB. Aero blades, H&R 5mm spacers. Best time 14.03sec, 0-62 in 5.7sec. 207gs @ 25psi , polished inlet mani. VAGCOM 805.1
    RIP S3dave
    May 2004
    nr Glos
    7,157
    oil breather into your old TIP or the 1/2 moon thing looks like its leaked in the past
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
    Jun 2010
    London
    17
    Ok, when you say 1/2 moon thing, you mean the thing in picture 4, above and to the right of my hand? What is that?
    You may be right about the oil breather may have also leaked too, there was no jubilee on it when i dismantled it, and the hose is knackered too, going to source a new piece, all corroded plastic inside!
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,273
    Yes mate the half moon thingy is the Cam Adjuster Gasket. Mine went too and oil has leaked out. I paid about 10 for a new one but you'll need to get a rocker cover gasket too as that'll be coming off.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    G60DAN's Avatar
    Cornwall
    321
    I so want one of bills tip pipe
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Sorry to thread hop, but remember my old thread westle where i said i had a hole in my engine, you said it was the 1/2 moon gasket, well the gasket in the picture above is also leaking on mine but the hole is at the front of engine, not there, if that makes sense lol.
    Westy's Avatar
    Dec 2008
    17,273
    It'll either be the rocker cover gasket or the cam adjuster gasket. Keep an eye on the following thread as I'll be doing both gaskets this weekend and I'll put pics and info on here:
    Few jobs for this weekend.
    S3 Build Thread
    s3matthewd's Avatar
    Jan 2011
    79
    sorry to thread drop but how much is it for the b5 tip and would i need any other parts swapping from a forge tip thanks matt
    RIP S3dave
    May 2004
    nr Glos
    7,157
    162+vat and delivery - so I've heard
    bill@badger5.co.uk
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Quote Originally Posted by Westle View Post
    Think it's going to be easier, haha. I'll keep an eye on it pal.
    Jun 2010
    London
    17
    Cheers mate, will do.
    Thanks for the advice, have ordered new rocker/cam adjuster gaskets anyway as it looks like that is definitely a leak!
    Westy's Avatar
    Dec 2008
    17,273
    Quote Originally Posted by tjkherz View Post
    Get all these parts mate as its good to replace old gaskets if these parts are coming off and they're cheap.:
    Rocker cover gasket: W058 198 025 A 18.15
    Cam adjuster gasket: W058 198 217 5.52
    Inlet manifold gasket: W058 129 717 D 3.05
    Throttle Body gasket: W028 129 748 1.83
    "Blue" gasket seal. From any motor place. The sealant needs to be put on the blue parts of the adjuster gasket.
    You will also need some rocker cover studs (haven't got part numbers to hand). There's 9 in total 5 small ones and 4 large ones. The small ones are 40p each and the large ones 50p each and it's just incase you snap any of the studs when doing this job.
    I will say that it is a bit of a daunting job as you get the rocker cover off. The best way to do the adjuster gasket to to loosen off 3 bolts on the VVT unit and lift the unit up to slip the old gasket out an the new one in. The Audi workshop manual suggests removing the front cam to slacken the chain but this isn't neccasary plus if you remove the cam you will need to put it back in the same position or it's bye bye valves!
    S3 Build Thread
    S3 TAM's Avatar
    Pocket now empty
    Oct 2009
    London & Hertfordshire
    621
    Westle i think we need to open up a cam adjuster fixing garage. Lol
    Revo Stage 2 with all the Gear
    BHP = 274 / Torque = 293
    Westy's Avatar
    Dec 2008
    17,273
    Quote Originally Posted by S3 Baby View Post
    Now there's a plan. We just need to remember to connect up all the sensor connectors afterwards so we dont scare the ****e out of the car owner when it doesn't start properly
    S3 Build Thread
    KB
    KB's Avatar
    Jul 2010
    Inverurie, Aberdeenshire, United Kingdom
    195
    ive got a leak in the same area, noticed on sunday when i took the gearbox out, engine is a bit oily and the side of the turbo has a spray of oil on it like in the photos.
Tags for this Thread
