Sky InsuranceChris Nott
Results 1 to 16 of 16
    Jan 2011
    staffordshire
    7
    Tip fitting K03s
    Need abit of advice. Currently running a AGU engine K03, Booked in next week to have K03s,tip and de cat downpipe fitted then re mapped again. Im no mechanic but when I offer tip to turbo it does not seem to connect to k03s, is the k03 slightly different? here is the link for the tip i brought
    VW GOLF MK4 1.8T 20VT SILICONE TURBO INTAKE PIPE AGU on eBay (end time 16-Mar-11 22:23:05 GMT)
    Do I need to buy another tip? before car goes in garage or is there a way to get this to fit
    BENJAMIN's Avatar
    Mar 2011
    472
    That tip is for the k03, the k03s requires a different tip as the intake diameter is bigger. Buy a tip for an 'aum' or 'auq' engine code.
    Jan 2011
    staffordshire
    7
    Are you sure this states k03s on e bay site, but if intake diameter is bigger then this is why it does not connect, looks like a refund
    BENJAMIN's Avatar
    Mar 2011
    472
    Just read the description, he lists it for the agu and arz engine code that are both k03 equipped. He says it fits the k03s, but if it fits the k03 it won't fit the k03s as the intake is a fair bit larger tbh. Hth dude.
    Jan 2011
    staffordshire
    7
    Thanks for all your replies, im going to email seller and swap for the aum tip he also has listed, is there any difference on this tip other than diameter for turbo inlet
    BENJAMIN's Avatar
    Mar 2011
    472
    No problem mate. Im certain that they're identical except for the turbo inlet diameter. I've done a few agu/k03s conversions and dont ever recall having any issues with the tips being different in any way except for diameter.
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    The difference between the inlets is minimal, that should stretch over with no problems. I had that exact TIP on my AGU K03S engine.
    Homer Simpson
    DaveA3's Avatar
    Audi A-Trizzle!
    Milton Keynes
    2,378
    yeh was gonna say bill said it was a couple of mm. could always cut a bit off
    Audi A3 1.8T Sport (AGU) - 2000
    Engine: Carbonio CAI/Jetex JR Hybrid Induction, Forge 007p DV, Forge TIP, Longlife S/S Custom Exhaust system, R-Tech Stage 1 Remap, Creation Motorsport Boost Pipe Kit.
    Exterior and Chassis: 18" Cades Tyrus, Euro Wipers, low on JOM Coilovers, Eibach Front & Rear ARB's, Black Angel Eye Headlights, 6000K HID's, S3 Brakes.
    For Sale PM ME - £2500 Mods Inc
    666markyboy's Avatar
    Mar 2008
    Oldham, Manchester
    1,110
    If i remember rightly what Bill said was that the oem TIP's from Audi are indeed different because of a difference in size but if you are fitting a silcone after market job you should be fine as they have a bit of give in them .... i need to find a tutorial on changing these as i've had a Samco TIP sat in the garage for the best part of 2 years waiting to go onto my K03 or KO3s (still dont know whats fitted ) do you have to get under the car to fit them ??? it looks awfully tight down there
    1999 A3 Quattro 1.8T Pics >>HERE
    2002 A4 Avant quattro 1.9 TDi
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Its not has bad as it looks, all from the top....
    Apr 2010
    Widnes Cheshire
    404
    There is a link some where to a step by step guide, with pics, to fitting a new TIP, im not sure if its on here or another VAG site. I have it on my Laptop but unfortunately it crashed to day and im having probs getting back into it, im on my NoteBook at the moment. Ill post it to you if i can get back into my Laptop.
    The guide was how to do it from the top without getting underneath the car.
    DC
    His: 2001 1.8T AUM. Hibiscus Red Pearl Effect - Hers: 2002 1.8T AUM. Metalic Silver.
    Apr 2010
    Widnes Cheshire
    404
    Search on here: How To Fit Tip
    DC
    Jul 2010
    bristol
    647
    What engine code do you have? Fitted my forge tip to my 99 a3 quattro a few weeks ago and it took less than 30 mins, very straight forward but securing a jubalee clip to the base where it connects to the turbo was sooo fiddley! Made a noticable difference though.
    Mar 2008
    Oldham, Manchester
    1,110
    Engine code is AJQ which seems to appear more in the TT's..... got 7 days of shifts to work now but i'm gonna fit it next week... silly for it to have been sat there all this time
    Mar 2008
    Oldham, Manchester
    1,110
    Couldn't find a guide on here but came accross this usefull one with good old Google
    OVD - Ottawa Vdubbing - View topic - Mk4 Forge Turbo Inlet Pipe (TIP) Installation
    Jul 2010
    bristol
    647
    So thats a ko3 unless its had an s fitted at a later date. Good luck with it, it honestly is simple. Dont waste your time trying to get to it from under the car, it didnt look possible to me
