AH FabricationsBadger5
Results 1 to 18 of 18
    May 2006
    Lancs
    211
    S3 missfire after head refit.
    I recently had the timing belt go on my AMK S3. I've now got it all back together but there seems to be a missfire, mostly at low revs seems to clear when at higher revs. I do have the engine light on.
    When I got it home I took the oil filler off and a fair amount of smoke escaped. Have I done something severely wrong here, timing out etc, or do you think it could be blocked breather pipes with the build up of smoke in the head cover?
    Coilpacks and plugs were fine before belt let go so I think it's unlikely to be them and much more likely to be related to the head being off.
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    sounds like you may have got the belt a tooth out ...easy mistake
    beachbuggy's Avatar
    Surrey
    1,744
    Did you remove the head? the title says you did but the post says the cambelt. If you removed the head it could just have oil in the water gallies and vice verse. This would cause the smoke/pressure in the cylinder head. If you have a misfire, could either be a bad coil pack or yes a tooth out but unlikely if it's fine when the revs rise.
    Do you have oil in the coolant?
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    His belt snapped so it was not HG failure, get it on the computer
    May 2006
    Lancs
    211
    Yes the head was off. I've refilled the coolant and noticed a small film in there, I assumed that was just because some mixed together in the bottom end when I took the head off, is this possible?
    Initially I did have the belt a tooth out but it was never turned over like this, I noticed that when I put the lower belt cover back on that the marks on the pulley were not quite in line so I sorted that. When the revs rise it sounds fine again, it's a noticeable vibration at idle and worse at about 1500, then starts to clear.
    I had a bit of white smoke from the exhaust at first but that seems to have cleared as the engine began to warm, it's times like these I really wish I had a laptop and VCDS!
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    PM me where abouts in Lancs you are David, wouldn't mind having a look at it for you if you want?
    Did you get the head pressure tested whilst it was off?
    May 2006
    Lancs
    211
    Yes, the head had the bent valves replaced, pressure test and skimmed.
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    Quick check to see if the head may possibly be cracked is to pour some red food colouring into the expansion tank, run the car for a while, let it tick over if it can, turn the car off and then pull each spark plug out one by one. If the white ceramic is pink you've got coolant getting into the chamber.
    Very slim chance this could be the issue but it's a simple check to rule it out
    S3 Nattie's Avatar
    Quattro ist für sissies
    May 2009
    Cardiff
    1,600
    The head shouldnt be cracked if it was pressure tested.
    As you got the EML, your likely to have the incorrect correlation fault code. I had it when I put my engine back together, basically the timing is out and the crank and cam are not in sink. Get it on the computer and see what the code is before you do anything else.
    For sale
    3" Downpipe and de cat (will be going on ebay soon)
    Autogauge boost gauge
    Chrome Audi Number plate surrounds
    PM for info.
    May 2006
    Lancs
    211
    Why would the timing be out? I set it up with the marks on the cam cover and bottom belt cover, aswell as manually setting no1 to TDC. I'm not disputing your theory, just wondering why it would be.
    S3 Nattie's Avatar
    May 2009
    Cardiff
    1,600
    I done the same when I done mine and thought it was all aligned right but it was out very slightly and got a incorrect correlation code come up. Did you look at the mark on the gearbox too as I found that was easier to use instead of the crank.
    Need to see the fault code you got really as I could be something completely different to the timing etc. Im just going by what happened to me when I did my timing and had a fault code come up straight away.
    For sale
    PM for info.
    Aug 2010
    bradford
    1,252
    i had simler prob when i had my timing belt changed the timing was out after they sorted it light went off but did not have no smoke pal
    350bhp & 316ftlb BBT new k16 7+7 blade hybrid turbo, Welly cooler, jetex filter, relentless ported v3 manifold 3" downpipe & de-cat, liquid gauge, r32 rear arb, AGU ported and polished Head, 550cc injectors, kw v2 Coilovers, s3dave tie bars & heat sheild, milltek cat back, I.E forged rods, brembos, inline fuel pump, v3 badger 5 tip, devils own WMI kit, AGU pistons, rear grooved discs & brembo pads, ds2500 pads & EBC ultimax disc, stack boost gauge
    May 2006
    Lancs
    211
    I think the smoke was probably just a bit of oil and water that had mixed together when the head came off, it's the lumpy idle and engine light that's really bothering me.
    Where is the gearbox mark, I couldn't seem to find that, that's why I used the old fashioned way and double checked off the crank pulley mark.
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Guess work mate, get the codes logged instead of tearing your hair out, there will be somebody near you with vagcom... do a shout out...lol or if you can come to leeds/bradford i will do it for you.....
    May 2006
    Lancs
    211
    Sandip kindly offered but I've only just got back and I'm out all day tomorrow cos it's my 30th! Looks like I'll have to take it somewhere and get it scanned on Monday, fingers crossed it's nothing too serious, I can't face pulling it all apart again!
    May 2006
    Lancs
    211
    All sorted, had a miriad of codes at first but I guess that was from when the belt went, cleared those and it showed a misfire on no4. A trip to Blackburn Audi and 4 new free coilpacks later it's running better than ever. So chuffed it was nothing serious, I'd worked late nights all week putting it back together, I don't think I could've faced taking it back in bits!
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Well done mate, glad your sorted...
    RIP S3dave
    May 2004
    nr Glos
    7,167
    coils dont like being disturbed.. fragile inside when baked on top of the very hot rocker cover
    NEW NEW NEW eShop now LIVE>
    www.badger5.biz
    bill@badger5.co.uk
