Monster MotorsportEM Tuning
Thread: rough idle
    s3matthewd's Avatar
    Jan 2011
    79
    rough idle
    hi could anyone tell me what the three way valve is that sits under the inlet manifold on the bam engine seem to have blown the end clean out of it on my car eml is now on guess its due to this fault
    beachbuggy's Avatar
    Surrey
    1,727
    I guess you're talking about the PCV system? One end comes off the inlet manifold, other end goes into the oil cooler and the 3rd goes to the hockey puck? It's part of the vacuum system, which draws pressure from the cylinder head and oil cooler, removing fumes etc , basically the breather system for the engine. If this has a leak then it will almost certainly cause rough idle as extra air is drawn into the manifold, also if it's blown before a one way check valve then you'll have a big boost leak. Either fit a catch can setup, a silicone replacement or buy a new set of pipes from audi.
    s3matthewd's Avatar
    Jan 2011
    79
    it actually blew the cap out of the one way valve would a new part fix this or would i be better going for a catch can setup
