Results 1 to 10 of 10
    May 2010
    19
    s3 full boost problem
    hey guys
    few days back had a coil pack go down so did the decent thing and replaced all 4(gsf coil packs)
    been driving it around for a few days fine
    went out for a lil spin last nite was running supurb all nit untill at the end of the nite it developed a problem seems to be down on a bit of power through rev range and when on full boost it wot i can discribe as hit fuel cut / miss fire.
    runs perfect up2 about 1.2 bar boost then this problem happens
    any1 had this problem or can fink ov anything iv missed to look at ?
    its recent plugs fuel filter coil packs im stuck please help! Thanks Dave
    May 2010
    19
    iv done some research seems on the AGU's the ignition module is common am i rite in saying mine dosnt have 1 (apy) ?
    any help would be appriciated im stuck !!!
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    APY does not have the module correct mate..
    BENJAMIN's Avatar
    Mar 2011
    466
    What plugs did you fit? NGK PFR6Q are the correct ones. The plugs are more than likely where your issue is. hth.
    May 2010
    19
    fitted new bosch super plus fr7kpp33+ today made no difference
    i cnt work out wot it is
    BENJAMIN's Avatar
    Mar 2011
    466
    Hmmm that's an odd one. I once had an issue with a new set of Gsf coilpacks on an apy overheating and a sticky spooge coming out the top of them. Maybe try a mates coilpacks to rule it out?
    s3 Hoggy's Avatar
    Whats going on???
    Apr 2009
    Oxford
    1,653
    Visit s3 Hoggy's Instagram Channel
    sounds like the exact problem I had mine was a coilpack that only misfired under full load. Did you keep your old coils? If you can get it scanned on vcds, if not then maybe you could try swapping one of your old coilspacks on each cylinder see if it goes?
    2002 S3 REVO
    Milltek, Sachs Organic clutch, 007p, Genuine RSTT's, BBS RS2's
    Koni FSD & H&R springs, Neuspeed 22mm rear ARB, KW tie arms
    LCR Brembo's with DS2500's & Paul's 300mm Rear disc kit,
    Michelin Pilot Sport 3's,Badger5 V2.2 Jetex filter & heatshield
    May 2010
    19
    done it all lol bloody car i have a feeling its fuel related
    its going back up 2 badger 5 on thursday nite so hopfully have result from that
    Thanks for the replys tho
    Dub16V's Avatar
    Nov 2010
    Leuven, Belgium
    i had the same problem.
    Water was coming in thru secundairy airpump.
    disconnected the hose on the airbox and covered the hole-> problem was solved.
    "without the people, the cars are just soulless objects" mike london
    May 2010
    19
    im running aftermarket air filter (no airbox)
    it really is a strange 1
