Monster MotorsportChris Nott
Thread: Ecu swapping
    Turboman-a3's Avatar
    speed thrills
    Apr 2010
    portsmouth
    153
    Ecu swapping
    Hi gents I've managed to obtain a remapped ecu that was mapped by amd on a golf agu with very similar mods to my agu a3 now am I nieve in thinking it will straight swap if not I've heard it can be linked to my car via vagcom but that's out of my league what do u guys think?
    Optimum Tuning's Avatar
    www.optimumtuning.co.uk
    Nov 2010
    37
    Quote Originally Posted by Turboman-a3 View Post
    The car will not run with this ecu as the keys wont match immo data in the serial eeprom. You need to swap the serial eeproms over or make the ecu run immo free by changing the immo data in the serial eeprom and dont attempt it yourself with a normal soldering iron!
    Also is the ecu bosch part number the same?
    2001 S3 8L, CR Turbos hybrid k04, Forge DV, silicone TIP,BBS LM reps.
    Nov 2010
    37
    I think You would need key skc pin code to do with vag com
    beachbuggy's Avatar
    Surrey
    1,739
    Yes it can be done. Either you need to immob defeat the ecu which will disable the immoboliser on the new ecu or you can re-sync the keys to the new ecu and immob. To do this you need the SKC code, which if you don't have you'll need vagtacgho or similar to get the code. Not really necessary to remove the serial eeprom as it can easily be got via the obd port. Once you have the skc, you can recode by using the same vagtacho software but I've found it a little flakey, where as it's a doddle with vagcom, although you have to have a full version to be able to do it.
    To be fair it's not a difficult job the only problem arises if you have an immo3 but as you have an AGU I very doubt you don't. If you're local to me I'd happily to help.
    speed thrills
    Apr 2010
    portsmouth
    153
    Ah I see I don't have any vagcom and cheers beachbuggy I'd happily travel to you or anyone who could help it will hopefully be here around Monday if anyone can help cheers guys
    speed thrills
    Apr 2010
    portsmouth
    153
    So is there anyone with vagcom and the the savvy that can help a dude out? for a drink of course il travel to you plzzzzz
