    gareth_oau's Avatar
    Dec 2008
    Perth, Australia
    216
    unusual vibration in S3?
    my car has developed an odd, very intermittent vibration.
    Happens about once or twice a week, typically when I pull in to a stop and turn off the engine.
    I feel and hear this obvious vibration through the clutch pedal, but it continues after I've taken out the ignition key and even without my foot on the clutch.
    Typically it will last around 10 seconds or so.
    It has rarely done it whilst I've pulled up to stop at say traffic lights, but not turned off the engine.
    Yesterday, as i pulled up the driveway, my son was there, and the vibration continued for around 30 seconds and he said he could hear and feel it through the radiator grill.
    any thoughts?
    (its booked in for an investigation!)
    2007 RS4
    2000 S3 APR'd
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,061
    It could be the after run electric water pump,
    chris99's Avatar
    s3 driver
    Dec 2010
    54
    don't think it's the water pump dave... vibrating through the clutch pedal??
    it's normal to hear the sound from the water pump cooling the turbo and lasting longer than 30 seconds, but only when you turn off the engine and no vibrations
    Audi S3 8L
    OZ Superleggera | Bilstein B14 | BMC CDA | K04 | FMIC | SACHS Race Engineering | Brembo Sport GT | EBC Redstuff
    Live to drive, drive to live
    Chugger
    North Devon
    2,716
    maybe its jammed and is humming, i cant see what else it could be. The pump is the only thing that should comtinue once ignition is off. If you cant hear it pump properly you can hit it to clear any corrosion of the contacts
    57 A3 2.0 TDI Sportback (140)
