Volks AutosMonster Motorsport
Results 1 to 8 of 8
    105
    HELP PLEASE GUYS.I HAVE A MISSFIRE
    Hello guys can you please help me to find out whats goin on with my s3.I changed some vac pipes over the weekend and also just took out cylinder no1 coilpack off to see if it was a vag one for the recall.
    When i put the new vac pipes on i started the car and drove of to the petrol station just cruzin.when the vehicle got warm a floored the vehicle heard a pop then the vehicle started to missfire.any ideas
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,465
    one of the vac lines may have come off
    or a pack failed
    did you have any lights on flashing ?
    105
    I have checked all the vac pipes dude loads of times and the one i changed was the on the side of the manifold that goes to the brake servo ect on the left and side
    Feb 2011
    Essex, South
    97
    I've said this in a couple of threads. My 1.6p A3 had a heavy misfire and after chaning the coil pack and plugs (a right pain too) it turned out the be the HT lead itself.
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    Quote Originally Posted by TheButtonz View Post
    S3's don't have ht leads
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Did you make sure the coil was fully seated? not unheard of them to pop up if not the bolt down type....
    Feb 2011
    Essex, South
    97
    Quote Originally Posted by sandip View Post
    Ok. That finally confirms it. I know F all about cars...
    I thought all cars with coil packs did. Consider my comment withdrawn! (slicks backto my A3...)
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    I thought all cars with coil packs did)
    lol I wouldn't say that bud, you cured your missfire on your 1.6 by changing the leads, the 1.8T's have a wiring harness/coilpacks instead of ht leads
    Some 1.8T's conversions do run ht leads but they'll have different engine management
