Volks AutosBadger5
Thread: ABS Light....
    Jan 2005
    ABS Light....
    i have an audi a3 97 1.6. My problem is that when i touch the brakes a bit the ABS light just flickers a tiny bit. Am guessing my ABS isnt working because of this. Ive recently changed the front brake discs and pads + coolant temp sensor + replced the driverside rear ABS ring (i could hear a whirring sound coming from that side, turned out to be the ABS ring gone loose).
    Has anyone else had a simluar problem? Could anyone explain why it does that??
    Thanks!
    Apr 2004
    58
    Re: ABS Light....
    I had a similar problem only my ESP light was coming on and staying on.It turned out to be a malfuntioning switch.
    16955 - P0571 Brake Switch (A) Circuit malfunction.
    that was the error code.
    I have also heard of this being caused by dirty contacts on the switch.
    imported_Skywalker
    Re: ABS Light....
    Octagon,
    I have exactly the same error code on mine. It started today.
    How did you fix yours?
    Booster
