Chris NottSky Insurance
Results 1 to 12 of 12
    Dec 2010
    Essex
    16
    Temp gauge not working? '98 A3 T Sport
    Hi,
    Not had the car long but i have noticed my water temp gauge does not seem to work / does not ever move off the bottom. Any advice for common faults or what to check?
    Cheers in advance.
    Martin
    Dec 2010
    Newcastle-upon-tyne
    93
    If its anything like mine, its the thermostat stuck open. Have you let it tick over on a warmer day for 15 minutes to see if it gets warm?
    CHRIS555's Avatar
    DOPE with added OCD
    Jul 2010
    Midlands
    1,941
    Extremely common fault on all VAG cars - 99% sure it will be your TEMPERATURE SENSOR - I changed mine a week or so a go and only with i'd done it sooner - more MPG and more power!
    You can buy the sensor from a dealer for around 20-30 - make sure you get the clip and o ring with it (they will know what they are) or you can get them of ebay cheaper - audi a3 temperature sensor items - Get great deals on Vehicle Parts Accessories items on eBay UK!
    This is such a common fault that most dealers keep them in stock all the time.
    When mine went the needle just did not move. It will be giving your MAF funny readings and most likely running rich (using more fuel) and losing a little power. Well worth a few quid trying this.
    Dec 2010
    Essex
    16
    cheers for the replies
    Quote Originally Posted by Ian_83 View Post
    Will try that if and when we get a warm day. I let the car tick over for ages when i bought it and it didnt move
    Quote Originally Posted by CHRIS555 View Post
    Sounds like the symptoms i have as the maf is giving odd readings. Looking through the history the car has had a recent maf and thermostat. There are also receipts for green and blue temp sensors (and also a credit note for the green so perhaps returned unfitted?). At that price though, i may just try them anyway.
    Martin
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,064
    It is the green one that is more reliable
    Dec 2010
    Essex
    16
    Is there any way of telling which I need or do you reckon its best just to change both?
    cheers for the advice
    Welly's Avatar
    Testing dodgy Chinese gear...
    Aug 2009
    Gloucestershire
    10,680
    Quote Originally Posted by martinb! View Post
    Change both the stat and the sensor. Remove all possibilities.
    Homer Simpson
    Wellyboots, you are quite literally my most favourite pikey in the entire world
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,934
    Or perhaps just diagnose the problem properly and only replace the part thats broken. I know its only a 20quid part, but its the thaught process behind just randomly throwing parts at a problem that really pisses me off with modern "mechanics".
    Give the car a run, then park up and leave it idling for 10mins. If the needle starts to climb then change the thermostat. If it doesnt, its probably the sensor.
    If you have climate control, you can view the current coolant temperature on there, which will give you an idea. Hold recirc, and press up, display should change to "1c" use temp control +/- to make the display read 49c, then press recirc again, and the display will show you the current coolant temp.
    Do that with the engine cold and you'd expect to see ambient temperature, 5-10c or something, and it should then start to climb as you drive it. You'd expect to see 90c within about 5-10mins of driving. If the thermostat is away, it will climb slowly, will level off at some low temperature, and will fall the faster you drive.
    TD5 Land Rover Defender build
    Welly's Avatar
    Aug 2009
    Gloucestershire
    10,680
    I disagree - if it were me I would be replacing both parts. I don't see the requirement to avoid 'throw away mechanics' when it makes the water temperature management system on the car more future proof.
    You are simply pre-empting failure of a part which is known to fail.
    Still, each to their own.
    Homer Simpson
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,167
    I like to change as much as possible but that's just me. I'd rather change both parts now and avoid having to do 1 part now and another part a few months down the line!
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    Dec 2010
    Essex
    16
    I'm not a mechanic by a long stretch and dont really know my way round these engines well yet so any advice is appreciated, thanks again for all your replies.
    Cheers, I have climate control so will give this a try tomorrow.
    Dec 2010
    Essex
    16
    right tried this today and it kooks like I may need to change both then. On the climate the display went up pretty slowly to about 48/9 but no higher yet when left on tickover for 10min+ the needle did not move at all.
