Sky InsuranceJMB Retrofits
    Aug 2007
    199
    Trim question - rear bumper
    I am not sure what it is called, but the black plastic trim that attaches to the top of the rear bumper (S3) and is covered by the boot lid when its closed - there is an 8mm x 1mm strip of double sided adhesive/rubber which holds the trim to the bumper.
    Does anyone know if this comes with the part or is it a separate purchase? What alternatives could I use in its place? I have found plenty of foam double sided tape but I am dubious as to their strength.
    19scotty81's Avatar
    Push down and across !!!!!!!!!
    Dec 2010
    Newcastle Upon Tyne
    107
    This comes with the part, it's always been a pain in the arse to re-stick since they first came out, we always try to replace them but i've had mixed results using different types of double sided tape,glues and tried a set of number plate sticky pads which worked quite well. If you want it mint replacements the best option although i'm not sure how much they are !!
    2004 A4 Avant
    Akoya Silver | 2 Graco Car Seats | Buggy In Boot |
    Aug 2007
    199
    Quote Originally Posted by 19scotty81 View Post
    Cheers for the update! I have found some performance tape but just waiting on a response as to how thick it is.
    Aug 2010
    652
    3m tape. Amazing stuff
    Aug 2007
    199
    Quote Originally Posted by steve bain View Post
    I will check their range - cheers
