Sky InsuranceAH Fabrications
Results 1 to 22 of 22
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,235
    Draining and flushing coolant system......
    Off work thursday so i think im going to have a crack at fitting my new coolant bottle and thermostat but.
    Whats the best way to drain the coolant system? Been told there's a drain off at the bottom of the rad on the passenger side! Ive had a look but cant see and havent got a clue on how to get to it! Any help?
    Also id like to flush the system out. Whats the best way of doing it? Shoving a hose pipe into the coolant bottle and just let it run out of the draining plug at the bottom of the rad?
    Cheers .
    S3 MRU's Avatar
    Aug 2010
    Luton, Bedfordshire
    756
    My brother works at kwik fit they have machines that extract the coolant and insert new coolant. Dont know how it works but its not expensive at all
    Audi S3 8P2 Silver
    BI-Xenons - FBMFSW - Rain/Light Pack - Auto dim package - iPod Integration - 2011 Nav - Electric Folding Mirrors - Rear Park Sensors - Full Heated Leather - BOSE - Privacy Windows - 2011 Console Conversion - My11 Rear Lights - RevD Diverter - Forge DMV14T BOV - ITG Maxogen CAI - BBS CH 18s
    SiGainey's Avatar
    Sep 2003
    North Wales
    475
    The drain is REAL easy to find - get your head under the car and look at the radiator, you'll see a black knurled piece of plastic that you just pull out towards the back of the car then turn the plastic about 45 or 90 degrees and the water will drain out the bottom of the rad. If you're doing teh thermostat too, it would be worth removing the stat, flushing the system with water (via the header tank) till it appears clean from the bottom of the rad. Then leave the stat out and fill the system with water again and run the engine for a minute to pump round and get all the old coolant out. Then just drain and fill with coolant (bearing in mind, there may be more water than coolant left as you can't drain it all)
    '01 AMK, completely standard except for the Ambient Lighting Pack.
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,235
    So i just need to get my hand under the passenger side of the car and i should be able to feel it, can you see it from above or is it just touch and feel?
    From Show... to GO
    Nov 2010
    Stafford
    436
    Its on the bottom right corner of the radiator, looking from the front.you cant miss it if you look.
    Did mine yesterday and fitted my new coolant tank.
    SiGainey's Avatar
    Sep 2003
    North Wales
    475
    You can only see if from below really
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,235
    So if i popped my head under id be able to see it? Just asking as its a bit dark togo out and look lol.
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,235
    Argh right. no worries, cheers lads.
    Jonesy's Avatar
    Jun 2004
    Kent
    570
    Hi, i'm thinking of flushing my coolant and fitting a new thermostat 2moro. Quick question, I know you cant mix the coolants with other coolants but once its flushed can I put any bog standard one in or does it still need to be that g12 stuff.
    Dani_B19 did you manage to get yours done ok, did you come across any problems?
    Allan
    2001 Audi S3 - Facelift - Revo remap - Forge 007p DV - BMC Panel Filter- Type R Ariel - Aero wipers - n75j valve.
    May 2006
    Lancs
    211
    Audi clearly state G12 or equivalent so I'd stick with that, they are on G12++ now, about 8-9 from the dealers.
    Apr 2010
    Widnes Cheshire
    404
    Whats the recommended ratio G12 to water?
    DC
    His: 2001 1.8T AUM. Hibiscus Red Pearl Effect - Hers: 2002 1.8T AUM. Metalic Silver.
    May 2006
    Lancs
    211
    2 parts G12 to 3 parts water
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,235
    Didnt manage todo it jonesy, ended up re-piping and fitting new oil catch can that turned out tobe a right pain in the arse.
    finesse's Avatar
    Aug 2006
    London / Anglia
    2,814
    whatever happened to quite Sunday afternoons?
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,235
    There too boring thats what .
    Apr 2010
    Widnes Cheshire
    404
    Quote Originally Posted by DavidW View Post
    Ok, thanks for that
    DC
    Jonesy's Avatar
    Jun 2004
    Kent
    570
    How much g12 will I need once ive flushed the system? you dont need to remove the bumper to get to the plug do you?
    Many thanks
    Allan
    Apr 2010
    Widnes Cheshire
    404
    5 ltr according to Haynes....... and nope.
    DC
    Jonesy's Avatar
    Jun 2004
    Kent
    570
    Thanks for the help, managed to get mine done the other day, plug was fairly easy to get to, had to remove some of the plastic covers underneith to access it, turn it 1/4 turn anticlockwise then pull forward and the coolant flowed out pretty quick. Also changed my thermastat and removed whatever coolant was in that area. Topped up with 2 bottles g12++ from dealer and used deionised water from halfrauds. Temp gauge now works a treat and sits nicely at 90c also my heaters in car are so much better, especially when clearing the screen!
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,533
    do you have to use deionised water??
    SiGainey's Avatar
    Sep 2003
    North Wales
    475
    Nope, its not mandatory if you don't live in a hard water area. If you do, just boil a few kettles of water and let them cool down and use that water
    Jonesy's Avatar
    Jun 2004
    Kent
    570
    Im not sure to be honest, my friend told me normal 'hard' water can still contain chemicals that can damage the inside of the radiator. Could be nonsense but it was only 3 quid for a 5l bottle. Plus it says on bottle recommended for coolant systems/batteries/air-con systems.
