Badger5Chris Nott
    MikeA3's Avatar
    Mar 2005
    Epsom
    1,176
    S3 Brake Issues.
    Hi All,
    I had a bit of a close call the other night on the motorway which has got me thinking something's not 100% with my brakes at the moment.
    I had to stop very quickly from motorway speeds and when I pressed the pedal it was almost like the brakes had failed somehow. They worked well initially but after a few seconds it felt like they just stopped applying pressure to the discs and I could hear what sounded like a grinding noise coming from the fronts.
    The car's had new discs and pads alround in the last thousand miles and the system's been bled so it's got new fluid in there as well. Apart from the really squeaky DS2500's I can't see how there could be a problem with any of this as it's all new.
    I think it's got to be either the brake switch playing up (I've bought a new one and will be fitting it this weekend) or it's some problem with the master cylinder which I might try bleeding as well this weekend (are there any "how to's" for this?).
    Any advice / similar expieriences out there?
    Thanks in advance
    Mike
    S3 AMK
    Bilstein B8's & Eibach Springs, Neuspeed ARB's (22mm front & 19mm rear).
    Badger 5's Machined Discs with DS2500 pads & HEL braided lines.
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,534
    the switch will only knock your break lights out
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Grating sound is the abs kicking in...so in reality it has less braking , but more control
