AH FabricationsSky Insurance
Results 1 to 14 of 14
Thread: Engine damage
    G60DAN's Avatar
    Cornwall
    321
    Engine damage
    Right happy days got my S3 back last weekend after having forge con rods fitted and new
    water pump
    oil pump
    piston
    piston ring set x4
    chain tensioner
    cambelt kit with belt idler
    con rods
    big end bearings
    forge 007 DV
    all at the cost of 2190.92
    and still have a code coming up of 17963 chargr pressure maximum limit exceeded
    off 2 see bill on sunday hope he can sort it as its doing my head in
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    That's exactly the same fault as mine, quite a lot of these popping up recently. First thing to check is the N75, i gave mine a clean and it seems to be behaving.
    Quick test with a multimeter to check if it's 'ok' . Should be between 25-35ohms, mine is at 31ohms. I think the closer it is to 35ohms the faster it reacts (aggressive) the closer it is to 25ohms the slower it is (smoother)
    birmingham
    165
    i had the same problem on my s3, i turned my actuator down alittle as it was going over the standard psi limit on the ecu
    try turning down a clearing code see if it comes back
    RIP S3dave
    May 2004
    nr Glos
    7,143
    Quote Originally Posted by sandip View Post
    where did you get this info from?
    internally their bores differ which is why some control differently to others... spikey so called "race" valves etc
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Extracted from generation dubbs:
    here's some info I compiled from various posts regarding the different valves..
    I had a dead n75 in my car when I had purchased it... causing me to do alot of research
    So these are what I've found so far.
    058-906-283-C 20-30 ohm
    058-906-283-F 25-35 ohm
    034-906-283-H 25-45 ohm
    034-906-283-J 20-40 ohm
    034-906-283-K 20-40 ohm
    word is C has been superceded by the F. I don't know anything else about the H,J, or K.
    "...as we now know, the N75 regulates boost pressure based on the ECU's signal. The only problem is that the N75 is pre-designed to react a certain way to this duty cycle signal. Since there are various turbos out there and various [COLOR=#0066CD ! important][COLOR=#0066CD ! important]engines[/COLOR][/COLOR] to pair them with, there are several different revisions of the N75 that you can buy from any VW/Audi parts dealer.
    The main change between these various N75 valves is the way that they react to the duty cycle signal. Some valves have a small threshold for the need to lower or level out boost pressure. Some valves are intended to allow much higher boost levels and hold them even throughout the entire RPM range. In the end, the ECU still controls the valve's open/closed state. The valve just reacts faster or slower to these signals.
    The main part number for the N75 valve is: 034906283.
    Each revision of the N75 has a different letter added to the end of it's part number.
    Here is a current list of the various N75 valves that you can find at your local VW/Audi dealership and what motors they were made for:
    034906283C - Oldest valve, A4 1.8T original
    034906283F - Newer revision for 1.8T (maybe 170HP or TT 225)
    034906283H - 1991/1992 ABY [COLOR=#0066CD ! important][COLOR=#0066CD ! important]engine[/COLOR][/COLOR] and AAN [COLOR=#0066CD ! important][COLOR=#0066CD ! important]Engines[/COLOR][/COLOR] in S4/S6
    034906283J - 3B [COLOR=#0066CD ! important][COLOR=#0066CD ! important]engine[/COLOR][/COLOR] in early S2
    034906283K - ADU and ABY [COLOR=#0066CD ! important][COLOR=#0066CD ! important]engines[/COLOR][/COLOR] in late S2 and RS2
    There are alot of places on the web that offer "upgraded" N75 valves for your 1.8T/2.7T.
    ECS-Tuning sells a "race" valve. THis valve is infact the N75 version "H". It will cause boost to spike very high and in some situations cause your ECU to cut power in fear of detonation (also called "limp mode").
    The N75 version "J" is a very popular model. It makes the K03 react very linear throughout the RPM range and doesn't cause the "limp mode" problem with most 1.0bar chip programs.
    The N75 version "K" is an uncommon version to see in use but, it is very similar to the "J" version and many people see no need to bother with it.
    **NOTE**: As with any upgraded item for [COLOR=#0066CD ! important][COLOR=#0066CD ! important]your [COLOR=#0066CD ! important]car[/COLOR][/COLOR][/COLOR], check to see if other people have tried this part with the exact same program you are using on your ECU to see what the effects are.
    On a side note, most ECUs will have a preset limit for boost pressure. The ECU can determine the boost pressure by reading the air mass as it enters the [COLOR=#0066CD ! important][COLOR=#0066CD ! important]air [COLOR=#0066CD ! important]filter[/COLOR][/COLOR][/COLOR] end of the intake pipe. By pairing an upgraded N75 with a high boost ECU program (ie. GIAC "X" chip) you are very likely to hit "limp mode"
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    I got it from various different sites Bill, is it wrong? I'm not a 100% that i'm correct on the whole 'ohm' thing
    N75 Ohm test range 25-35? - Passat World Forums
    part number question? N75 valve - AudiWorld Forums
    Star Performance Testing Day Pt4 N75s
    Apologies if i got this all wrong
    G60DAN's Avatar
    Cornwall
    321
    Well I will let Bill sort it out this Sunday thanks for all the input.
    RIP S3dave
    May 2004
    nr Glos
    7,143
    thanks for the links.. the resistance ranges quoted are large.. 20ohm-40ohm doubling??
    i believe their internal apatures are different which is why the control is different
    but I could be wrong.. lol
    every days a school day
    bill@badger5.co.uk
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,987
    I think the n75F valve has been superceded by part number 06A 906 283 E....
    > S3 225 (03) - OEM+
    > 205 GTI (90) - Limited Edition Miami Blue with full leather - 1 of only 300 made
    > Clio v6 255 (05) - Lethal Weapon
    View: My S3 diary
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,264
    Quote Originally Posted by Funky_Junky View Post
    Correct, I bought a brand new one last week.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    Next time you have a dyno day we'll check the N75's to see if different readings give different delivery
    G60DAN's Avatar
    Cornwall
    321
    My N75 is an E got that a month ago from Audi.
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,754
    Thank god. I just mine through the post from the UK and it was an E. I thought I'd have to send it back! ASN sorts me out yet again.
    Handling mods++. GTX30 soon-ish. Hiding parts from the mrs since 2011. Build thread
    fran-s3's Avatar
    1,090
    Interesting they're on the E version - wonder if the parts any different from the F....
