AH FabricationsVolks Autos
Results 1 to 11 of 11
    Aug 2010
    bradford
    1,252
    what can C.A.U.S.E spluttering
    hi my mates got a s3 when he puts his foot down all the time it splutters at about 4rpm onwoulds in all gears.
    dont have a clue what it could be wondering if anyone has had this problem with there car.
    tar
    350bhp & 316ftlb BBT new k16 7+7 blade hybrid turbo, Welly cooler, jetex filter, relentless ported v3 manifold 3" downpipe & de-cat, liquid gauge, r32 rear arb, AGU ported and polished Head, 550cc injectors, kw v2 Coilovers, s3dave tie bars & heat sheild, milltek cat back, I.E forged rods, brembos, inline fuel pump, v3 badger 5 tip, devils own WMI kit, AGU pistons, rear grooved discs & brembo pads, ds2500 pads & EBC ultimax disc, stack boost gauge
    Dec 2010
    Newcastle-upon-tyne
    93
    Coilpacks or a boost leak is where I would start.
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    Coilpacks, MAF, temp sender, thermostat (if it's running cold), spark plugs, pre cat lambda, fuel filter, split hoses
    shanejess
    in my case its 2 bottles of rioja.
    SamiG's Avatar
    On Boost, ish.
    Southampton, UK
    231
    Corz. Lolz.
    Aug 2010
    bradford
    1,252
    Quote Originally Posted by sandip View Post
    cheers sadip that will help mate think his temp sensor has gone he's getting the fault anyway and he's got a dodgy maf connetion
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,273
    If the coil packs are a problem your mate should have the engine management light flashing at him (if its bad). A split in the fuel regulator hose can also cause problems if the car is struggling to fuel properly under load. Your best bet is to get the car scanned.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    DaveA3's Avatar
    Audi A-Trizzle!
    Milton Keynes
    2,378
    lol who changed the title?
    wouldnt the coilpacks cause stuttering at all different rpms rather than just at 4k?
    Audi A3 1.8T Sport (AGU) - 2000
    Engine: Carbonio CAI/Jetex JR Hybrid Induction, Forge 007p DV, Forge TIP, Longlife S/S Custom Exhaust system, R-Tech Stage 1 Remap, Creation Motorsport Boost Pipe Kit.
    Exterior and Chassis: 18" Cades Tyrus, Euro Wipers, low on JOM Coilovers, Eibach Front & Rear ARB's, Black Angel Eye Headlights, 6000K HID's, S3 Brakes.
    For Sale PM ME - £2500 Mods Inc
    Westy's Avatar
    Dec 2008
    17,273
    Quote Originally Posted by DaveA3 View Post
    They are worse on load though because they are having to work harder so the problem is more noticable higher up the rev range.
    S3 Build Thread
    Jan 2011
    9
    It would also be worth checking that the cam timing is not a tooth out.
    Aug 2010
    bradford
    1,252
    thanks all he's got no engine light on and has been scand on vagcom just got temp sensor fault and maf but that coz he unplugged it
