JMB RetrofitsBadger5
Page 1 of 4 1234 LastLast
Results 1 to 40 of 126
Like Tree5Likes
Thread: DIY heat shield - for under Ł20
    Oct 2009
    90
    So this all came about after I fitted my a Badger5 3" TIP and JR filter. Having pulled out the old airbox I could see that the MAF and filter were going to be bouncing about all over the place, so figured I needed something to secure it, stopping the vibrations destroying the MAF. That and obviously something to stop the heat soak.
    I looked at a few on the web but decided I wanted something a little more substantial yet still pretty simple as I'm a bit of a spanner with a spanner. Don't get me wrong, this is officially amateur hour.
    Anyway, I popped down to Homebase and picked up the following...
    Materials:
    • Steel sheet - 100cm x 50cm x 0.0055cm - Ł16
    • 2 x nuts & bolts - 4mm - Ł0.85
    Tools:
    • Tin snips - Ł17
    • Rivet gun - Ł16
    • Drill - 4mm & 6mm drill bits
    The design is all one piece of steel to keep it fairly fool proof, cut to the template below and riveted together. It's a fairly tight fit which is what I was going for so that it doesn't rattle around. It also gives as much room around the filter as possible, so shouldn't be too restrictive.
    Before first fitting... needed to be trimmed down a couple of inches in length as it just wouldn't fit. Not as easy as it sounds.
    Fitted...
    I used one of the airbox fitting screws to secure it against the wheel arch, as well as the rubber ring from the lid of the airbox to space the filter from the heat shield. Having just thought about it, it would probably be better used to space the MAF from the heat shield. Must remember that.
    What would I do differently?
    • Potentially use aluminium instead of steel as it would be lighter and easier to cut/bend. Unfortunately that's all Homebase had on the day.
    • Reduce the height by about 10mm as mine makes an indentation on the bonnet lining. It's a tight fit at least!
    • Make the tabs larger which would make them easier to bend. These were a real ball ache with the thickness of the steel and fairly little leverage.
    • Find a better tool to cut the MAF hole out - that took bloody ages to get a decent circle with those tin snips.
    The adjustments above have been made to the template. Mine looks a little rough as I had to make adjustments as I went, which was a pain once everything had been bent into shape. Might also find some PVC edge trim to finish up the sharp (now slightly scrappy) edges.
    All in all I'm pretty happy with it, certainly does the job. If you have the tools already, it's a steal at Ł17.
    Next up is a cold air feed. Any suggestions?
    Any thoughts, comments, amendments on the design? What has everyone else done? Answers on a postcard.
    Cheers,
    Geoff
    Drewvic and Empty like this.
    Currently running a MTM stage 1 map, ECS brakes, Forge DV, Bager 5 TIP, 18" RS4s, Bilsteins, H&R springs, Tie bars, Milltek catback... but not for long...
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,987
    That looks great mate, well done!
    > S3 225 (03) - OEM+
    > 205 GTI (90) - Limited Edition Miami Blue with full leather - 1 of only 300 made
    > Clio v6 255 (05) - Lethal Weapon
    View: My S3 diary
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,491
    looks good
    1 thing tho
    paint it will look even better
    flat out
    north weald essex
    220
    that would look awesome in the matt black like the engine covers
    2001 1.8T B5 Black A4 Avant Votex kit and Ecru Leather
    RIP S3dave
    May 2004
    nr Glos
    7,167
    very well done fella.. nice one
    NEW NEW NEW eShop now LIVE>
    www.badger5.biz
    bill@badger5.co.uk
    Oct 2009
    90
    Cheers for the comments.
    Actually I had thought about spraying it black as not only would it look the nuts and blend in a bit more, but would also give it a little protection against the elements.
    However, would spraying it black not make it absorb heat rather than reflect it, or are we talking about low enough temperatures for it not to matter?
    RIP S3dave
    May 2004
    nr Glos
    7,167
    dont worry about the colour of the paint...
    www.badger5.biz
    bill@badger5.co.uk
    DaveA3's Avatar
    Audi A-Trizzle!
    Milton Keynes
    2,378
    wow lovely job mate!
    Audi A3 1.8T Sport (AGU) - 2000
    Engine: Carbonio CAI/Jetex JR Hybrid Induction, Forge 007p DV, Forge TIP, Longlife S/S Custom Exhaust system, R-Tech Stage 1 Remap, Creation Motorsport Boost Pipe Kit.
    Exterior and Chassis: 18" Cades Tyrus, Euro Wipers, low on JOM Coilovers, Eibach Front & Rear ARB's, Black Angel Eye Headlights, 6000K HID's, S3 Brakes.
    For Sale PM ME - ÂŁ2500 Mods Inc
    fran-s3's Avatar
    1,090
    Wow looks awesome! Wish I was as clever and handy enough to make one of those....
    From Show... to GO
    Nov 2010
    Stafford
    436
    brilliant! i'll be making this in the morning!
    did you draw around the filter for the circle hole size?
    shanejess
    well done looks good, i wish i could put my hand to stuff like that.
    From Show... to GO
    Nov 2010
    Stafford
    436
    also, how did you get the steel to fold so well, did you score it to weaken it at the joint? or just fold up around a spirit level, or something similar with a sharp edge?
    barters3's Avatar
    May 2008
    440
    i was going to design something like this when iv got a badger5 tip and jetex. however youve done the hard work, nice one. Im going to make it out of card following your design and then tweak if necessary.... iv got some spare satin black sat here so i think ill paint mine when its done.
    s3_kev's Avatar
    Stage2'd!!!!!!
    Feb 2008
    1,984
    after seeing your own coment of being a 'spanner' i thought oh no here we go it will be rubbish, but you stand me corrected thats actually a very good effort, well done
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Nice effort, i do them in ali with 2 fixing points, 1 down by the battery, well done on the folds with no press...
    DJ_Troopa's Avatar
    K1 Driver
    Oct 2008
    West London
    1,737
    Visit DJ_Troopa's Instagram Channel
    Brilliant DIY there! I got the Jabba heat shield route for myself though a month back. Yours would be better if it was longer so it covered the whole length of the air filter.
    Inferi Black Cupra K1
    Click here for more Troo-Pics!
    From Show... to GO
    Nov 2010
    Stafford
    436
    Troopa, his did cover the whole length, but it was cut down due to fitting issues
    damo.h's Avatar
    DVLA Say it's Black
    NW
    3,608
    Good skills dude.
    From Show... to GO
    Nov 2010
    Stafford
    436
    Did you just use a hand riveter?
    found this: 250mm (10in) Steel Plate Hand | Hammers | Focus DIY Online
    dont know if it will be any good, i'll have to buy a rivet gun and tin snips
    Dec 2010
    45
    looks great mate,, make a few and sell them !!
    cecilthesausage's Avatar
    ...It's Never Finished...
    Jul 2010
    Teesside
    933
    That riveter will do the trick coyle
    From Show... to GO
    Nov 2010
    Stafford
    436
    Quote Originally Posted by cecilthesausage View Post
    nice one dude, i'll get everything tomorrow, and have a go.
    going to make it from cardboard 1st, make sure im happy with it, then go for it
    105
    Hi piester is the template you have wrote down before or after the things you said you would do different at the end of your post?
    J B
    J B's Avatar
    Dec 2008
    Hants & Ox
    140
    Thats exactly what I needed, something to keep me busy at the weekend, had been thinking about this and grabbed some cardboard to make a mock up then you post this! Top bombing
    s3 Hoggy's Avatar
    Whats going on???
    Apr 2009
    Oxford
    1,653
    Visit s3 Hoggy's Instagram Channel
    This looks great! I don't have a badger5 tip or a jetex filter but still feel the urge to just make a heatshield!!!
    2002 S3 REVO
    Milltek, Sachs Organic clutch, 007p, Genuine RSTT's, BBS RS2's
    Koni FSD & H&R springs, Neuspeed 22mm rear ARB, KW tie arms
    LCR Brembo's with DS2500's & Paul's 300mm Rear disc kit,
    Michelin Pilot Sport 3's,Badger5 V2.2 Jetex filter & heatshield
    Chugger
    North Devon
    2,716
    Quote Originally Posted by s3_kev View Post
    got to admit i was expecting something made of ply and coated with tin foil! pmsl
    But im seriously impressed, you have all the DIYers with 3" mafs coming out of their holes... very inspirational.
    Maybe a competition for the most elabourate heatshield? :P
    57 A3 2.0 TDI Sportback (140)
  28. #27
    From Show... to GO
    Nov 2010
    Stafford
    436
    Quote Originally Posted by sportstractor View Post
    could make a perspex lid
  29. #28
    Aug 2009
    97
    Looks good, might have to make myself one! Might go one step further and make it from CF though
    Is there a good place to get a CAI feed from?
  30. #29
    DaveA3's Avatar
    Audi A-Trizzle!
    Milton Keynes
    2,378
    could get some carbon wrap around the sheet steel. would look great
  31. #30
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,273
    Nice work, you have got the cogs going round in my head now too
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
  32. #31
    Oct 2009
    90
    It's really not that hard, honestly. This is the first thing like this I've made and whilst it took me a while, that's mainly because I was trying to figure it from scratch.
    Draw around the MAF, as that's what goes through the hole. If you end up cutting it slightly bigger, it's not the end of the world as the two screws fastening the MAF to the heat shield will stop it rattling around.
    I did score the outside of the edges of the tabs with a standly knife, but not too much as I didn't want it to split. To bend I just used two off cuts of the steel to get it nice and even. Only the tabs really posed a problem as they were so short on mine.
    Exactly right. Whilst my dimensions worked for me, that's based on how I fitted the TIP. Given that the TIP is fairly adjustable being in three bits, it shouldn't be too different but definitely do a template first. Use card as well, not paper like I did. Whilst it looks like it fits on the paper template, it's a different story once it's solid steel.
    I'd actually made a bracket to use the battery fixing point to give it the extra stability, but the whole thing is such a tight fit I decided there wasn't any need to in the end. No point over complicating things.
    That's what I thought but it didn't fit as a straight rectangular box and whilst I could have tapered it in at a similar angle to the filter, I thought it would only be more restrictive. Also as it's squared off, it follows the line of the battery cover which keeps it nice and neat.
    That's pretty much exactly the same as the one I bought.
    Can't be arsed. The template is there though for anyone that wants it.
    I made a few rough amends to the measurements when it was finished based on the issues I had, but would definitely recommend making a card template first and a seeing how it fits the way you've set up your TIP.
    This is what I want to know. I've seen somewhere that someone had flexible ducting pipe (as below) going down under the headlight. Anybody got any pictures or ideas?
    NTCDUCTING.COM -Heating and Ventilation Ducting - Industrial Ducting- Flexible Ducting Manufacturer
    Cheers again for all the comments. Definitely worth giving it a go if your bored one day.
    Again if anyone has any changes to the template, PM me and I'll send you the powerpoint I made it on, or if you just want it to print I've got it on a PDF.
  33. #32
    Oct 2009
    90
    Crikey, that was a long reply!
  34. #33
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    I can cut some 2500mm x 1250mm aluminium sheet down to the overall cut size at cost, if there is enough interest
    should be no more than Ł10 delivered....
  35. #34
    JamJay's Avatar
    Oct 2010
    Reigate, Surrey
    190
    Fantastic! It looks a lot like my old Neuspeed shield which I can confirm does not fit with Badger 5 TIP even with 1" trimmed off of each end of the top 90degree bend. The problem with the Neuspeed was that it wanted to sit too far backwards to meet the mounting points which meant the TIP needed to be pushed back so far that it raised and kinked. The Jabba one looked like the TIP slides into the shield rather than bolts to it which will be better but I like the idea of securing the MAF to something so I might make a version of what you have done but have it sitting further forwards with the mount points moved further back.
    You only really appreciate how retarded people are in this world when you log on to a forum and recoil in disgrace over their spelling. How are any of you actually employed?!
  36. #35
    RIP S3dave
    May 2004
    nr Glos
    7,167
    if Neuspeed can fit on std intake or silicon one, why would'nt it fit with my 3inch, which fits on std airbox if you trim it accordingly?
    Neuspeed one is narrow tho, too narrow for the JR filter.. that I have seen
    www.badger5.biz
    bill@badger5.co.uk
  37. #36
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Yeah the neuspeed is oval.. and sits in on the shorter side
  38. #37
    fran-s3's Avatar
    1,090
    Anyone got a picture of the Jabba one? Can you confirm if it would fit with the JR filter?
  39. #38
    JamJay's Avatar
    Oct 2010
    Reigate, Surrey
    190
    This I can't answer Bill but I would have had to make a right mess of your TIP to get it to fit. I trimmed 2" off as if was and any more than I'd been too close to the bend in the pipe so it was a non-started I'm afraid. The only other way I could have done this would be to trim the lower 90degree bend and make it very short. I moved the hoses at all angles on the ported joiner and still no luck, just doesn't fit I'm afraid.
  40. #39
    fran-s3's Avatar
    1,090
    Piester regarding the cold air feed, me and my friend did once manage to stuff a cold air feed down the hole in the side of the wing where the original hole is where the passenger wheel is... (well it's more of a triangle then a hole, gap thing) He had to take my wheel fender off and pointed the other end forwards so as to catch cold air above the passenger wheel.... I was trying to install a universal enclosed kit but it didn't work out (as the pipe kept collapsing on full acceleration because of the angle) Anyway the point is you can utilise that gap and get a cold air feed down there, means a very tight fit with the wheel fender/guard things as we struggled to put them back on - a lot of bending was needed but it was possible. I'll definitely be doing that when I get the JR filter.. and of course u can pull the cold air pipe out as much as you want so it's pointing right at the cone..... Not as good as the front of the bumper but the next best thing I think.
  41. #40
    JamJay's Avatar
    Oct 2010
    Reigate, Surrey
    190
    How did you cut the hole for the MAF meter housing?
