Chris NottVolks Autos
Page 2 of 4 FirstFirst 1234 LastLast
Results 41 to 80 of 126
Like Tree4Likes
Thread: DIY heat shield - for under Ł20
  1. #41
    Oct 2009
    90
    How did you cut the hole for the MAF meter housing?
    With difficulty. Basically drilled two large holes next to each other to get the tin snips in, then lots of little snips later and you get a nice MAF sized hole. It's a ball ache but you get there in the end.
    Currently running a MTM stage 1 map, ECS brakes, Forge DV, Bager 5 TIP, 18" RS4s, Bilsteins, H&R springs, Tie bars, Milltek catback... but not for long...
  3. #42
    RAPS3's Avatar
    Moo Moo Land
    1,040
    Good effort mate - did something very similar a good few years ago when I had my 8L
    S3Lol likes this.
    Paul R
    S3 Sportback - Sprint, Buckets, Bose, Rain & light, Alu rails, Piano trim, FT Warning, Bluetooth prep
    S3's now sold - roll on the Golf MK1 Project
  4. #43
    www.badger5.co.uk
    May 2004
    nr Glos
    6,944
    Quote Originally Posted by JamJay View Post
    This I can't answer Bill but I would have had to make a right mess of your TIP to get it to fit. I trimmed 2" off as if was and any more than I'd been too close to the bend in the pipe so it was a non-started I'm afraid. The only other way I could have done this would be to trim the lower 90degree bend and make it very short. I moved the hoses at all angles on the ported joiner and still no luck, just doesn't fit I'm afraid.
    hmmm. oh well you tried.
    just curious how I can get the 3inch tip to fit OE airbox.. Fiddly job that it was compared to using a JR fiter (trimming was required to both silicon bends but it worked.)
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
  5. #44
    fran-s3's Avatar
    1,090
    Quote Originally Posted by RAPS3 View Post
    Wow that looks awesome! Where did you have you airfeed pointing?
  6. #45
    JamJay's Avatar
    Oct 2010
    Reigate, Surrey
    190
    Quote Originally Posted by Piester View Post
    Thanks . I am just about to invest in a pack of Tin Snips, R/H, L/H & Straight. I found a guide on the internet for cutting round holes in ducting which has been very useful.
    It would have fitted for sure but like you say, I'd have to trim both hoses and I didn't want to make a mess of the TIP or risk compromising its performance. It's fine though, I've sold the Neuspeed on and I look forward to making my own custom shield in a couple of weeks. It's currently secured using the eyelet for the OE cold cold air feed .
  7. #46
    RAPS3's Avatar
    Moo Moo Land
    1,040
    Quote Originally Posted by fran-s3 View Post
    Thanks mate - I had the air feed pointing from the end of the cone down through the inner wing and into the front of the foglight grill - was a bit tricky getting it in but worth it
    Paul R
  8. #47
    Feb 2008
    529
    i could knock some of these out, as im a CNC Laser operator
    Audi A4 Avant 1.9TDI Quattro Sport 2004
  9. #48
    barters3's Avatar
    May 2008
    440
    Here's my attempt, based on Geoff's but i made i few changes.
    Primed it with an etch primer for aluminium and satin black top coat. doesnt look amazing but it should do the job. just got to install a cold air feed now.
    Oh and the sticker is just to cover a mark on the aluminium, i would have preferred it to not be on there tbh.
  10. #49
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,970
    Very nice mate!
    > S3 225 (03) - OEM+
    > 205 GTI (90) - Limited Edition Miami Blue with full leather - 1 of only 300 made
    > Clio v6 255 (05) - Lethal Weapon
    View: My S3 diary
  11. #50
    J B
    J B's Avatar
    Dec 2008
    Hants & Ox
    140
    Looks good mate, I finished mine off the other day blacks the way forward I should get a pic!
    Where did you get the protective edging I cant find any anywhere!
  12. #51
    105
    that looks really good mate.did you use the same measurements as Geoff's and did you use ali or steel?
  13. #52
    barters3's Avatar
    May 2008
    440
    Where did you get the protective edging I cant find any anywhere! [/QUOTE]
    I have got an astra van and behind the seats are cubby holes with rubber edging on!! There wasnt enough to do the whole thing so i just did the straight edges as they were hard to get dead square using snips, so the edging made them look a bit better.
    Quote Originally Posted by s3 kam View Post
    Followed geoffs design, however i didnt cut the bracket into the right hand side of it, i just made both sides the same and then rivetted a bracket in place after.
  14. #53
    barters3's Avatar
    May 2008
    440
    oh and i used aluminium
  15. #54
    Chugger
    North Devon
    2,716
    Quote Originally Posted by J B View Post
    You can get it on eBay mate. Search edge trim, I got a few metres for Ł3 per metre... Bargain
    57 A3 2.0 TDI Sportback (140)
  16. #55
    JamJay's Avatar
    Oct 2010
    Reigate, Surrey
    190
    Quote Originally Posted by barters3 View Post
    How thick was the aluminium, 1mm?
    Here's my mock up, will build it this week.
  17. #56
    From Show... to GO
    Nov 2010
    Stafford
    436
    I think it would work better without the coupler between the MAF and the filter,
    and also, why didn't you fold the card around the right edge of the filter? you changing the shape?
  18. #57
    JamJay's Avatar
    Oct 2010
    Reigate, Surrey
    190
    The coupler is there to straighten the airflow pre-MAF to ensure further longevity of it, its widely implemented across SCN and works well. It also sticks the filter nearer the air feed which is now noticeably cooler than when it was attached to the MAF. The shield i am making is basically a Neuspeed/Jabba hybrid, best bits from both, there is no right hand wall as there is no point, the turret is enough and gives the filter more room to breathe and a larger area for the cold air to be trapped in.
  19. #58
    JamJay's Avatar
    Oct 2010
    Reigate, Surrey
    190
    Calling S3 Fran, empty your Inbox, I'm trying to reply to your message about this .
  20. #59
    fran-s3's Avatar
    1,090
    LOL sorry emptied!
  21. #60
    J B
    J B's Avatar
    Dec 2008
    Hants & Ox
    140
    Ok so thought I would put a couple of pics of my attempt up, I couldnt get hold of any aluminium so ended up using .6mm steel which seems sturdy enough for now just waiting for some edging strip from ebay to just finish it off Now all I need is to sort out a decent cold air feed!
    Put two brackets on it and it sits on a foam pad on top of the cabling conduit this thing aint goin nowhere
    Cheers Geoff for the kick up the backside that I needed lol kept putting it off but got it done eventually
  22. #61
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,061
    Looks well JB, nice effort
  23. #62
    J B
    J B's Avatar
    Dec 2008
    Hants & Ox
    140
    Cheers Dave, the hardest part was getting the TIP to fit again had to cut both the silicon joiners down in the end, wasnt much room to play with!
  24. #63
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,160
    That looks very professional JB good work. I'm going to get a Jetex filter this weekend but I'm still torn between a custom enclosure like yours or a cut and hack at the standard air box to keep the OEM look
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
  25. #64
    J B
    J B's Avatar
    Dec 2008
    Hants & Ox
    140
    I did think about hacking the standard box like tuffty and others but decided it was just as easy to make a custom shield, if it was painted crackle black then I think it would blend a bit better. It might be possible to fit the old airbox cover over it which is something I hadnt thought of might look into that tomorrow
  26. #65
    Westy's Avatar
    Dec 2008
    17,160
    If you can get the old air box cover to go on your custom shield that would be ideal. The thing I dont like about hacking the standard box for a cone is that it has to be squeezed in to fit.
    S3 Build Thread
  27. #66
    JamJay's Avatar
    Oct 2010
    Reigate, Surrey
    190
    Here;'s my effort pre-spray painting. Fits extremely well and just what I wanted.
  28. #67
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,061
    Looking good jamjay,
  29. #68
    JamJay's Avatar
    Oct 2010
    Reigate, Surrey
    190
    Thanks Dave.
    Having some trouble getting the edging strip though, anyone know of any high street stores that stock it? My local RS Trade Counter does but they don't open on Saturday's.
  30. #69
    barters3's Avatar
    May 2008
    440
    mine was a pain to get it to fit!
    I wish i extended mine towards the wing like you have, it looks much better.
    Any updates on cold air feeds would be appreciated as this is the next thing on my list.
  31. #70
    Chugger
    North Devon
    2,716
    Trim chaps: SMALL BLACK PVC rubber car interior EDGE gripping TRIM on eBay (end time 04-Apr-11 14:54:21 BST)
    I couldnt find anywhere local that stocked it, if anything, it would be worth asking at fabrication shops if you're that scared of eBay.
  32. #71
    JamJay's Avatar
    Oct 2010
    Reigate, Surrey
    190
    Well here it is, all finished...
    fran-s3 likes this.
  33. #72
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,970
    Very nice
    > S3 225 (03) - OEM+
    View: My S3 diary
  34. #73
    LukeTripod87's Avatar
    Apr 2009
    Kent
    315
    Anyone fancy making one of these for me as I don't trust myself? lol I'll pay well!
  35. #74
    fran-s3's Avatar
    1,090
    Awesome - I want one! Just in time for summer eh...
  36. #75
    barters3's Avatar
    May 2008
    440
    thats really good jamjay, just paint it black and itll look the nuts!
  37. #76
    JamJay's Avatar
    Oct 2010
    Reigate, Surrey
    190
    Thanks . I've just repainted my Brembo's so I have the painting bug.
  38. #77
    JamJay's Avatar
    Oct 2010
    Reigate, Surrey
    190
    Quote Originally Posted by S3turbo-luke View Post
    I have a spare one ready to go, just needs to be cut out of the template. You would however need to cut your own MAF hole as each car is slightly different, especially those with 3" TIP. Where are you located, if close I could do this for you?
  39. #78
    Inertiauk's Avatar
    Mar 2011
    529
    Another Job on my To Do List.
    Going to ask my dad for a hand as he's an engineer. Might even be able to knock me one up at work.
    __________________________________________________ __________________________________________________ _
    Driving a 2004 B6 Audi S4 - Stage 2
  40. #79
    Aaronipswich's Avatar
    May 2011
    38
    Superb work guys
  41. #80
    Apr 2009
    Kent
    315
    Ooo sounds tempting! I live in canterbury in kent mate. If all I would need to do is cut the MAF hole I'll take it mate.
    Audi A3 8V 2.0tdi 184ps Sline
    **Message for parts enquiries in Kent**
