Results 1 to 11 of 11
    Jan 2011
    77
    oil leak and oil/filter change
    have discovered a leak from the oil filter area do you think this is likely to just be a bad seal in the filter?.. also i want to do a oil/filter change but have never done this before, do you guys think this is an easy job for a novice?
    cheers
    Scott
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,472
    very easy
    and theres a few guides around
    Jan 2011
    77
    yes mate i know how to do it just never been brave enough to attempt it
    Chugger
    North Devon
    2,716
    yep its one of the easiest job you can do, just a bit messy the first time
    57 A3 2.0 TDI Sportback (140)
    Jan 2011
    77
    the bit that bothers me most is jacking the car up and putting on axle stands...
    talentwalsh's Avatar
    May 2010
    Galway
    139
    Try and get someone with a pit, ramps or a lift if you can, audis are pretty low slung cars and even with a jack and stands its pretty tight under there!! It is on my S3 anyway. It will make your life a whole load easier!!
    Jan 2011
    77
    nyone with any of those..so is it to hard just to do it on axle stands?
    a3tdi2001's Avatar
    437
    A pavement kerb for one side and a breeze block for each of the other two wheels with two bricks to get up on the blocks, cheap from B&Q
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Quote Originally Posted by a3tdi2001 View Post
    Oil change, pikey style , lmao.
    a3tdi2001's Avatar
    437
    Hey don't knock it. Easier than arsing about with axle stands and a jack. Beware though, there is ALWAYS an old neighbor who comes up to ask you what your doing
    Ross_S4
    Aug 2009
    Dundee
    718
    Go for it mate. get wired in there.
    everyone has to start somewhere and that is one of the easier jobs to do......IF it all goes well...
    From your profile pic your drive looks pretty steep, maybe want to use the road or somewhere level for stability when it is jacked up. or you could get a set of ramps pretty cheap out of halfords.
    Top tip - Get yourself a kitchen washing up basin (don't nick it off your mam / missus!) and use that to catch the oil draining from the sump plug. nice big opening to catch it all in and you can decant into a drain bottle or whatever later for disposal.
