EM TuningJMB Retrofits
Results 1 to 13 of 13
    Black 1997 Audi A3 1.6
    63
    Engine Misfire - Can't access spark plugs
    My engine is slightly misfiring however I can only access two spark plugs because the inlet manifold is in front of the other two spark plugs. Is there a tutorial of how to access them?
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Quote Originally Posted by silverswish View Post
    Huh?
    Homer Simpson
    Dane's Avatar
    Faster than a V12 Q7
    Cheltenham
    4,003
    Inlet manifold?
    What engine do you have dude?
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Quote Originally Posted by Dane View Post
    Inlet manifold?
    Must mean the N249 assembly - that's the only logical thing I can come up with...
    Homer Simpson
    SiGainey's Avatar
    Sep 2003
    North Wales
    475
    In which case, try Waks Wide Web
    '01 AMK, completely standard except for the Ambient Lighting Pack.
    RIP S3dave
    May 2004
    nr Glos
    7,134
    what model car?
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
    TDIQ's Avatar
    8L > 8P > 8V
    Jul 2009
    777
    Previous posts suggest it's a 1997 1.6 A3.
    I know on my AVU engine 1.6 it's seriously tricky to change the middle two without taking the inlet manifold off. It IS possible though, I had to use a socket with two different extensions and a spark plug socket on the end and bend it and slowly work them out. Tricky, but it is doable.
    It could also be coilpacks or HT leads that cause a misfire.
    '02 A3 TDI quattro sport
    8L IS DE BEST
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Quote Originally Posted by Aar0n View Post
    Ahhhh, I see...
    For those who haven't ever seen one (like me) this would be the item in question then - ignore red circle.
    Homer Simpson
    Dane's Avatar
    Cheltenham
    4,003
    Wow, bad times!
    S3KO4's Avatar
    Aug 2009
    London
    850
    Why don't you remove the inlent manifold then? does not look that hard!
    S3-8L REVO stage 2, Milltek, 3" DP & custom 3" decat, RS2 spark plugs, 4 bar FPR, Green-Cotton uprated upper/lower boost hose & TIP, Front Zimmerman & Ferrodo. LCR spliter. boost gauge, smoothed AB. Aero blades, H&R 5mm spacers. Best time 14.03sec, 0-62 in 5.7sec. 207gs @ 25psi , polished inlet mani. VAGCOM 805.1
    Chugger
    North Devon
    2,716
    Ahhhh, I see...
    EWWWWWWW
    57 A3 2.0 TDI Sportback (140)
    Feb 2011
    Essex, South
    97
    I changed mine about 1 year ago. I am a complete spanner, and it took me about 4 hours. The entire top bit (more evidence of my incompetence) had to come off, resulting in pistons showing etc. Behind the silver manifold in the centre of the picture are the delicate injector bar - this is all wires and sensors so be careful. As far as I can tell, the one on the passenger side is the only accessible one on the car. I literally took the whole top off to get to them!
    I changed due to a massive misfire but It didn't solve the problem, so I then changed the coil pack - still no luck. Then I discovered it was the HT lead. Moral of the story - when you do it -- do the lot if you can afford it.
    Sorry I can't be more help.
    TDIQ's Avatar
    8L > 8P > 8V
    Jul 2009
    777
    Quote Originally Posted by sportstractor View Post
    EWWWWWWW
    That's the pic I took a long time ago, that is the heart of 100hp.
    Quote Originally Posted by TheButtonz View Post
    I originally changed mine to stop a misfire, then the coilpack and it turned out to be a HT lead aswell.
    8L IS DE BEST
