JMB RetrofitsChris Nott
Results 1 to 19 of 19
    Andrew@A.L.D's Avatar
    Cylinder Head Master
    Jun 2009
    Leeds
    3,453
    S3 creaking when taking up drive
    Its only just started in the last few days
    Is there a common problem that causes this on S3's that people know of?
    RIP S3dave/David Marshall stickers now available
    FOR SALE
    Sparco Torino 2 sport seats, None resonated Milltek exhaust, Blue Haldex controller
    Adjustable FPR from 1-5 bar, 2 sets of Unused ARP 3/8 2000 rod bolts, relentless 200 cell cat pipe, Std AGU Crankshaft. Ported & Reconditioned Cylinder head service.
    flat out if in doubt
    stoke on trent
    149
    mines the same when i turn left or pull off.its coming from the passenger side.drives me up the wall
    SiGainey's Avatar
    Sep 2003
    North Wales
    475
    Mine makes a creaking kinda noise. Sounds like a loose heat sheild and I've removed the cat heat sheild. I can rev the engine with the box in neutral and it doesn't do it, it's only on taking up drive and if I come on / off the throttle. Drives me MAD!
    '01 AMK, completely standard except for the Ambient Lighting Pack.
    Jun 2009
    Leeds
    3,453
    I'm not the only one then
    FOR SALE
    Jun 2009
    Leeds
    3,453
    no one knows what it is?
    Might get a garage to diagnose the problem as i could spend time and money trying to find it
    FOR SALE
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,520
    i know what it is, a 10 year old car, only normal man, wouldnt worry about it unless its shouting at you ya know.
    Jun 2009
    Leeds
    3,453
    Yes it may be a 10 year old car but for it to just start over night there must be something wrong.
    I rather get it fixed than just leave it
    FOR SALE
    Nilz's Avatar
    Defo worth the wait :)
    Apr 2006
    10,062
    Front arb bushes, its a common problem.
    SiGainey's Avatar
    Sep 2003
    North Wales
    475
    Not sure it's the arb bushes (as I've just replaced them) as if I come off the throttle and gently on to it again, I get the noise. It sounds like a heatshield that's loose somewhere. Does the downpipe have a heat shield on it?
    Nilz's Avatar
    Apr 2006
    10,062
    Could be a heatshield, also on the ARB bushes, they are meant to have a plastic sleeve inside of them, if they are taken off or split, it can be them that causes the issue....
    Jun 2009
    Leeds
    3,453
    No heatshields on my exhaust
    Plan to change to my R32 kit soon anyway
    FOR SALE
    Chugger
    North Devon
    2,716
    engine mounts? or exhaust movement?
    57 A3 2.0 TDI Sportback (140)
    Jun 2009
    Leeds
    3,453
    Got a uprated dog bone bush but standard engine and gearbox mount
    FOR SALE
    Apr 2007
    98
    Any more ideas on what this knock was, think im getting the same thing. I have changed both wishbone bushes, ball joints, droplinks, Dogbone bushes, all with new bolts. Knock is still there when driving slow, taking up drive and braking etc...I have checked a replaced pads in calipers, now onto removing driveshaft and re-greaseing the cv joints on the N/S/F as there is a bit of play there.
    Not a really loud knock, but still a knock.
    Any help appreciated.
    Audi S3 AMK
    Jun 2009
    Leeds
    3,453
    Engine mounts maybe as i have recently ripped the threads out of the engine mount causing a knocking noise
    FOR SALE
    Dec 2010
    30
    I recently started a thread "Strange Clonking/Creaking noises" and got similar answers but no real solution. Have you tried any silicone spray on the buses just to free them up a bit?
    Apr 2007
    98
    All the bushes are new......plus i disconnected the droplinks and arb and the knock was till there...so not them. Im going to look at the side engine mounts tomorrow after sorting out cv's. if its not them it has got to be top mounts.....or a worm hole to knocksville
    Audi S3 AMK
    SiGainey's Avatar
    Sep 2003
    North Wales
    475
    Solved mine this weekend (but got another lol) - the heatshield on the bulkhead was missing a bolt so was resonating...
    Apr 2007
    98
    Sorted.........It was the central bolt in the dogbone mount...I had not torqued it up tight enough and it was twisting....Set it to 60nm and it is sweeeet.
    Audi S3 AMK
