Chris NottAH Fabrications
Page 1 of 24 1234567811 ... LastLast
Results 1 to 40 of 946
Like Tree228Likes
Thread: superkarls overhaul
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,533
    superkarls overhaul
    greetings gents, had a busy day today on the car and thought id upload and share my story as i have nothing better to do, alone on a saturday evening as the girl friend is away.
    so, i took my car off the road before christmas with the intentions of doing a few things, however with the weather so terrible i did very little, until the past week or so.
    i initially took the car off the road to replace some much needed parts, 2 cv boots that were torn to buggery. and also as i was selling my standard wheels and had bought some new ones to refurb and paint, so its been on axle stands for a couple of weeks.
    But upon inspection it became clear other areas would benefit from replacement parts and minor upgrades.
    the parts i've got are as follows....
    B5 RS4 wheels, pictured is an uncompleted primed one, they will be sprayed a light gunmetal called moonland pearl (vauxhall colour).
    inner cv boot
    outer cv boot
    haldex oil and filter
    bottom ball joints
    top mounts
    powerflex dogbone bush (red diesel one)
    thermostat
    and what isnt pictured:
    lemforder rear wishbone bushes
    powerflex front wishbone bushes
    tpi wheel spacer kit from theTTshop
    egt sensor
    il start by showing the condition of the parts on the car, that should show how worn they are, 10 years old, 133000 miles worth of frankly SH**E british roads....
    first is the rear wishbone bush on the drivers side, quite clearly split
    inner cv boot, pretty shagged to say the least
    bottom ball joints, slight split at the bottom, going to be worn out anyway due to age/miles
    so i started my work to take the wishbones out. drivers side, fairly easy, not to hard to crack all bolts out at all. 18mm bolt through the front bush, 18mm on the rear bush with nut on other side, held with a spanner and ratchet off. Three 16mm nuts on the underside of the ball joints.
    ball joint nuts wer quickly sprayed with some primer for reference on refitting new ones so that alignment shouldnt be toooo bad to drive to get alignment done.
    once all was undone and bolts were removed, i used a jack under the discs to raise it up, and with a pursuader (hammer) nocked the wishbone down off the balljoints, they then simply pulled out with relative ease.
    this is the topside of the bush which was seen earlier, split, sitting pissed in the wishbone. it should be completely flush
    underside shows just how bad they can be fromall this time and driving
    the front bush, later 45mm one (happy times), looks all mushed and all over the place really, a powerflex poly one should sort that out! i chose a poly one for this bush as it only has rotationally movement, so wont be all that hard on the ride, but the rear bush having multiple movement, im replacing with rubber so as not to jeapardise comfort.
    the ball joints were not as bad as i thought, no knocking movements, just a little loose most probably from lack of grease. i took one apart to see just how much grease was in there. the new ones are difficult to move by hand, whereas these can be moved with your little finger.
    i decided to have a little go at the rear bush as it was buggered and thought it might drop out. 3 hits with the pursuader later and it came out. only leaving the metal casing thats supposed to be around the bush with it, oh well, shows how bad they are, and can be hit out later.
    the passenger side was a different story, the rear bolt wasn't going anywhere, id tried so hard, im fairly strong and just couldnt get it to budge, then after a breather i said to a mate, im havin one last go at this ******, and pop, undone. i honestly nearly pooed myself!
    this side seemed to have been replaced at some point, the arm was in much better condition than the other, and the bush had nearly no splits
    i also found out that very recently, well, before i bought the car last april, the droplinks must had been replaced, they look brand new, which is good.
    so, wishbones removed, ready to have bushes pressed out and new pressed in at some point, this coming week most likely. they'l also be cleaned and painted up black just to look a bit prettier, just because im like that lol.
    i still had plenty of light left so thought id tackle the dogbone mount. two bolts at the front of the mount, two at the back, and a bar going across the subframe undone at one end to oull it out, very quick, very easy.
    bushes looked tired and were very soft, had left lots of rubber on the actual mount which was like chewed up gum.
    fitted the new red powerflex bushes and had a bit of a pain trying to get the bolt in by compressing it all but looks nice and pretty now, ready to rock and roll, or not in the engines case.
    the rear bushes to go in
    quite a productive day for myself.
    next job is to get the shafts out to change the cv boots and grease them up. take the shocks out to fit top mounts. and clean up wishbones and fit bushes and reassemble it all again.
    all will be updated soon hopefully.
    busy mountainbiking this weekend so will have try and fit some nights in and do bit by bit.
    so so looking forward to having it on the road again, all nice and tight, with new wheels, and a few other detailed touches later on.
    thanks for your time reading.
    stay super
    superkarl
    one last thing, can anyone tell me how tight i should do up the dogbone mount??? seems to just wind in forever, dont want to overdo it. thanks
    Jul 2010
    bristol
    647
    nice work mate, i did the wishbone bushes and droplinks a few weeks ago, although i polybushed the whole lot, ride comfort is still the same but the front end is alot more precise when turning in than it was before. interested to see what result the dog bone bush gives, tempted to do this next!
    going to keep an eye on this thread.
    Feb 2008
    2,817
    Great work. Ps it's Friday night.
    2000 AMK S3, Revo'd, forge 007p, B8's, H&R's, tarox g88's, ferrodo ds2500's, and in the fastest colour
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    nice bit of servicing,......
    From Show... to GO
    Nov 2010
    Stafford
    436
    im in the process of doing pretty much everything on your list, wishbones are out, ready to have new bushes this week.
    need to do top mounts and dog bone bush's..
    dont suppose you have a link to the red bushes?
    Also, not sure what top mounts im going for, I heard the seat leon cupra ones are a good upgrade. what have you had? are you not doing the top mount bearings at the same time?
    while mines off the road im having my rocker cover smoothed and polished, strut brace, charge pipe, inlet manifold and throttle body mirror polished,
    Im changing as many rubber hoses with silicone as possible, including fuel hoses. done the SAI delete, bypassed the N249 and N112.
    and today I spent 6hours degreasing, cleaning, t-cuting and generally sorting out the grimey bay ready for all its new polished parts :D
    I also got rid of the charcoal canister today
    Tomorrow im fitting my new dispstick tube, and nice white (instead of faded orangey) header tank.
    need a haldex service, with filter and oil, as my rear wheels feel like they are dragging abit on tight corners, and ive read a few people have sorted this with a service.
    Ian W's Avatar
    Oct 2007
    Wirral, Merseyside
    1,054
    Nice work there mate.
    I did all my front bushes, ball joints, drop links etc in September, the difference to the car was noticable straight away, a lot more planted and tight.
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,533
    Quote Originally Posted by S3 Rav View Post
    i can be slightly retarded sometimes lol. yay another day!
    thanks for the interest guys.
    Quattro1 the dogbone bush is real easy mate, and at only 18 its a no brainer if its not been done before. got mine from Awesome.
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,533
    Quote Originally Posted by coyle View Post
    red dogbone bush can be found on awesomes site really cheap too. my top monuts arn't lcr ones, however i found out about them after id bought these, il dig the receipts out soon to remember where i bought them, although i think it was ecp.
    From Show... to GO
    Nov 2010
    Stafford
    436
    just ordered the red bushes from awesomes ebay shop
    ive got a bad clunking from front drivers side, and my rear wishbone bush is identical to yours, realy badly split!
    so i dont know if replacing that alone will cure it, or if the topmounts need doing too. im going to try the bush first, see how it goes, then do top mounts if i need too
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,533
    id say clunking is down to top mounts. when i had my car on the ramps, i grabbed the wheel and shook like fook and it was clear the top mount was A)goosed B) loose. i had slight knocks over sharp bumps
    From Show... to GO
    Nov 2010
    Stafford
    436
    i get a sound like something is clunking, rattling around, does it worst when reversing and turning at the same time
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Turning the song up "heyyyyyyy macerena...always makes my noises dissapear.......
    From Show... to GO
    Nov 2010
    Stafford
    436
    that works, or putting the windows down to hear the chatter, i like that too!
    Audi TT A3 S3 Golf Seat Suspension Alloy Top Mounts on eBay (end time 03-Mar-11 14:54:14 GMT)
    these look good?
    finesse's Avatar
    Aug 2006
    London / Anglia
    2,814
    Good work, at the red diesel mount thread, I posted a PDF and it says what torque
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,556
    these look good?
    LCR top mounts would be a better option on a road car tbh... stiffer than std but a little give so they won't knock...
    <tuffty/>
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,896
    good work Karl
    Feb 2011
    southampton
    229
    looking good mate ..
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,273
    Good stuff matey. I did my dog bone last night and used the following torque settings to nip it up. I got these off the golf MKIV site:
    The bolt (& nut) which go through the middle of the dogbone mount need to be torqued to 45-55nm. The bolts which go into the chassis need to be 20nm & 90-degrees. And finally, the bolts in the engine need to be 40nm & 90-degrees.
    Hope that helps.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    ptr
    ptr's Avatar
    Aug 2010
    129
    Cheers for posting up karl, good pics!
    I think I need to do a complete overhaul of suspension components, visually they look shagged out and there's a lot of play in the steering and recently a knocking noise from front drivers wheel.
    How hard is it to replace bushings, cv joints and top mounts? I'm fairly handy with a spanner but never done any work on suspension parts.
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,533
    Quote Originally Posted by ptr View Post
    All this to follow buddy! More tomorow.
    cecilthesausage's Avatar
    ...It's Never Finished...
    Jul 2010
    Teesside
    933
    I have the same clunk when I go in reverse to do a 3 point like you Coyle. And when I put it up on a ramp it looks like the bushes in my swinging arms are fecked would that be my problem ?
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,533
    evening. bit more progress today, not too much as it was bitterly cold
    well first off i fitted the dogbone mount back in place, nice and easy, took around 20 mins to do
    had to remove the bolt in the bottom right corner in order to remove and refit it, by slightly pulling that bar across the subframe out.
    next up was to tackle the driveshafts and remove them to fit the new cv boots.
    so, with a screw driver in the disc to stop it rotating, and a rather long socket attatchment i cracked the the following bolts off, but only cracked them off for now
    once they were cracked off i removed the hub nut, didnt photo this, doh, but just took some muscle to undo. followed by very carefully hamering the drive shaft out of the hub itself.
    this left the shaft hanging out of the hub, but still attached on the inside, then simply undo the bolts i cracked off in the first place, and it pulls out
    the gaiter on the shaft was split all the way round, grease all over the show, a big horrible mess!
    anyway i didnt have a pair of circlip pliers and relevant ones to clip the new one back on so that will likely be done tomoro.
    other side was exactly the same procedure, only the outer boot was torn right at the end
    and a new one fitted, ready for the clips to be fastened
    once thats done they'l be fitted back, and wishbones and all bushes should be done soon, il try get some pictures of them on the press.
    danke
    Jul 2010
    Teesside
    933
    Roughly how much did all the bits cost you for this these jobs mate. Ive just had my track rod ends done on Friday and my bushes in my rear arms need doin as well cos 1 side is clunkin when I reverse, and I am thinking I may as well get everything done what you are doing.... Cheers Bud for a really good thread you have pushed me in the right direction just with my track rod ends done I can feel a difference, so with everything else it should really transform my car.... Cheers Rob
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Bust day karl, good work, first time ive seen a lower strut brace, doesnt look that it will do much, mine has been removed for some reason
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,533
    is that what it is? haha, had no idea, cant imagine it making much difference at all anyway.
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,533
    Quote Originally Posted by cecilthesausage View Post
    thanks for the compliments. i think its the right direction to go. not the first thing on peoples minds when they just want more power, which i do!
    il do a list of prices of bits and where from for you soon mate. il have to get all receipts out. kept them all for record.
  28. #27
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,533
    quick update.
    got the circlip pliers to get the inner cv joint off to fit the gaiter, so all the boots and joints were lubed up with the grease that came with the kits and they're all back together ready to go back in.
    then took delivery of these delicious items. 2x 45mm powerflex front wishbone bushes. and 1x tpi wheel spacer kit bought from the ttshop.
    the bushes went in the wishbones a piece of cake, its great having to just push them in by hand and not have to use a press.
    the rears i had someone press in for me, wernt too difficult apparently.
    and the spacers, well, i thought they were expensive at 195 delivered, but the quality of them is superb, with two different size bolt sets for the 15mm and 20mm spacers, and 4 locking wheel bolts, and 1 bespoke key. great bit of kit!
    nice shot of the wishbones complete, cleaned up, and ready to go back on
    and a before and after shot. not that il see the bloody things but keeps me grinning
    the next update will be me fitting all this back on, and removing the suspension to have the top mounts fitted.
    adios
  29. #28
    Westy's Avatar
    Dec 2008
    17,273
    Nice work Karl. All the suspension components are things I'm putting off till the warmer weather arrives. I take my hat off to you sir.
    S3 Build Thread
  30. #29
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Did that rear bush come off like that?? looks like it was about to fall out...some nice tidy work there, once you have got 4 wheel geometry done, it should handle like a dream.....
  31. #30
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,533
    noo that was after i hit it about 3 times with a hammer, did pretty much just plop out though. going to awesome once all this is done to have alignment done. cannot wait! hopefully it wont be too dodgy driving there.
    Quote Originally Posted by Westle View Post
    cheers mate, i would've waited for summer, but i couldnt wait any longer with the cv boots the state they were. just got to wrap up warm. hands dont half get cold though. and when i smack my knuckles, well i feel sorry for the neighbours the language that comes out! haha
  32. #31
    Chugger
    North Devon
    2,716
    Good effort. Iv got those spacers too, well worth the extra money I think, they are a quality item.
    No joke, out of all the cars iv owned, iv found the s3 the easiest to work on. The easiest CV boot iv ever changed. My MOT time is coming up soon, so no doubt I will be doing much the same work you are.
    Although the lower brace looks ghey, Im sure it has some purpose/use, no doubt its quite strong under compression!
    Question is... did you get new hub nuts? most people dont seem to bother
    57 A3 2.0 TDI Sportback (140)
  33. #32
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,533
    new hub nuts came with my cv boot kits from audi. which was nice. althought its not really needed is it
  34. #33
    From Show... to GO
    Nov 2010
    Stafford
    436
    are the front wishbone bushes the same on all S3's?
    Ive got to do the rear ones, so while the wishbones are off it makes sense to do these i think
  35. #34
    Mar 2010
    Durham NE
    578
    see you went for the TT front bushes ive got this set up and its far better than the powerflex set up that was in before !
    James
    Silver Audi 8L S3
    97 Fireblade fully restored ...just for summer!
    My old Corrado VR6 Turbo... Click me for the build DIY style!
    and many many cars and bikes in the past!!
  36. #35
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,533
    no there is two sizes, 30mm on very early cars, and 45mm on later models. wont positively know until you check.
    Quote Originally Posted by AudiS3-Turbo View Post
    well, they have the same wishbones, they're just the 45mm powerflex bushes. for S3/tt
  37. #36
    Mar 2010
    Durham NE
    578
    The stock S3 bushes have the voids in the bushes were as the tt have the solid type bush.
    James
    Silver Audi 8L S3
  38. #37
    From Show... to GO
    Nov 2010
    Stafford
    436
    James, you said TT front bushes, but karl fitted ppwerflew in the front and TT/ R32 in the REAR bush,
    Hence the confusion
  39. #38
    Apr 2007
    98
    I have just done the same to my front wishbone setup....however i went for full superpro setup. Apparently they are much closer to OEM than the ones used here. All i can say is that they are excellent, not harsh at all, just a lot tighter than before, and responsive......90 for bushes! but worth it : ) Doing the rear soon.
    Audi S3 AMK
  40. #39
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,533
    Quote Originally Posted by mrj0ey View Post
    Good to hear the difference it makes! Rear next for me too!
  41. #40
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Very nice karl, bet you cant wait to get the beast back on the road.
    What top mounts are you fitting, standard or LCR? Where have you ended up getting all your bits from?
