Sky InsuranceEM Tuning
Page 9 of 24 FirstFirst ... 234567891011121314151619 ... LastLast
Results 321 to 360 of 946
Like Tree228Likes
Thread: superkarls overhaul
  1. #321
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    Come to think of it Karl, when we did the logs on yours there was no slip at all. I've been in Dans' car when his clutch was on it's way out and doing logs it used to slip like mad!
    First car i've sat in with the B5 TIP and got to admit it sounds awesome and although MAF readings were the same as last time, the car did feel alot smoother and at ease. Like you say, i think you've maxed out the G/S for the standard boost/map
    You'll have to try my ECU
  3. #322
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,533
    Yeh i know it doesnt slip, but its like the clutch doesn't grip and transmit the power when launchong it, obv I dont expect it to instantly grip and go, that would break something, it just takes litetally a couple of seconds to grip.
    I was thinking before sandip, if were gonna play around with your ecu i dont think wed be able to, the ecus are immobolised with the cars/keys. So it prob wont work
  4. #323
    Mar 2010
    Durham NE
    578
    you wont need to reprogram keys mate if you are swapping ECU over,you will just need to adapt the ecu to your car and vice versa.
    http://wiki.ross-tech.com/wiki/index.php/Immobilizer_II_ECU_Swapping
    I
    ts easy,done it my self with this s3 of mine
    James
    Silver Audi 8L S3
    97 Fireblade fully restored ...just for summer!
    My old Corrado VR6 Turbo... Click me for the build DIY style!
    and many many cars and bikes in the past!!
  5. #324
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,533
    excellent news thanks dude.
    we just plan to have a play around, do some logs with his ecu, plus gives me a taste for a little more power.
    the map thats on it was a half finished stage 1 i believe, sandips car dyno'd 240. 18psi, slightly rich, so should be safe to play around with it. and see what sort of airflow il be getting.
    il deffo be getting a compression test done before hand though.
    tires are on order, then final setup of the coilovers height wise, and off to awesome for alignment.
  6. #325
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    6.6 is respectable in standard form Karlos.....more to come...
  7. #326
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,533
    Yeh considering standard timeis 6.8, and my wheels are near 2kg heavier than standard 17's.
    ive been considering going back to 17s, some wide lightweights, low offset. say 9 inch wide, run 245 tires.
    But that's another dream at the mo
  8. #327
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    yeah you cant beat light weight wheels very underrated mod... i got 5 secs dead a few days ago unmapped!
  9. #328
    Dane's Avatar
    Faster than a V12 Q7
    Cheltenham
    4,003
    Awesome work mate!
    My best at gti inters was 5.18s with standard avus'.... that ruined my clutch.
  10. #329
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,563
    I have my Avus's back on at the moment and I must say the car feels a little more nimble than on the 18's...
    <tuffty/>
  11. #330
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,273
    <tuffty/>
    I'm currently hunting for some new wheels. The difference between my S4s with adapters compared to my 17" avus with no spacers or adapters is amazing. Turns easier, feels more responsive, feels a LOT lighter!
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
  12. #331
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,533
    dane, dave, awesome times!
    i imagine you do those with just the one gear change, hitting 60 in second?
    wheels are massively overlooked as a performance mod, i knew instantly the difference when putting my 18's on. it annoys me lifting them off when doing work on the car, constant reminder of whats letting the car down.
    trouble is, i ant find many lightweight wheels out there that will fit the s3 well and actually look good. there isnt a great deal of choice.
    i did find a nice set of impreza prodrive wheels though, but impreza wheels tend to have really high offsets of around 40-45, which isnt ideal.
  13. #332
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,563
    <tuffty/>
  14. #333
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,533
    Bloody show off!
    Q for you Paul, does bill raise the rev limit when putting generic maps on? Is it part of the map, Or would this be done on request?
  15. #334
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,563
    Bloody show off!
    He can raise the limit on the maps he does but not the Revo IIRC... not sure what he normally does but on the hybrid and BT stuff he normally takes it to 7.4k to 7.8k depending...
    <tuffty/>
  16. #335
    Nov 2011
    Sturminster Newton
    190
    When you put your AP's on did you not have to put adjustable drop links on?
    A3 1.8TQS Minge blue
    Mods: AP coilovers, Strut Brace, Merc wheels, S3 brakes, hopefully going BT soon
  17. #336
    Westy's Avatar
    Dec 2008
    17,273
    Quote Originally Posted by Grazam View Post
    You don't need adjustable drop links on these cars mate only adjustable tie bars.
    S3 Build Thread
  18. #337
    MURRAYS444's Avatar
    Aug 2009
    Edinburgh
    789
    Loving the work Karl I got a B5 TIP this week and seeing a picture of it with the other one makes me glad I bought it how are the coilovers feeling on your car?
  19. #338
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,533
    Quote Originally Posted by scottm4 View Post
    coilovers feel great! couldnt be more pleased.
    il be even more pleased when i get alignment at awesomegti on wednesday (ya can tell it needs doing, still improvements with braking stability to be made)
    you'l love the B5 tip. i just need more boost now getting hungry
    il get an up to date pic of my car this week. im not gonna lie, its looking good now its at a respectable low
  20. #339
    MURRAYS444's Avatar
    Aug 2009
    Edinburgh
    789
    Aye gonna have my car remapped next month i'm wanting to lower my car to but not to sure if coilovers are gonna happen as my driveway has an incline at the front where my bumper already scrapes might just have to settle for lowering springs instead!
  21. #340
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,533
    if it already scrapes you'l need a new driveway even with lowering springs! lol
    im after more power too, but i think an engine rebuild would be a good investment, then i can up power to my hearts content.
    otherwise il just get all the bolt ons available and mapped, then run it till something dies.
    but i like to be sensible.
  22. #341
    MURRAYS444's Avatar
    Aug 2009
    Edinburgh
    789
    Haha aye mate stupid driveway just drive it in at an angle my clio was lowered by 30mm and it was fine but less overhang if you know what I mean!
  23. #342
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    15,456
    Get a pic up Karl. Glad your happy with the collies.
  24. #343
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Quote Originally Posted by Sandra View Post
    X2
  25. #344
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,533
    some pics i posted in the pics thread:
  26. #345
    s3 Hoggy's Avatar
    Whats going on???
    Apr 2009
    Oxford
    1,653
    Visit s3 Hoggy's Instagram Channel
    Looks awesome bud!
    2002 S3 REVO
    Milltek, Sachs Organic clutch, 007p, Genuine RSTT's, BBS RS2's
    Koni FSD & H&R springs, Neuspeed 22mm rear ARB, KW tie arms
    LCR Brembo's with DS2500's & Paul's 300mm Rear disc kit,
    Michelin Pilot Sport 3's,Badger5 V2.2 Jetex filter & heatshield
  27. #346
    s3 Hoggy's Avatar
    Whats going on???
    Apr 2009
    Oxford
    1,653
    Sunset is the best time for Ming blue, makes it look so slick
    2002 S3 REVO
  28. #347
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,533
    Quote Originally Posted by s3 Hoggy View Post
    thats why i waited till about half 5 to get the pics! hehe!
  29. #348
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    That looks spot on Karlos....great pics...
  30. #349
    Mar 2010
    Durham NE
    578
    hot dang thats nice....i wish my heap looked as good
    James
    Silver Audi 8L S3
  31. #350
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,533
    service time comes far too quickly!
    been doing alot more miles recently too, so she's getting on a bit, but drives great still
    new:
    oil
    oil filter
    fuel filter
    pollen filter
    spark plugs
    discs
    pads
    although, as ever, problems and niggles are found....
    i jack the car up to find oil all over the sump, gearbox, dogbone mount, subframe, lower strut brace.
    now its allllways been dry as a bone, so quite a surprise, so i started cleaning it up and hunted for a source.
    above was my first idea, the seal on the gearbox, i think? but i thought that would be unlikely to just go so sudden.
    i then noticed how thick it was on the front of the sump, and realised that the dip stick tube was directly above this, circled.
    turns out theres loads of thick oil/sludge here. and its always baffled me how the orange dip stick tube just slots onto the pipe going into the engine/sump, no seal at all, so i've come to the conclusion that this is where my leak is, and the oil is leaking down the sump to the back and splashing/spraying onto the dogbone and subframe.
    cleaned up ready to be checked again soon.
    i did take the dipstick tube off, and snapped it, doh! but its back on in 2 pieces and i tried sealing the tube onto the tube on the engine, in the hope it will fix the leak. but now i need a new tube.
    my question is, will the tube be ok in 2 pieces with the car being used in the week??
    will oil be going everywhere? it is snapped right at the top.
    so after the service was done i turned my attention to fitting my forge short shifter which has been in the boot for a few weeks now.
    however, another issue, how on earth do these gear cable ends come off??
    mine are the ball ends without circlips, so i assume they just forcefully pop off?
    i did try with quite a bit of force but they wouldnt budge.
    is there a nack to this??
    i really done want to break them. and really want a shorter throw!
    thanks for your time/help/thoughts.
    peace
  32. #351
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    I hope it wasnt the "bird week" with a finger like that Karlos.....
  33. #352
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,533
    Reesys mum mate, diiirrrrtty *****
  34. #353
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,003
    On the end of the cables, near the ball join and the spring. That erm.....ring or what ever the name is for it, that pulls towards the ball join and quarter turn it clips in and releases the cable.
    No idea how the call joint comes off. The joins on the Pugs gear box is forcefully removed with allot of effort but really easy to put back on.
    New Car, New Thread: Scott's Akoya Silver A8
    Gone But Not Forgotten: Audrey's Build Thread
  35. #354
    Westy's Avatar
    Dec 2008
    17,273
    westys mum mate, diiirrrrtty *****
    I was just about to give you some helpful comments and you've gone and ruined everything now........
    Wnkr
    S3 Build Thread
  36. #355
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Karl get over to forges website, you can download a pdf file that gives you a step by step guide.
  37. #356
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,533
    just says they pop off? THEY DO NOT JUST POP OFF!
    im just gonna have to go for it arent i.
    word of advise for anyone contemplating running there car with a broken dipstick....DONT
    oil everywhere!
    i lost about 3-4mm on the dipstick today, did about 40 miles, had no choice
    ordered a dipstick tube first thing this morning through TPS, fitted it this evening, used sealant where the tube connects to the engine.
    part number: 06A103663B
    got 4% discount and it came to £3.76
  38. #357
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Think they need some force mate.
    Damn that is bad, bet you loved cleanin that little lot up.
  39. #358
    Reesy's Avatar
    East Sussex
    3,604
    Did this ever get sorted Karl? And what was the crack with those trailing arm bushes...
  40. #359
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,533
    Quote Originally Posted by Reesy View Post
    yep, got sorted that night with a new dipstick tube, a sh*******te load of degreaser and some elbow grease, oh and some oil to top up. its not leaking anymore.
    you know the deal with my trailing arm bushes you cheeky yut. they'l get done along with the rest of my pile of car stuff thats accumulating in the garage:
    rear discs
    rear pads
    haldex controller
    downpipe & decat
    trailing arm bushes
    and a FMIC which is with an insanely skilled fabricator getting 63mm pipes put on.
    heres todays news. a mini detail:
    first minor detail of the year
  41. #360
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,533
    porsche coolant and oil caps:
    thanks to scott
    i just really want a black washer bottle cap now.
