Volks AutosEM Tuning
Page 5 of 23 FirstFirst 12345678910111215 ... LastLast
Results 161 to 200 of 912
Like Tree211Likes
Thread: superkarls overhaul
  1. #161
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,455
    hard to photograph, looks more apparent in the flesh..
    hoping awesome will dial abit of that out
  3. #162
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,156
    That's on standard springs and shocks isn't it?
    I'll get a pic later but I'm sure mine is the same if not slightly worse on a 25mm drop.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
  4. #163
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,455
    yeh standard springs and shocks.
    here is the settings il suggest to awesome,
    Front
    Camber -1.3�
    Toe 0�02 (2 minutes toe out)
    Rear
    Camber -1.0�[/QUOTE]
    Toe 0� (Parallel)
    based on the info, tests and advice in here:
    S3 Suspension and Set-up Guide
    il see what awesome say to this of course
  5. #164
    Westy's Avatar
    Dec 2008
    17,156
    Here's mine. Crap pic I'm afraid
    S3 Build Thread
  6. #165
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,455
    Is say they're the same and mine isn't lowered.
  7. #166
    S3Steve's Avatar
    Sep 2005
    Peterborough
    1,588
    Rear camber isnt adjustable without adjustable tie bars mate, the only thing they will do at the rear on a standard car is adjust the toe.
    2007 A3 TDI 170 S Line
    Sold - 2002 S3
  8. #167
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,061
    Quote Originally Posted by Westle View Post
    Yours is crying out for arms.....
  9. #168
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,061
    Yours could be the bushes karl
  10. #169
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,455
    Haha and where do you suppose he gets those?? Hmmmmm lol.
    Yeh I think you could be right, which makes me think twice even more about gettin it aligned before I've done the back.
  11. #170
    Westy's Avatar
    Dec 2008
    17,156
    I think you're right Dave. Be in contact soon.
    S3 Build Thread
  12. #171
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,455
    done next to nothing on the car this weekend, which is boring, only gave it a wash, and did some touching up and polishing on the paint
    she looks well though.
    ordered some powerflex anti roll bar mounts so that'l be the next job, hopefully get that done before my trip to awesome. im not gonna try and re bush the rear before i go there because its quite alot of work, well, labour intensive anyway.
    on the other hand i have some bike porn for anyone thats interested.
    fitted a K&N to a cbr600rr-5.
    airfilter is under the tank and under the main ecu
    heres a comparison between the two filters, strangely the k&n was slightly smaller, but its clear it will flow a hell of alot better than the standard one
    this i thought was pretty cool and id never seen before, as you can see it has injectors here, which i was like, this cant be where they are, right before the throttle bodies??
    turns out it has two stage injectors, a set which are direct port injection, and then upon full throttle, or roughly 90% as we found out, these come in before the throttle bodies mixing with the what would be ram air.
    took a video....
    pretty freaking cool to me
  13. #172
    Westy's Avatar
    Dec 2008
    17,156
    Nice stuff Karl. Car is looking mint. I really like the yello s3 badge but I think you should get a plain nurburgring sticker (like mine) but in yellow
    S3 Build Thread
  14. #173
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,455
    haha i've already thought about that sticker, got to go all the way back to earn a yellow one though haha. plan is to buy a yellow one and put it on upside down, this was the idea with the one i've got, as i span on my first ever lap. woo go me, schumacher.....naaaaaaatttt.
  15. #174
    Feb 2011
    southampton
    229
    looking good mate keep up good work ..
    audi s3 2001 amk 210bhp, forge 007p
  16. #175
    Westy's Avatar
    Dec 2008
    17,156
    Haha good idea mate. I'll try not to spin when I go later in the year
    S3 Build Thread
  17. #176
    Inertiauk's Avatar
    Mar 2011
    529
    Maybe a late reply, but I think I spot your mistake which caused your coolant leak, the O ring doesn't go between the stat and the block, the stat sits directly into the block and the O-ring goes over that then the housing on top.
    I made this exact mistake myself, got frustrated, but finally figured out where I went wrong thanks to google.
    http://pictureposter.audiworld.com/62820/p6300018.jpg
    Thermostat replacement procedure..>> - AudiWorld Forums
    __________________________________________________ __________________________________________________ _
    Driving a 2004 B6 Audi S4 - Stage 2
  18. #177
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,455
    Ha yesss I'm not alone, I was gutted when I took the stat out again and realised what id done. All sorted now though.
  19. #178
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,455
    my latest goodies...
    still waiting on some 45 degree 19mm to 15mm reducers to come and a couple other bits, as the can has 15mm outlets, biggest i could find. its quality though, and only £25, its all the pipes and joiners that all add up though
    big thanks to westle and his catch can thread! gave me abit more confidence to actually do it.
  20. #179
    Westy's Avatar
    Dec 2008
    17,156
    That looks nice mate. Will you vent to TIP or to atmos?
    S3 Build Thread
  21. #180
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,455
    Venting it to atmosphere so ive got a breather filter on the way too. Hope your right about there being no smells.
    I think I might fit it to the side of the battery casing, don't want to move that fuse box at the back tbh as I want to put the n249 in there. Not sure though, prob look better tucked away at the back, but having it at the front its easy to drain.
    One more thing too, should I pack it out with wire wool?
    dusty likes this.
  22. #181
    Westy's Avatar
    Dec 2008
    17,156
    S3 baby has tried his with and without wire wool an it did a better job of collecting oil with the wire wool.
    S3 Build Thread
  23. #182
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,616
    I love seeing new goodies waiting to be fitted,keep up the good work Karl (making us jealous)
  24. #183
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,455
    Hardly jealous, my thread is a boring one as it doesnt have a turbo the size of a small car lol.
    Ive got plenty of work to do though, all in good time
  25. #184
    Westy's Avatar
    Dec 2008
    17,156
    I wish I'd done a thread like this now as all my work is dotted about in different threads. I've got some shiny stuff to go on too.
    I might merge all my threads into one.
    S3 Build Thread
  26. #185
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,616
    Say the words and I'll do it (well I'll try)
  27. #186
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,455
    Yeh make one westle. I only really did this to put my bush work on as I'd never seen anyone put the work involved up. It's handy just putting it all here though.
  28. #187
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,616
    Hardly jealous, my thread is a boring one as it doesn't have a turbo the size of a small car lol.
    Not at all because it all adds to the forum and members get ideas,I saw one a while back cleaning the sump which has no value in horsepower but helps the engines life...all good
  29. #188
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,455
    making a trip to awesome today for alignment. hopefully get soime advise on my bizzare camber on the rear even though its not lowered. driving bumpy back roads fast and the rear is very lively over bumps, want to get it more planted.
    on a more negative note, spending on the car is going to cease, i owe me and my girlfriend a holiday. apparently ive been spending too much on the car?!? is that even possible???
  30. #189
    Westy's Avatar
    Dec 2008
    17,156
    Karl do you think it could have anything to do with the wheels and spacers you have on that's effecting the camber?
    I know the feeling. In June I have a holiday with the bird, my car insurance, a car service, a turbo refurb, and a 4 wheel alignment! I'll be broke.
    S3 Build Thread
  31. #190
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,455
    no i cant see how it could have anything to do with that, i had noticed it with my old wheels, its just since fitting these ive been looking alot more lol. i reckon its down to bushes personally, that together with my car doesnt sit all that high for standard suspension compared to some ive seen.
    powerflex for the rear end might sort it out, if not il give dave a bell and have some of his tie arms.
    rear powerflex kit is £130, doesnt seem hard to do either. but, ive got to think about a holiday lol ...............i could do with one to be fair.
  32. #191
    Westy's Avatar
    Dec 2008
    17,156
    I got a set of Dave's tie arms the other day. Lovely piece of kit and a cracking price.
    ps. have a holiday at the Ring see my sig.
    S3 Build Thread
  33. #192
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,061
    Women only take so much and then start moaning......only when there bored though...put on this earth to stop our fun....fak em..
  34. #193
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,455
    yeh they look awesome.
    haha i've tried suggesting that mate, but its not a 'holiday holiday' no beach, no sun, no sea etc etc.
  35. #194
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,970
    I'm running the standard -10mm springs and 15mm spacers and mine has similar negative camber at the back to yours. This is AFTER having 4 wheel alignment done at Awesome....it's worth noting that I don't experience uneven tyre wear at the rear either.....go figure?
    > S3 225 (03) - OEM+
    > 205 GTI (90) - Limited Edition Miami Blue with full leather - 1 of only 300 made
    > Clio v6 255 (05) - Lethal Weapon
    View: My S3 diary
  36. #195
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,455
    Quote Originally Posted by Funky_Junky View Post
    thats interesting, and no uneven tire wear, you must go HARD round corners. well il see what they say, i dont want too much to upset the handling, based on what i've read -1 degree of camber on the back is about right for a good fast road setup. how did your car feel after having it done by them? im literally about to set off now
  37. #196
    Westy's Avatar
    Dec 2008
    17,156
    Ok then just treat yourself to the Ring
    I've found that my car turns in so much better with the slight camber I have on the rear. I quite like it but I wont like forking out for new 18" tyres if they where out.
    I too haven't noticed any rear tyre wear....... yet.
    S3 Build Thread
  38. #197
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,970
    The handling was much improved but that could be down to the fact the fronts were way out. I've still got the print out so I'll get it posted up to compare with the results of yours. Good luck!
    > S3 225 (03) - OEM+
    View: My S3 diary
  39. #198
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,455
    the way im looking at it is, more camber - less contact patch, even on hard cornering too much camber won't have the whole 225 tire in contact. so i think -1 degree should give a good say 80% contact most of the time, then hard cornering should give 100% contact for optimum grip. less camber should = less twitchyness over bumpy roads too, something i think ive got as only half the tire is on the road and bumps are soaking up through less rubber.
    to put it into perspective, some of the nobbles on the tires are still there on the outside of the rear, and i've thrown it around good style
  40. #199
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,970
    So, how did it go?
    > S3 225 (03) - OEM+
    View: My S3 diary
  41. #200
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,455
    Fronts were way out on toe, so now they're right. The rears are shocking. The fella said that rebushing it might sort it a tiny amount but to correct it fully il need adjustable tie bars. He did say it was common they have a lot of camber.
    But, front feels a lot better now.
    Il upload my print out when I get home.
