Sky InsuranceBadger5
Page 12 of 24 FirstFirst ... 2567891011121314151617181922 ... LastLast
Results 441 to 480 of 937
Like Tree214Likes
Thread: superkarls overhaul
  1. #441
    Feb 2012
    bedfordshire
    737
    Top work mate looking good need to take on this mission in the near future
  3. #442
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,520
    been a BUSY weekend!
    fitted my 3 inch downpipe and decat today.
    was absolutely dreading the job after what people said but it wasnt THAT bad.
    total time, from getting on the ramp to driving off the ramp, about 2hrs 30 mins.
    some tips for anyone and what i did:
    • split the downpipe at the flexi pipe, wiggled till it came apart, and prised it apart with a bar, this leaves just the top turbo bit of the downpipe, meaning much better acces to the bolts.
    • next, stubby spanners, ratchet spanners are a plus but ours were too fat.
    • facing in the cars direction, bottom, and rear most nuts off from the bottom and through the drivers wheel arch. top nut off from the top of the car
    • now, use all your magic to wiggle the top part of the downpipe out through the bar of the bay from underneath.
    • then, take your flange from the OEM downpipe, place it on the flange for the new one (in my case xspower) my new one was slightly fatter, and the oem one was difficult enough to get out so, i grinded the flange of the new one to about 0.5-1mm smaller than the OEM dp flange.
    • next, undo prop at the front of the car (3 bolts, then under a heatshield there is a centre join in the prob, undo its mount so you can slide the prop off (its on a spline), this gives you more room to fit the downpipe in.
    • use ALLLLLL your magic and determination to get that new downpipe in, i put mine in turned the wrong way, then once in the gap, turned it round.
    • now fit your dp with nuts in which ever order you like, the same ways you removed the OEM.
    • re-attatch prop, charge pipe, exhaust, any other bits and bobs, and see how it sits.
    • i had to knock my heatshield slightly to stop it contacting.
    • and FINALLY, prepare to jizz your pants as you start your engine and here the mighty growl of the exhaust!
    im so happy with the way it sounds, i expected it to be REAAALLY loud with my bodged OEM exhaust but its not. It still has the same annoying drone, but the growl and gargle is just EPIC!
    this weekend im tired, exhausted from heat, sunburnt, but the work on the car is done and dusted! it waits for it mot now.
    good day everyone
  4. #443
    Feb 2012
    bedfordshire
    737
    Good stuff mate thanks for the info to will help when I take this on
    know how you feel with this heat and working on cars does you right in
    Atb
    Dre
  5. #444
    Jay A3's Avatar
    come fly with me
    Mar 2011
    Greenhithe, Kent
    1,772
    Some one has definitely been a busy boy! Loving the work mate and how your car looks with the fmic! Over the moon with downpipe? Get a video up of the "growl" ASAP!
    <Jay A3 build thread>
    241bhp K03s - R Tech
  6. #445
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,318
    Sounds great karl, top work lately man, it's moved along so fast!
    Now it's time to man up and get some boost on the go I think! Get it mapped!!!!!
  7. #446
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,520
    il try and get a vid made with a go pro. i know i've said id do that but now i definately will!
    prawny, i think you are right, bout time for some boost!
    i'l have to leave the car alone for a while now, spent alot recently, not just on the car, so il let my balance recover.
    i hope i can get some R-tech treatment in the next couple of months!
    my only worry is the clutch il cry if it slips when i get mapped
  8. #447
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    15,343
    Karl, car is looking well good. You have been busy this weekend. Top work. X
  9. #448
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,520
    tiny update.
    got some fancy show plates that im painting/putting together, just for a cheap fun mod really.
    also, i've decided a cambelt and all the other little bits should be done, piece of mind really. its been over 3 years and 32k miles since the last one. i like to be cautious, afterall it wasnt done in my ownership.
    il have a go at this myself with my dad keeping a watchful eye on the situation, always good to learn when you can.
    and lastly the car is running great. pulls sooooo well right now. i would like to fit a boost gauge to see what its doing but i think il just do some logging sometime.
    oh, and i've still not been to awesomegti, hopefully going this thursday. Ive fitted 2 new tyres to the rear (3rd set 12 months), but when i visit awesome im taking my old ones so they can have a good look at them. i hope to get the alignment sorted. i mean to me the car handles great already, but clearly there are improvements to be made.
    my next future plan/idea, thats always in the back of my mind, is do i buy a large port engine to rebuild and swap. hmmmmmmmmm. time will tell.
    for now, happy motoring gents
  10. #449
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,632
    Looks great karl! I seen an AGU a3 for sale on the classifieds, worth buying and breaking.. was my plan but things change lol! FMIC looks nice though! i want one.. and a downpipe!
  11. #450
    damo.h's Avatar
    DVLA Say it's Black
    NW
    3,608
    Nice work scouse. Sounds like you've had a ****ter with awesome tho. Hope they come good and offer some sort of compo for trashing yr rears. So I take it we ain't going R-tech this month then
  12. #451
    Dane's Avatar
    Faster than a V12 Q7
    Cheltenham
    4,003
    Free revo for wrecking your tyres...
  13. #452
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,520
    Quote Originally Posted by damo.h View Post
    i dont think i will for a while
    im going to london in 2 weeks, and then theres inters, plus for my map i still need to do my cambelt etc, plus a 007p ideally. so im way off mapping for a couple of months.
    Quote Originally Posted by Dane View Post
    id never trust them to map it!
  14. #453
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    One of the best looking IC installs on here IMO, well done Karl!
  15. #454
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,968
    Shame about the bumper
    New Car, New Thread: Scott's Akoya Silver A8
    Gone But Not Forgotten: Audrey's Build Thread
  16. #455
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,520
    well pleased with these:
    painted ming blue with chrome decal.
    il upload a picture of them on the car once i've lacquered them
    also, should i fit this:
    its momo, solid steel, weighs a ton!
    hardly oem, but i was thinking it might not look too bad, and might feel good to use. its been sat around my house for yeaaarrrrrrrs, never been fitted to anything
  17. #456
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,968
    Nice plates Karl.
    Bout time mate.
    You do like a nice polished knob in your hands.
  18. #457
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,520
  19. #458
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    15,343
    Liking the plates very much Karl. x
  20. #459
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,520
    went to a specialist today that makes custom exhausts.
    got a quote on a 3 inch catback and got booked in for the 18th.
    then found out about another exhaust.
    we'l see what happens with that.
    also booked in to awesome gti next wednesday to rectify my alignment problems. looking forward to that, as john on the phone said 'lets put this issue to bed'.
  21. #460
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,317
    lol at those alignment figures.
    Its quite clearly 1.7 degrees total toe, which is completely mental.
    You want factory toe on the rear (circa 8 minutes toe in per side) and a touch of toe out on the front to provide nicer turn in.
    TD5 Land Rover Defender build
  22. #461
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,520
    its nuts isnt it.
    i have parrallel toe on the rear, and im happy with that. i did also consider slight toe out on the front, but with how well the tyres are wearing im going to leave it at parallel.
    i think in the end, id like a tad more camber front and rear, sometimes i find when pushing hard it can slide out and tyre squeel, like there isnt enough camber to combat the roll of the car and im losing my contact patch.
    i do drive quite hard, but at the same time i want as long out of my tyres as possible. who doesnt!
  23. #462
    Danio's Avatar
    AUDI-MANIACS.COM
    Aug 2011
    Skelmersdale WN8
    187
    Karl how much they want charge you for custom back box??
    Currently not in the country
  24. #463
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,520
    Quote Originally Posted by Danio View Post
    was quoted £360 for a 3 inch catback with one large box mounted sideways at the rear, milltek stylee, any tips you choose.
    that was at DCMS in burnley. Good reputation, my mates company uses them regularly.
  25. #464
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,088
    That was what I said about Hayward and Scott but look how my luck turned out lol
    I'm sure they'll do a lovely job
    Power & Torque 335bhp 285ftlb
    0-60 4.64 1/4 mile 13.02
    My GTX3071r Build Thread
    http://www.audi-sport.net/vb/a3-s3-f...ld-thread.html
  26. #465
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,520
    Quote Originally Posted by StaceyS3 View Post
    id hope they do a better job than H&S!
    and, luckily for me, and i wasnt going to reveal it till i had it with me and could take pics, but i've got hold of a brand new milltek non res with slash cut tips for a BARGAIN!
    which reminds me i need to cancel my booking for a custom one....
  27. #466
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,088
    Nice one mate milltek ftw
  28. #467
    BENJAMIN's Avatar
    Mar 2011
    466
    Centre section was not on back order and should be with me early in the week. I'll call you as soon as it lands dude.
  29. #468
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,520
    cheers ben
  30. #469
    Reesy's Avatar
    East Sussex
    3,604
    Quote Originally Posted by BENJAMIN View Post
    Not a 4 week wait then
  31. #470
    BENJAMIN's Avatar
    Mar 2011
    466
    Quote Originally Posted by Reesy View Post
    Last one was 8 in total!! The wrong one was cheaper though! Lol
  32. #471
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,520
    busy day, driven 90 odd miles today to visit awesomegti to have my car looked over/diagnosed regarding the excessive rear tyre wear.
    first thing il say is thankyou to them, despite the troubles i've had (not all their fault) they have been very helpful, willing and kind to have my car in today for a good 2 hours free of charge.
    so i got my car in to them, went through to the workshop with the mechanic and discussed what had happened, what was on the car, my theories, and also showed him one of my 2.5 month old tyres that was completely buggered and clearly showed some tell tale signs of wear and toe in.
    after a good while in the waiting room i was called out to the front where another mechanic was going around in circles. His theory was that the rear diff was on its way out and the wheels were rubbing in corners and therefore causing the wear. I took what he said on board but i've never personally experienced rubbing, although i know its common. even IF that were an issue i dont personally think it would cause this:
    in just 2.5 months of driving and roughly 1500 miles, if that.
    also, even if the rear diff was a possible culprit, the toe in would still be excessive and out of spec in the first place and would still need addressing. so, they proceeded to put it on the alignment ramp, got it all setup and the readings taken, i was called to the car and shown my current settings, to which the mechanic then AGREED there is excessive toe in, out of the specifications. just what i wanted them to acknowledge, we're getting somewhere.
    so after some discussion and me identifying that there is still some adjustment where it could be dialled out the mechanic said he would try his best to see what could be done.
    moments later the mech had reduced it by 0.20, but STILL it was 0.75 OUT of the max limit.
    this was when some serious head scratching went on.
    the ONLY thing left to consider is the trailing arm bushes. everything else on the rear end is new and uprated, so this one bush may be a weakness that the other modifications being stiffer, have highlighted.
    so the next step is to replace these with powerflex poly items, and then i will see where its at.
    i also mentioned to the mech, that this bush/mounting is located to the chassis by 4 bolts and is through some slightly elongated holes (giving minimal side to side movement) and i may look into modifying these larger (like is done with the wishbone ball joint holes), to hopefully give me that extra mm or 2 to get the settings within spec. i just hope there is enough outward room before the bush fowls the chassis.
    hopefully this will sort the issue out. i need the toe as parrallel as can be, then, if the wear continues, i can accept the mechanics suggestion of the rear diff. which as i say i think is unlikely, seems ok to me.
    here are my latest printouts:
    so i need my rear toe within 0.20, and thrust angle at 0 and i will be happy.
    on a more positive note! i picked up this:
    shiny new milltek back box for a hardon inducing £150!
    loving the slash cut tips.
    just waiting on my mid section now, which i also got for a great price.
    which reminds me, the O2 network has been down today since about 1 o'clock. i went to O2 in the trafford centre because i was stressing there was something wrong with my phone/network/account, turns out they are having technical problems and only notified the engineers when i, amongst a million other people went in to complain.
    so ben, if you have tried to phone and not got through, you know why.
    same for you sandip, i could've met up with you today, i was there till 3 o'clock, ended up going to KK's for some donuts too win
    cheers all for your interest and comments.
  33. #472
    damo.h's Avatar
    DVLA Say it's Black
    NW
    3,608
    Finally getting somewhere dude. Glad awesome came good and you didn't have to piss on the counter
    £150....... Dam you scousers !!!!!
  34. #473
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,520
    so i got my milltek on....
    first impressions, borrrrrinnnng, its not very exciting from inside the car, i have a 3 inch downpipe and decat too but it is SO tame from inside, which i guess is a good thing, but i enjoyed the scream of the old exhaust after 4k rpm.
    anyway i got a friend to video it as he said its got a good growl to it, and watching them back i though 'eh, that aint too bad actually'. My dad also took it for a spin and i was quite impressed by it once id heard it drive off.
    its quite an amazing piece of kit really, so well made, fits perfectly, so so quiet inside the car, yet sounds like an animal when you're behind it. overall im really happy
    MASSIVE thanks to:
    ben @ parsons performance
    reesy
    sandip
    awesomegti
    they all helped me find a brand spanking milltek for a VERY good price
    my mate who recorded the videos tells me he'l upload them to youtube so il link them as soon as i can.
    only bummer is, relentless idea of 2.5 inch is obv alot different to millteks idea of 2.5 inch, so the milltek reducer isnt very snug on the decat so i do get a tiny blow. its either that or the decat is made of thinner wall steel.
    but il be getting rid of the 2.5 section at some point making it 3-2.75 inch. flanges or just slip on and clamp im yet to decide.
    after the exhaust, gave the car a clean, emptied catch can as per, she looks all pretty, ready for some more progress soon (trailing arms, haldex controller).
  35. #474
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,748
    It gets better with time!
    Also, you can hear it more if you have firmer mounts (you can hear more of everything though!) which also help tighten gearshift and feel.
    Handling mods++. GTX30 soon-ish. Hiding parts from the mrs since 2011. Build thread
  36. #475
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,264
    It'll never compare to your de-baffled OEM backbox madness! I did find that the exhaust mani made my whole exhaust system louder so maybe that's a future mod for ya
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
  37. #476
    Reesy's Avatar
    East Sussex
    3,604
    Quote Originally Posted by Westy View Post
    I've told him this as well.
  38. #477
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,520
    video as promised.
    il get some better ones with a hd camera at some point
  39. #478
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,968
    video as promised.
    1080 and 5.1 please.
    Thank you.
    It don't sound to bad Karl.
    Looks good though mate.
  40. #479
    Feb 2012
    Pie eating land
    1,289
    Follow ruffrida On Twitter Visit ruffrida's Youtube Channel
    done next to nothing on the car this weekend, which is boring, only gave it a wash, and did some touching up and polishing on the paint
    she looks well though.
    ordered some powerflex anti roll bar mounts so that'l be the next job, hopefully get that done before my trip to awesome. im not gonna try and re bush the rear before i go there because its quite alot of work, well, labour intensive anyway.
    on the other hand i have some bike porn for anyone thats interested.
    fitted a K&N to a cbr600rr-5.
    airfilter is under the tank and under the main ecu
    heres a comparison between the two filters, strangely the k&n was slightly smaller, but its clear it will flow a hell of alot better than the standard one
    this i thought was pretty cool and id never seen before, as you can see it has injectors here, which i was like, this cant be where they are, right before the throttle bodies??
    turns out it has two stage injectors, a set which are direct port injection, and then upon full throttle, or roughly 90% as we found out, these come in before the throttle bodies mixing with the what would be ram air.
    took a video....
    pretty freaking cool to me
    Ohhhhhh bike pron, love it lol
    B6 1.9tdi Quattro Avant Sport:
    My Build Thread = http://www.audi-sport.net/vb/a4-a4-c...so-begins.html
    Coming soon: -35mm Springs, Colour coded FOG grills, Trip stalk upgrade.
    Wish List; FMIC, BV43 turbo, Bigger Remap, Fat Clutch,Full Stainless, S4 Brakes, 5m mspacers - front, 10mm spacers rear, MFSW.
  41. #480
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,318
    Is this mapped yet or is it still gay?
    ruffrida likes this.
