- Joined
- Oct 27, 2006
- Messages
- 2,851
- Reaction score
- 110
- Points
- 63
On my drive home last night i was moving in trafic , not at any great speed but moving steady. The lights up the road turn to red... i brake and......
NOTHING!
pedal to the floor, no reduction in speed at all,
I ended up swirving and just bumping up a kerb, A damaged undertray is all the damage but... why no brakes??
I then plug in vag com and get one code...
00810 sensor 1/2 for brake preasure
27-10 implausible signal- intermittent
so clearly i have a leak, but where?
no obvious signs so i drive using the hand brake to get home, After jacking the car up i find the rear drivers wheel is all wet , a little more of a look around and it turns out the rear brake hose ( the section to the rear caliper ) which has a solid section and a rubber section had failed.
When i went to pick the new hose up today i was told "ye, they fail there quite alot "
What the hell ! has anybody else had this problem?
I was very lucky to not be ordering a new front bumper as well as the hose !
NOTHING!
