    Feb 2011
    6
    2005 A3 1.6.....ruined (i think!!)
    Hi,
    I think my A3 is about to give up the ghost! The E.S.P warning light came on two weeks back, and has remained on almost constantly ever since, although it does intermittently turn off! Since yesterday its started to play up when starting, starts eventually but takes a little while to make its mind up! Then, when it does start the revs keep dropping out when idling causing the engine to stall every now and again, and to sound like a Sherman tank constantly! Then when I do eventually start accelerating it feels like the car is lacking in power, with intermittent surges of power like a turbo is kicking in....except I don' have a turbo!!!!
    Any ideas what might be causing all of this? I want to sell the bl**dy thing soon so I want to get it sorted as soon as possible!
    Thanks for any help
    May 2006
    Lancs
    211
    If it's a 2005 you'll need to post this on the 8P A3 forum, this one is for the earlier 8l models.
    As it is though I'd say the first step is to take it somewhere that has diagnostic equipment and get it scanned for fault codes.
    Feb 2011
    6
    Thanks david, got it booked in to get it hooked up to the computer on Monday. Just wondered if any of the problems were common place! Posted in the 8P forum now, sorry about that!!!!
    May 2006
    Lancs
    211
    The ESP light is fairly common but can be caused by any number of things, there are various sensors that the ESP system uses and it only takes one to be faulty to trigger the warning light, that's why you really need to get it scanned.
    Essflee's Avatar
    Mar 2008
    2,007
    Could be a knackered maf.
    revo'd
    666markyboy's Avatar
    Mar 2008
    Oldham, Manchester
    1,110
    Or a vacuum hose somewhere has come adrift or split
    1999 A3 Quattro 1.8T Pics >>HERE
    2002 A4 Avant quattro 1.9 TDi
