AH FabricationsJMB Retrofits
Results 1 to 7 of 7
    Feb 2011
    AAARGH!!!! 2001 S3 temp issues and more!!!
    Any thoughts on the following symptoms for a 2001 S3
    • Car struggles up to get to and does not maintain a normal running temperature
    • ECU light on
    • Below average MPG 24ish careful driving used to get more
    • The air con does not know what temperate it is, I.E whatever temp I set it at it blows about the same and the air does not get hot.
    Any suggestions as to what will be causing these issues and which I should tackle first?
    Many thanks for the help!!!!!
    Jan 2011
    54
    Having been through a similar experience, point 1 will be down to the thermostat, resulting in point 4, and 2 and 3 could be the CTS incorrectly reading the coolant temperature and therefore running slightly rich. Thermostat is about 24 from Audi, the CTS around 8-9 from any parts retailer.
    Note - I had a "genuine" Audi thermostat fitted by a dealer, didn't resolve the problem. Collected and fitted a "genuine" Audi thermostat myself today, problem resolved. I did the CTS too, purely because I had my tools out and it's only a 5 minute job.
    beachbuggy's Avatar
    Surrey
    1,744
    Will almost certainly the thermostat.
    Oct 2010
    59
    Is there any how to guides on here on replacing the thermostat?
    1992 Cavalier SRi 8V RIP
    2002 Mondeo ST TDCi Good riddance!
    2000 A3 8L 17" Ronal TT, -45mm, LCR Splitter, Matt Black Badging, Soon to attempt Lamin-x headlight tints
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Quote Originally Posted by stu_b View Post
    Thermostat replacement procedure..>> - AudiWorld Forums
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    Car Thermostat | All types of Car Thermostats
    As said, change the thermostat first then see how things go
    Speedy Steve's Avatar
    Nov 2008
    Leicester
    1,246
    yep id agree with stat if you have vagcom you can check the temp while running in that then id go for CTS which is a breeze to change
    Ive been Badger 5'd
    Can we break the magic 300?????? In a word Yes 314 BHP 249 lbft at Badger 5
    steves is way quicker than any stock turbo'd s3 i have driven
    I only date skinny Women! They keep my power to weight higher...
