It's just 8 Torx screws, 4 behind the end cap on the dash, 3 up inside the glovebox and one down low near the centre console. If you have an airbag switch inside the glovebox then you'll need to unplug it but don't put the ignition on while unplugged as it will disable the airbag system and can only be reset with VAGCOM/VCDS.
