Volks AutosAH Fabrications
Results 1 to 9 of 9
    3hZ
    Audi's make the world go round
    Jan 2011
    Manchester
    27
    The humble gear box
    Does anyone know how to check the gear box oil on an A3 1.8TSQ 53 plate?
    Cheers people. Matt
    4 Springs and a duck please.
    Mpathe's Avatar
    1st gear
    Aug 2009
    manchester
    394
    no way checking the oil as there is no dip stick, but you
    could drain it and put new oil in
    09 white black edition a3 2.0 tdi 😃
    99 silver apy s3 - revo stage 2 mapped - relentless downpipe + sports cat - cat back milltek - fmic - piper x panel filter - silicone tip - forge 007 - vmaxx coilys - andy mac stealth sub - wilwood 4pots and r32 discs - h &r spacers - bbs ch wheels or std gunmetal grey alloys
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,061
    Its supposed, to be up to the oil fill nut, so you could dip your finger in??
    3hZ
    Jan 2011
    Manchester
    27
    I know this sound stupid but where do I locate it? And is it easy to get too?
    Mpathe's Avatar
    1st gear
    Aug 2009
    manchester
    394
    the drain plug is on the bottom of the gearbox and the filler plug is on the front of the gearbox
    Carpy25's Avatar
    Oct 2007
    272
    dont "dip you finger in" with the engine running or that finger will be no good for dipping any more
    flat surface fill till it runs out the level nut hole, should be filled for life unless you have lost some with a leak no need to change in road cars , race cars use thinner stuff and additives to aid gear shifts and reduce drag but this could rduce the life of the box
    Rob
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,061
    Quote Originally Posted by Carpy25 View Post
    Rob
    LOL.....if he would be able to do that it would be a miracle as it would have to be in gear with the engine running for anything to be moving....
    you wouldnt check any fluid levels with the engine running apart from screenwash would you?
    Carpy25's Avatar
    Oct 2007
    272
    dave even out of gear with the clutch engauged(pedal up) the first motion shaft is turning and that is driving the lay shift which is meshed to the gears on the output shaft , when you engauge gear you lock a gear on the output shaft to the shaft its self via a selector therefore transmitting drive to the differential and on to the wheels this is how gear boxes work
    trust me dont stick your finger you could end up picking your nose with your elbow ,
    as checking engine levels ect with the engine running seen people touch drive belts engine fans the lot is very easy to slip up
    Sorry people but i don't make these things up if i don't know i don't say anything
    Rob
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,061
    Ok mate, points noted, i did not tell him to check it with the engine running though...unfortunatly you cannot see the level, so i believe this is a standard way of checking, i suppose you could use a straw etc.
