Chris NottSky Insurance
Thread: STIFF STEERING
    shanejess
    STIFF STEERING
    my stearing has always felt stiff since i bought the car 2 years ago, i notice this more at the weekends after being in my A3 diesel during the week, when reversing or turning when going quite slow the steering is stiffer than i think it should be, when friends have driven the car they have comented on the stiff steering. their is no strange noise or anything coming from the steering an ive checked steering fluid level which is fine, is the S3 steering supposed to be like this or does any one know what the problem might be, thanks in advance shane.
    S3KO4's Avatar
    Aug 2009
    London
    850
    Check fluid is actually green, and not red as this is the wrong one. brown is worn out.. etc. use it on a clean tissue..
    Tire pressure makes a huge difference, both side must be equal.
    finally if non made a difference check the condition of the drive belt for cracks and worn out condition, if it has gone shiny then its likely to slip from time to time. and lastly with the TDi engines they have issues with alternator pully this affects the steering, usually makes some noise sometimes it doesn't it works abit like the clutch on the AC compressor, so that might be simillar to your s3.
    My steering feels heavier than most other VAG cars I have driven.
    S3-8L REVO stage 2, Milltek, 3" DP & custom 3" decat, RS2 spark plugs, 4 bar FPR, Green-Cotton uprated upper/lower boost hose & TIP, Front Zimmerman & Ferrodo. LCR spliter. boost gauge, smoothed AB. Aero blades, H&R 5mm spacers. Best time 14.03sec, 0-62 in 5.7sec. 207gs @ 25psi , polished inlet mani. VAGCOM 805.1
    Mpathe's Avatar
    1st gear
    Aug 2009
    manchester
    394
    also ive noticed a pressure switch on the pump does anyone know if we can test it with vagcom as my steering is heavier than my mates s3 and there seems to be no visual problems
    09 white black edition a3 2.0 tdi 😃
    99 silver apy s3 - revo stage 2 mapped - relentless downpipe + sports cat - cat back milltek - fmic - piper x panel filter - silicone tip - forge 007 - vmaxx coilys - andy mac stealth sub - wilwood 4pots and r32 discs - h &r spacers - bbs ch wheels or std gunmetal grey alloys
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,411
    S3 steering in general seems quite heavy, driving with 19" rims and wider 235 tyres amplifies the heaviness also.
    You've got to have a laugh!
    Aug 2007
    199
    Quote Originally Posted by S3KO4 View Post
    Could worn out fluid cause creaking (noise) in the rack?
