Monster MotorsportBadger5
Results 1 to 8 of 8
    adcooper's Avatar
    Audi A4 Avant 1.8T 190 S-Line its good to be back
    Dec 2004
    Birmingham
    256
    Few questions about the S3
    As above just a few questions about my new 2003 S3 i would like to ask other owners cheers for any help.
    1) The boot button on the key, mine does nothing is it supposed to open the boot when locked?
    2) When the engine is on all the dash (speedo, rev counter and window buttons) are lit, is that normal?
    3) Some one told me it was hard to wheel spin the S3, when i gave it some beans earlyer the TC light flashed like a xmas tree even from 1st to 2nd gear, is that normal?
    4) The temp gauge is always on 90 is that ok?
    5) Someone also told me that you can get the car to lock it self if you go quicker than 5-7mph can audi do that?
    Last one honest i have also heard that you can get the car to open the drivers side first then the rest if you press the button again, can audi do that too?
    Sorry for all that but any feedback is greatfully appreciated!
    Adam
    [img]/ubbthreads/images/graemlins/beerchug.gif[/img]
    Apr 2004
    London
    404
    Re: Few questions about the S3
    I am probably the least knowledgeable person on here but I'll have a stab:
    1. Yes, the boot should open. You should hear the same sound as when you open the boot manualy (unlocking).
    2. The instrument panel is always lit but things like climate control buttons are not lit unless the headlights are on.
    3. I have never seen the traction control light on my car come on, and I have tried, even in the wet!
    4. 90 is normal.
    5. Yes, you can do this but you need VAG-COM software, a laptop and cable. The dealer will do this but will charge you.
    Nov 2004
    Hosrham, West Sussex
    390
    [ QUOTE ]
    Adam
    [/ QUOTE ]
    Welcome! Nice choice of car [img]/ubbthreads/images/graemlins/smile.gif[/img]
    1) Boot should unlock and pop open - solenoid probably duff, very common
    2) Only if the headlights are on, not 100% sure on that though
    3) Has the car been chipped? Tyres ok? Have to try pretty hard to get the TC light flashing on mine
    4) Perfectly normal
    5 and 6) Both are anti car jacking features and can be enable by Audi () or a kind forum member with VAGCOM software and cable.
    HTH
    Adam
    PaulRS3's Avatar
    UK
    1,005
    press and hold it for a few seconds and it will pop the boot.
    yes
    it can do if you really brutal.
    yep perfect
    yes its an option that can be enabled at audi or with vagcom. locks you in at about 15mph.
    you can also have locking beep and a couple of other functions, like 2 touch locking. again set like above.
    adcooper's Avatar
    Dec 2004
    Birmingham
    256
    Cheers for the quick responce people.
    3) The Tyres are ok as the car has only just covered 1,100miles from new, dont think its been chipped i have only drove 1 other S3 before from Beechwood Audi. It was a bit damp and i was giving it a bit for the first time as a 306 GTI6 was giving me lip. Should i be worried?
    5) How much does thsi normally cost?
    Cheers yet again
    Adam
    adcooper's Avatar
    Dec 2004
    Birmingham
    256
    5) How much does this normally cost?
    Cheers yet again
    Adam
    Oct 2003
    South Wales
    2,942
    Get yourself along to one of the meets and I'm sure someone will have vagcom with them. I'm sure if you buy them a pint they will enable the features for you.
    Rich.
    adcooper's Avatar
    Dec 2004
    Birmingham
    256
    Anyone want a pint in the midlands? [img]/ubbthreads/images/graemlins/beerchug.gif[/img]
